Pier engineering
304 replies to this topic
#226 macdonjh
macdonjh
Posted 30 June 2020 - 08:35 AM
After that - consultations with architecture and constructor of the building. May be I`ll change type of the building footer (from slab to strip)...
But really complicated consultation will be with my wife smile.gif 1 square meter pier is a serious point. Probably she will have much stronger arguments about pier then climate, type of soil and resistance of materials all together smile.gif Then I`ll have to accept solution of domes developer and make a "floating" footer of pier on vibration damper, placed on the mansard floor. We will see.
Thank you a lot again!
Agreed.  Engineering problems are usually easy to solve in comparison to making the solution aesthetically pleasing.
#227 macdonjh
macdonjh
Posted 30 June 2020 - 09:16 AM
Using the load conditions at the beginning of this thread, 12" steel pipe deflects about 6 arc-sec.  Too much.  So, you either go bigger or just don't bump it in the first place.
This has been gnawing at me.  So I redid my numbers.  Hopefully this won't be too boring for the denizens of this thread.  I thought about sending speedster a PM, but then thought some might find this interesting.
For a cantilevered beam (or column) with a force applied to the end:
d = PL3 / 3EI  (sorry, no Greek font, that "d" should be delta)
With a bit of rearranging, since speedster calculated 6" arc (or 0.007", 240" * TAN(6" arc) ):
P = 3dEI / L3
P = 3(0.007 in)(30x106 lb/in2)(279 in4) / (240 in)3 (note, I= 279 is for 12" x 0.375" wall pipe)
P = 12.7 lb (the load at the top of the 20'-0" tall pier pulling sideways).
Since speedster's criterion is 0.5" arc (0.0006 inches) deflection, I reorganized the deflection equation to find I:
I = PL3 / 3dE
I = (12.7 lb)(240 in)3 / 3(0.0006 in)(30x106 lb/in2)
I = 3251 in4
The area moment of inertia for a "hollow" circle is:
I = PI(R4 - r4) / 4
Since, at least in the US, "standard weight" pipe is available, I'll assume the wall thickness will be 0.375":
I = PI(R4 - (R - 0.375 in)4) / 4
Therefore (I wish I hadn't thrown my scratch paper away, I don't remember how I calculated this without expanding the polynomial above):
3251 < PI[ (15 in)4 - (14.625 in)4 ] / 4
3251 < 3829; therefore, 30" x 0.375" wall thickness pipe will be suitable.  For reference, the moment of inertia of 24" x 0.375" pipe is 1942 in4, so it isn't stiff enough to meet the 0.5" arc deflection criterion.
Those were the calculations behind my recommendation of 30" x 0.375" pipe for a 20'-0" tall pier with a maximum deflection of 0.5" arc under a 12.7 lb side load.  Or, in metric: 762mm x 9.5mm pipe for a 6.1m tall pier with a maximum deflection of 0.5" arc under a 5.8kg side load.
  • Christopher Erickson likes this
#228 speedster
speedster
    Astronomy Architecture and Engineering at McCathren Architects
  • Loc: Abilene, Texas
Posted 30 June 2020 - 03:51 PM
macdon,  your calcs are spot on.  The difference is that you are figuring 12.7# force and I'm figuring 5#.  The 5# is an arbitrary number to sort of simulate a bump of the pier and to have some defined load for calculating deflection difference in various pipe and concrete shapes.
#229 jambi99
jambi99
  • Loc: Ottawa , Canada
Posted 21 July 2020 - 02:03 PM
Howdy GraySkies!
Part 9 of the Ontario Building Code states frost depth is 1.2m which is 4' feet.  There is no "wrong" way when the final decision boils down to personal preference.  This thread was started so we all have some accurate info to make informed decisions and get the most bang for the buck.  Ultimately, we are after stiffness which is measured by modulus of elasticity.
Steel = 29,000,000 psi
Aluminum = 10,000,000 psi
Concrete = 4,350,000 psi
Specific metal alloys make a difference, as does concrete mix design but, a general comparison of structural metals and 3,000 psi concrete shows that Aluminum is 3x stiffer than concrete and steel is 3x stiffer than aluminum.  The shape and length of the piece also affect stiffness so a 16" concrete column is stiffer than an 8" steel pipe even though concrete is 7x more flexible than steel.
