Comparison: W.O. FLT 110 and Takahashi FSQ 106
6 replies to this topic
#1 Bob Kimball
Bob Kimball
Posted 19 February 2019 - 02:56 PM
I have been an astrophotographer for 6 years.  I currently have a William Optics FLT 110 with a flattener/reducer.  The scope fill my 8300 sensor with round stars and I like the effective focal length of 540 cm.  On the other hand, I'm an equipment junkie and can't resist thinking about upgrading to a Takahashi FSQ 106.
Here is my question:  Would there really be a significant difference if I upgraded?
Bob
Edited by Bob Kimball, 19 February 2019 - 04:48 PM.
#2 dhaval
dhaval
    Vendor
  • Loc: Round Rock, TX
Posted 19 February 2019 - 04:25 PM
Given that you're a self proclaimed equipment junkie, I am sure after you've bought the FSQ106, you will next want to buy a 16803 camera with 65mm square filters to ensure you are covering the full image circle that the FSQ provides. Good times!
I haven't used either scope, although I do have a couple of imaging buddies who use the FSQ106. They are generally very impressed by the scope and the star colors that they get. I tend to agree with them and their quality of images show all that is nice about the FSQ. The newer FSQ106s are all made from FPL-53 lens, unlike an older generation of FSQ scopes that were made from a flourite element. These buddies of mine do have the older version of FSQ106, one of them does have the flourite element version not sure about the other one though - maybe that contributes a bit to the wonderful star colors and sharper images, I am not sure. Not that the FPL-53 lens is a slouch, but still.
Having said all that though, what is nudging you to buy something new? Just the "equipment junkie" aspect of it? Not that it is a bad thing, but trying to figure out what got you started in the first place.
CS!
  • psandelle and Gene3 like this
#3 RogeZ
RogeZ
  • Loc: Palm Beach Gardens, FL
Posted 19 February 2019 - 06:35 PM
Bob:
If you are going to stick with a 8300 sensor, the improvement will be minimal.
What the FSQ does very well indeed is open the door to much larger sensors and make it look easy!
  • Jim Waters and psandelle like this
#4 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 19 February 2019 - 09:22 PM
Bob
Yes, there will be a significant difference. The FSQ is better corrected, has a larger imaging circle, and has available reducers to really speed it up, if you so desire. Just be sure to get the ED model and not the -N model, as the -N model is the Fluorite one and the reducers will not work with it.
You will also feel lighter, as your wallet will weigh you down less. grin.gif
  • Salacious B Crumb likes this
#5 Bob Kimball
Bob Kimball
Posted 20 February 2019 - 01:19 PM
Thank you all for your input.  I think I'll just stick with my W.O. FLT 110 as long as I keep my Atik 383L camera.
#6 Gene3
Gene3
  • Loc: Del Mar, CA
Posted 20 February 2019 - 01:38 PM
CS!
Hi Dhavel,
If one were to "invest" in the 16803 for the FSQ106, then the pixel size goes to 3.5 arcsec/pixel (FOV 239 x 239)
In your opinion is that large pixel size a drawback in any way? Are you limited to really big targets where detail/resolution is not super important?
Gene
  • hahied likes this
#7 dhaval
dhaval
    Vendor
Posted 20 February 2019 - 03:46 PM
Hi Dhavel,
Gene
I am no expert when it comes to matching cameras, telescopes and targets. From my limited understanding of the subject, people use that combination when they are really after large FOVs, I don't believe they are after detail in that situation.
I would imagine, at 530mm FL using a 3.8um camera under good seeing (between 1" and 2"), you are already very close to being undersampled suggesting that you may already be giving up resolution (not to mention a 4in telescope has a theoretical limit of how much it can resolve). So, when you do use 9um camera, you are obviously giving up resolution and seriously limiting yourself to larger targets.
CS!
