Skywatcher EQ6-R vs EQ6-R PRO
5 replies to this topic
#1 eitannudel
eitannudel
Posted 20 February 2019 - 08:18 PM
Hello! I can't seem to find any information regarding what is the difference between the pro and non-pro versions of this mount. I found HB photo has the non-pro version for sale now, and the specs match the pro, but not sure if I am missing something. What is the difference??
Thank you!!
#2 tonyt
tonyt
  • Loc: Australia
Posted 20 February 2019 - 08:56 PM
Belt drives and a handle are the obvious differences plus some other smaller things detailed here: https://www.firstlig...rial-mount.html
I like the AZ-EQ6 better than either as it's a few pounds lighter and has a better altitude adjuster.
  • eitannudel likes this
#3 SDTopensied
SDTopensied
  • Loc: Atlanta
Posted 20 February 2019 - 09:10 PM
EQ6-R and EQ6-R Pro have been used interchangeably for the same mount.  I'm not sure when the confusion started, but the first time I saw it for sale on one of the US retailer's sites, it was listed as the EQ6-R.  The SkyWatcher site lists it as the EQ6-R Pro and there is no EQ6-R model listed.
-Steve
#4 Eddie_42
Eddie_42
  • Loc: Colorado Springs
Posted 20 February 2019 - 09:20 PM
the non pro is the older generation.
Controller to mount connection is a DB9 cable in the older, RJ-45 in the PRO
Controller has a USB-B (printer cable) port on the bottom for linking between a computer (can still bypass controller entirely with appropriate cable)
Touch heavier payload capacity on the PRO (44 vs 40lbs)
#5 skyward_eyes
skyward_eyes
    Vendor - Sky-Watcher USA
Posted 20 February 2019 - 10:01 PM
Anything with “Pro” in the name indicates it’s good for astrophotography.
To be honest all our mounts can be used for that application for the mount part.
The EQ6-R comes in one version only. Some people use Pro in the name while others cut it out. Regardless it is all the same mount.
  • JeffreyHorne, LuntSolar, RickDawg and 1 other like this
#6 eitannudel
eitannudel
Posted 21 February 2019 - 12:01 AM
Thank you for your answers. Seems like skyward_eyes and SDTopensied are right. The descriptions between the skywatcher usa and HB photo websites seem identical, its just weird that they don't use the same nomenclature.
Thank you again.
