Identify Object near NGC3344
6 replies to this topic
#1 aacc66
aacc66
Posted 20 February 2019 - 09:54 PM
This is kind of a re-post, but I am not sure if the original post was in the correct forum.  I managed to image ngc3344:   https://www.cloudyni...e-sliced-onion/
I found an object that doesn't have an identification when annotating it in pixinsight.  The object seems to look like a galaxy, but the image analysis and annotation seems to not notice it.  I even went to Simbad and it doesn't identify it; but I was able to use Simbad to get the Ra and Dec for it, which is : 10 43 0.878 +24 40 55.36
I assume that I am doing something wrong with image analysis and the annotation and maybe someone can point me to the correct library for this object.  I would like to know the id name for it.
Thanks for any help.
Alvaro
The image should show the object with a yellow arrow with respect to NGC3344 and there is also the annotated version showing that it is not marked. And a larger picture of the object inside the yellow dashed box.
#2 bmhjr
bmhjr
  • Loc: Colorado
Posted 20 February 2019 - 10:17 PM
Looks to be PGC 3759468.  A +15.77 magnitude spiral galaxy in Leo Minor.  Nice image.
#3 havasman
havasman
  • Loc: Dallas, Texas
2MASS 10430087+2440550
Per Aladin Lite
  • rekokich likes this
#4 catalogman
catalogman
Posted 20 February 2019 - 10:43 PM
PGC 3759468 = 2MASX 10430088+2440545 (where X=extended sources)
The GLADE catalog has a mag of B = 15.69
PA 82 deg
--catalogman
#5 aacc66
aacc66
Posted 20 February 2019 - 11:13 PM
Thank you all.
With your information, I was able to find it in Aladin lite using both identifications: 2MASS 10430087+2440550 and 2MASX 10430088+2440545. Simbad will show it and mark it with a green cross but will not identify it, while it will mark the a star, a proper motion star and a galaxy that looks quite dinky compared to 2MASX 10430088+2440545.  I haven't found a catalog that uses this PGC code, but need to try harder, I suppose.  Wonder why it is hard to find in the catalogs, but the smaller galaxies are easier.
Thanks again.
Alvaro
#6 catalogman
catalogman
Posted 21 February 2019 - 10:15 AM
Attached are screenshots of the 2MASX and GLADE ID's from Aladin.
You could also get these by searching all of the catalogues in Vizier very near the position:
http://vizier.u-stra.../viz-bin/VizieR
Also attached is part of the PGC record in HyperLEDA. In this link to the SQL query form
http://leda.univ-lyo...ld_fullsql.html
type
SELECT * WHERE de2000 > 24.681 and de2000 < 24.682 AND al2000 > 10.716 AND al2000 < 10.717 AND objtype='G'
--catalogman
Edited by catalogman, 21 February 2019 - 11:37 AM.
#7 aacc66
aacc66
Posted 21 February 2019 - 10:47 PM
Wow! thank you Catalogman, for sure I will use those links in the future.
BTW: Is all that knowledge why your call-name is Catalogman?
Thanks again,
Alvaro
type
--catalogman