The 8" concrete pier scheme has a practical problem with embedding anchor bolts in the top of it.  Embedded bolts need to be at least 2-1/2" from the edge of the concrete which really limits your bolt pattern on an 8" concrete pier.  You could do a funnel shaped bolt cage and embed the funnel so there are ways around this if you want an 8" concrete pier.
The aluminum option is personal preference but bare in mind that an 8" aluminum pipe is way more expensive than 8" steel and also way more flexible.  Weight is our friend and steel is heavier.  At our thicknesses, corrosion is not an issue for the next 100 years unless aluminum is in contact with concrete.
The one certain thing is that our needs and wants will change over time and the metal pier on top of concrete pier gives you a great deal of future flexibility since it is relatively easy to cut some off or weld some on later.  Also easy to attach stuff to it and run things through it.
Looks to me like steel (or Al) on concrete is the way to go.  A local shop can typically weld up a pier to your specifications cheaper than the store-bought ones and you can get exactly what you want.
Just to confuse things, since you are going 6' deep (excellent), you could just suspend an 8" steel pipe in the hole and concrete it in like a big fence post.  No bolts, no pier fabrication cost and, if you move, just cut it off and take the top with you.  Then, weld a base plate on it and you still have your pier.
I'm interested in the funnel type bolt cage setup. My concrete pier is not wide enough to accommodate my steel pier. So, when you are are referring to a funnel type bolt cage you also mean that the concrete shape will have a funnel shape right? Like that (sorry for the quick drawing):
My other alternative( and preferred one) would be to finish the above grade section with concrete block(wider). The only issue with that is that the above grade section will be wider(by 3-4 inches around) than the below grade section. I guess this is not a good design while the frost will push up against the concrete block like if you are trying to remove a nail by its head. Please note at this point I really do not want to dig wider. My current hole is 6' 4" in depth and about 15-16 inches wide.
Edited by jambi99, 21 July 2020 - 02:11 PM.
#230 speedster
speedster
Posted 21 July 2020 - 04:20 PM
concrete shaft is straight but the bolts are bent toward the center.  Our loads are so low we can do some things to make things fit.  Imagine a 1/2" x 12" hex head bolt.  Just below the threads, bend it about 30 degrees and embed it so the head is pointing toward the center of the concrete.  Threads are vertical, the part just below the threads doesn't have much concrete cover but concrete cover increases as you go down the bolt.  Below ground, 2"-3" of concrete cover pretty much eliminates corrosion issues with the rebar.  At bolts above ground, the concrete cover prevents loading in tension of a skinny piece of concrete.
If the funnel shaped bolt cage still doesn't give you enough width for the steel pier base plate bolts, It's common to put an enlarge cap on the top of the concrete, just like your nail head analogy.  The cap part would only be a few inches bigger than the shaft and only needs to be a couple of inches thicker than the embedded length of your bolts.  I wouldn't worry a second about the frost heave acting on the bottom of the cap.
#231 jambi99
jambi99
Posted 21 July 2020 - 06:06 PM
The thing is that my concrete cap would be 6' tall. So it would be 6 feet underground and 6 feet above grade being slightly larger than in ground. Any issue with that?
#232 outofdark
outofdark
  • Loc: SLC
Posted 23 July 2020 - 09:02 PM
Hi All,
Just got my pier bolted in place today.  Thanks to speedster I designed a pretty stout pier.  It's made of schedule 80 ten inch steel pipe. The base plate is one in thick.  Overall it's 96 inches and just over 600 lbs.  It's bolted to a cubic yard of concrete.
  • tim53, DeanAK and kathyastro like this
#233 macdonjh
macdonjh
Posted 23 July 2020 - 10:10 PM
Hi All,
...and I thought my pier was overkill.  Not that I'm making fun: concrete and steel are cheap,  worrying whether or not your scope is steady enough is expensive.  I'll be interested to see photos of your completed observatory.
