Sun from Februari 19
9 replies to this topic
#1 MAURITS
MAURITS
  • Loc: Belgium
Posted 19 February 2019 - 12:13 PM
Telescope 150mm with Baader D-ERF, extensions, Quark chromosphere, 0.5x reducer and ASI 174 MM.
No newton rings to see (no tilter or eliminator used).
This is the first time that I have a recording all in one time.
The post processing from the surface and prominence is from the same recording.
At the first sight, all was oké.
The gray scale image is I think well, except the white ring around the edge (I don't know where this come from) ?
The color version is total different from my previous method, when I had two recordings (one surf. and one prom.), however with the same color settings. Hmm stranges results … but oké.
  • will w, hopskipson, RickV and 4 others like this
#2 MalVeauX
MalVeauX
  • Loc: Florida
Posted 19 February 2019 - 02:19 PM
Looks good Maurits!
Very best,
#3 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 19 February 2019 - 04:49 PM
So how does one capture the surface and prominence in the same video?
#4 rigel123
rigel123
  • Loc: SW Ohio
Posted 20 February 2019 - 07:06 AM
Nice Maurits!  I'm guessing that bright rim is simply parasitic light from the photosphere that one gets when using a bandpass as in a single stacked set up.  I'm sure Bob can explain it better, but I know with my single stacked Lunt I get this and have to play with the image to minimize it when capturing the surface and proms in one shot.  My luck with capturing all in one shot depends upon the brightness of the prom and how good the seeing is.  Then for me it’s simply balancing the Gain, Gamma and exposure to be able to get the two elements to show well.  If the proms are bright it’s much easier to accomplish.
#5 RickV
RickV
  • Loc: Ottawa, ON, Canada
Posted 20 February 2019 - 07:48 AM
Maurits... excellent.
#6 MAURITS
MAURITS
  • Loc: Belgium
Posted 21 February 2019 - 01:59 AM
James, with Imppg you can play with the curves and save the image first for the Proms , reset the curve and adjust it and save for the surface.
In Photoshop you can mix the two images as one.
#7 MAURITS
MAURITS
  • Loc: Belgium
Posted 21 February 2019 - 10:47 AM
I have the above images again reprocessed.
I have attempted to improve the white border.
  • hopskipson and MalVeauX like this
#8 MalVeauX
MalVeauX
  • Loc: Florida
Posted 21 February 2019 - 10:51 AM
Lovely prom!
Very best,
  • MAURITS likes this
#9 MAURITS
MAURITS
  • Loc: Belgium
Posted 21 February 2019 - 11:13 AM
Marty, this is the same prom as before (images above), but I tweak out more details in Imppg.
#10 rigel123
rigel123
  • Loc: SW Ohio
Posted 21 February 2019 - 09:49 PM
Nice job on the repost!