#234 outofdark
outofdark
  • Loc: SLC
Posted 23 July 2020 - 10:19 PM
You make me laugh! One does lay awake at night pondering such thoughts.
more build pictures here. http://thestarquarry.com I started work on my obseratory just over a year ago.  I figure I have a few months to go before I'm opperational.
  • brave_ulysses likes this
#235 macdonjh
macdonjh
Posted 24 July 2020 - 07:35 AM
That is an impressive project.  I don't think I ever would have built mine if I'd needed a concrete pumper.  The photos near the bottom of your build page with snow on the ground were surprising.  I am always shocked to see snow in what otherwise looks like a desert'y area.
#236 outofdark
outofdark
  • Loc: SLC
Posted 24 July 2020 - 07:41 AM
Yes sir, in Salt Lake at 4800'. it's been known to snow in early June some years.
#237 dkb
dkb
  • Loc: Minnesota
Posted 25 July 2020 - 12:55 PM
Is there a difference in deflection between a steel pipe compared to a steel square tube made of same material and thickness?
Was also wondering how much difference the type of steel would make in a telescope pier.  Since you have access to a lot of different steel I wasn't sure if there was that much advantage of one or another (besides price).
#238 macdonjh
macdonjh
Posted 26 July 2020 - 12:22 PM
There will be a minor difference in deflection with a square tube.  In some directions deflection will be less, in other directions deflections will be more.  One of the nice things about round sections is their properties are symmetrical no matter which way you try to bend them.  All that said, if you were to do the math, the differences in deflection would be tiny, so I don't think you should worry about it.  If you have access to an inexpensive piece of square tube which meets your needs, you should use it.
No, there won't be any practical difference in different grades of steel.  For our purposes they all have a bulk modulus of 30,000,000 psi (that's the property which describes how resistant a material is to deforming).  Some actually have E=29x106, or E=29.5x106, but it doesn't make a practical difference.  You may find your calculations suggest using a 4.1" diameter pipe, but you'll have the choice of "making do" with a 4" or going up to a 6" pipe.
  • dkb and Scott123 like this
#239 StarAlert
StarAlert
Posted 09 October 2020 - 06:38 AM
Shifting gears to the other end of the size spectrum, I’m making an 8” pier extension for my ioptron AZ mount Pro. Like just about everything in astronomy these days, they are on back order and won’t be available for 6-8 weeks. So I decided to make one myself. I’m using two 6” diameter, 1/4” thick steel discs. My question is how thick should the 8” long steel extensions be? I have 5/8” and 1/2”. I was going to use three 5/8” legs instead of four 1/2” legs to allow easier access to the bolt to secure the mount. Would three 1/2” diameter legs be sufficient?
4E620678 CD95 4574 A0B8 773D7CECD6C1
AF71C58F 972F 42E6 95BB ABA82ECD3D63
Edited by StarAlert, 09 October 2020 - 03:23 PM.
#240 speedster
speedster
Posted 09 October 2020 - 04:41 PM
Howdy StarAlert!
Anything will be sufficient to keep it from falling down.  I think the nut can be tightened with a ratchet with a universal knuckle between 2 extensions so you need enough space between rods the get a socket between them but not necessarily enough to swing a wrench.  My mounts don't have a center bolt so I'm speculating there.  To get a feel for deflection of the options, we can look at the Section Modulus and simplified comparison to a 4" pipe which is a size we have somewhat of a "feel" for.
Sx of 4" pipe = 3.21
Sx of 1/2" solid rod = 0.01225
Sx of 5/8" solid rod = 0.02393
Sx of 1" pipe = 0.13264
Options look depressingly flexible compared to 4" pipe but you actually have an assembly rather than just the sum of 3 or 4 members and that's what makes several small members work for you.  Your Sx is the Sx of the assembly rather that just the parts.  Diameter is your friend so the 5/8" beats the half and 1" pipe is much better.  The more members, the better but there are sharply diminishing returns and more than 4 is overkill unless there is something weird going on.  Four 1" pipes laid out on a 5" radius has an Sx of about 1.5.
  • StarAlert likes this
#241 StarAlert
StarAlert
Posted 09 October 2020 - 05:07 PM
Howdy StarAlert!
Wow... there is a big difference going to the 1" pipe. This is going to be used strictly for visual. A 4" f8 refractor for high powers and a 6" f6.5 for low power sweeping. First test will be next week.
Edited by StarAlert, 09 October 2020 - 05:08 PM.
#242 Gert
Gert
Posted 25 November 2020 - 05:27 PM
Hello All,
I posted a pier design question for our club observatory here ..
https://www.cloudyni...question-cdk20/
.. and was pointed to this thread.
Maybe the experts here can comment.
We are rebuilding our observing site which was destroyed in the CA fires.
https://www.trivalleystargazers.org/
https://charity.gofu...rebuilding-fund
Our location is on a hill top with rocky hard soil.
We received donations to build a new observatory with a Planewave CDK20 on a Mathis MI750 fork mount. A sketch is shown below.
Maybe the experts here can recommend proper pier design?
Here is an unrelated photo that would show the soil material. It was quite hard to dig little holes to place those 3 pavers for tripod legs into the ground.
Gert
#243 speedster
speedster
Posted 26 November 2020 - 12:24 AM
Howdy Gert!  Even with 500# of load, weight is not the issue.  Deflection is still the issue and your mount allows larger diameter piers than EQ's so you can get your deflection down to about nothing efficiently and economically.  I think I read something in the other thread about a 10:1 weight ratio.  I would ignore any weight ratios.  It's about shape and depth and a weight ratio just obscures what we are really after.   What you see is only as good as what's in the ground.  My advice:  get an auger mounted on a skid loader or trailer and drill an 18" hole 6' deep.  Bigger and deeper is marginally better but this will do it.  Pour concrete directly in the hole.  Very important to not form anything below ground.  If the rocky soil leaves a rough hole, that's fine.  The concrete will fill all the voids and roughness.  Form the part above ground with 16" Sonotube or spiral duct or 18" galvanized steel culvert pipe.  The base on the mount is 14" so it looks like 16" or 18" diameter shaft will fit up fine.  Four #5 rebar full height with #3 round stirrups at 24" on center vertically.  Considering the load conditions that this thread is based upon, a 16" concrete pier 7' out of the ground has a deflection of 0.125 acr-sec.
If you happen to encounter consolidated bedrock, drill into it and epoxy rebar directly into the rock.
#244 macdonjh
macdonjh
Posted 26 November 2020 - 10:16 AM
speedster,
Gert's location is in northern California, so seismic activity could be a consideration.  I know astronomy loads a tiny, but should he use more stirrups (say on 12" centers)?  I'm pretty sure in earthquake zones concrete columns are now built using "spiral" stirrups along the whole length of the column.  Of course, that's for "real" loads...
Also, if the MI750 has a 14" base plate, shouldn't his concrete be 18" diameter minimum to maintain 2" cover over the anchor bolts and rebar?  Not that it's necessary, but I'd have a stirrup around the embedded portion of the anchor bolts just because.
#245 speedster
speedster
Posted 27 November 2020 - 12:49 AM
More stirrups won't hurt anything and they're cheap so if anyone sleeps better, add more.  Good point about the bolts.  With his mount, it looks like he could go 18".  I assumed if the mount base is 14", the bolts will be inside that.  If the bolts are an inch inside the edge of the plate, he's got his 2" of cover.  Fine going bigger diameter as long as mount clears.  More diameter is stiffer but he's already down to 0.125 at 16" so bigger diameter could be called optional.
#246 fx4m
fx4m
Posted 28 November 2020 - 11:09 PM
Hello pier-heads,
Fantastic thread.
I am on the team with Gert designing the replacement observatory. We do not have a geologic report and I know very little about geology but here are my observations. Gert's characterization of the "soil" as "hard rocky" may be an understatement (the place were he was digging is a little different than the spot under consideration). The tentative location for our pier and observatory is on, what appears to me to be, a flat-ish solid rock outcrop about 15 feet in diameter on the top of a hill. The surface is weathered, eroded and a bit fractured, (I guess it is sedimentary because of its parallel-ish fractures, if I remember correctly). It has very little soil in the (probably quite shallow) fractures, but I would be really surprised if this was not considered consolidated bedrock at, or an inch below, the surface. Maybe it is tuft. I would think that an 18 inch auger would not be able drill into this (but I don't know what such an auger can do) and that jackhammering would be necessary. The site was graded to form roads and tiers, and there were trees and bushes there (hence the fire) so I guess it is very "hard rocky soil" over most of the hill, but I don't know how deep.
Assuming my characterization of this outcrop as bedrock is correct, how would you proceed? Clean up the surface, drill and epoxy rebar into it without sinking the pier below ground? And what about the building foundation being directly on the same bedrock; should we worry about vibrations from footsteps (I'm guessing no).
Chuck
Edited by fx4m, 28 November 2020 - 11:11 PM.
#247 macdonjh
macdonjh
Posted 29 November 2020 - 08:49 AM
fx4m,
Welcome to Cloudy Nights.
If you're lucky enough to have exposed bedrock exactly where you want to build your club's observatory, congratulations.  You're correct for the pier: use a hammer drill to bore a few holes into the rock and epoxy rebar into the holes.  That will secure your concrete to the rock.  Use the concrete to make a stable "platform" which is the proper elevation and square and plumb for your mount.  What I would do (overkill): eight each #4 rebar, 8" into the rock, full height, then add the stirrups as speedster recommends to tie it all together.  That's more than you need, but the quantities are so small it will make hardly any difference in either material cost or labor (the most expensive part will be renting the hammer drill and buying the correct size bit).
As for your building: rather than jack hammering a flat spot on the rock, I'd use that hammer drill and put rebar around the perimeter of your future building.  Then I'd use concrete and blocks to make a wall with a level top.  A wood floor inside (not touching the pier) and the dome on top of it.
Another possibility: use the hammer drill to secure some rebar in a grid over the rock.  Build form-work such that when it's time to pour you have minimum thickness of 4", the maximum thickness would be whatever it takes to make your slab level.  When that's cured you'll have a flat and level slab to build your building on.  I don't have any experience with piers and floors placed on bedrock: I don't know if walking around would cause vibration.  It can in images in gear set-up on concrete slabs.
A lot depends on access to your site.  Can you get a concrete truck up there?  Pouring that much concrete one sack at a time will require lots of people and lots of effort.
Or you could hire somebody with big tools to flatten that rock...
#248 speedster
speedster
Posted 29 November 2020 - 03:10 PM
We leave an air gap between the pier and floor to eliminate vibration transfer but the pier is still coupled to the structure through the ground.  We really can't escape that coupling.  In your case, you are couple through the rock.  I can tell you not to worry about the pier and structure sharing the same rock but and example is even better.  This is the 4-meter at Kitt Peak and everything is stuck to the same rock:
  • Scott123 likes this
#249 Kirkman1
Kirkman1
Posted 06 December 2020 - 12:48 PM
If I bought a metal pier, could I just drill it into my
Driveway?
#250 speedster
speedster
Posted 06 December 2020 - 02:48 PM
Certainly. Some people are picky about minimizing the potential for deflection but many things work for just holding the mount.  Individuals have different expectations of how stiff they need things so there is no right answer.  The downside of bolting a pier to a slab is that vibrations in the slab are more directly transferred to the pier.  Try setting up on a tripod where you want the pier to be and have someone stomp around while you are at the eyepiece.  Then, you'll see first hand what amount of moving around results in what magnitude of image movement.
Deflection is the result of some applied force.  Take away the force and you take away the deflection.  Even very stiff piers will deflect more than acceptable if you just hit them harder than what we consider to be an acceptable force.  The point of this thread is, if you are going to invest the time and money to do a permanent pier, there are some things to do to maximize its performance.  But, there are workarounds.  I was once imaging off a spongy wooden balcony in Monument Value and I swear a bird landing on the railing would have caused movement.  I started a sequence, tiptoed back into the room, and just threw out the first image that had the shake in it.
