Eyepiece case or box what are you using?
740 replies to this topic
#26 Allan Wade
Allan Wade
  • Loc: Newcastle, Australia
Posted 28 February 2019 - 06:54 AM
I use a Pelican/Storm iM3300 case. It's a fairly large case, but I picked that size because I can fit my entire eyepiece set in there and it means one trip out the door or into the car with everything I need. They aren't cheap, but really only cost about 1% of what's inside the case, so it's money well spent for the peace of mind.
  • Dave Mitsky, Paul G, sipster and 35 others like this
#27 Dunkstar
Dunkstar
  • Loc: Sunshine Coast, Australia
Posted 28 February 2019 - 07:13 AM
Crikey Allan shocked.gif  now you’re gonna tell us you get away with that as carry-on lol.gif
  • jlh7 and stevenwav like this
#28 Allan Wade
Allan Wade
Posted 28 February 2019 - 07:39 AM
  • doctordub, havasman and Joe1950 like this
#29 Dunkstar
Dunkstar
Posted 28 February 2019 - 07:48 AM
#30 Jon Isaacs
Posted 28 February 2019 - 07:56 AM
I use multiple cases plus a camera bag for my lesser used eyepieces.
My main eyepiece case is a high quality aluminum clad equipment case.  I gave up using pluck type and use solid Kaizen foam, It handles the heavy eyepieces without coming apart.  This case has the 31mm and 16 mm Type 5 Naglers, the 11mm, 9mm, 7mm, 5mm and 3.5mm Type 6s plus the 21mm, 13mm and 8mm Ethos and a 2x Barlow, my filters and the Paracorr.  That one case pretty much covers all my needs.
The eyepieces lay flat and if the scope doesn't have an eyepiece rack, then I set the case on a table, or chair or rolling cart and it provides easy access plus dew protection.
Everyone has their own system.  If one has heavy, expensive eyepieces, the case is not the place to cut corners.. A latch that is not secure.. that can be expensive.
  • droid, doctordub, epee and 13 others like this
#31 sickfish
sickfish
  • Loc: Cape Coral Fl.
Posted 28 February 2019 - 08:16 AM
2 pelican cases.
Cut the foam with a knife.
Doesn't have to be exact just cut the spaces smaller than the EP so they are snug.
#32 epee
epee
  • Loc: Suh-van-nuh, Jaw-juh
Posted 28 February 2019 - 09:22 AM
They ARE beautiful.  But eyepieces are very heavy and I don't see the practicality of lugging them around in wood.
I also don't like anything to do with foam.  GN
Not saying that I don't agree on both counts; but out of curiosity, what do you use?
#33 Ryan555_1
Ryan555_1
  • Loc: Phoenix, AZ
Posted 28 February 2019 - 10:03 AM
I use this. It is not expensive, and it is solid.
Edited by Ryan555_1, 28 February 2019 - 10:07 AM.
  • george tatsis, BFaucett, Dana in Philly and 1 other like this
#34 Matt78
Matt78
  • Loc: Maine
Posted 28 February 2019 - 10:30 AM
I just use a small plastic case we were throwing out at work, with some egg crate foam. I haven’t made cutouts, but the foam makes enough pressure that they won’t roll when it’s closed. It’s just a basic hinged nylon case. Nothing too fancy, but it’s very durable.
  • epee, havasman and rodney j johnson jr like this
#35 russell23
russell23
  • Loc: Upstate NY
Posted 28 February 2019 - 12:46 PM
Right now I am using three different Sterilite type boxes as my cases. They latch tightly and each box is light enough that they hold just fine.   I only observe at home so this works fine.  However, Last month I bought a real nice wood case for $25 at a local antique store.  I have not done anything with it yet because I’m still deciding which eyepieces to put in it.  Inside dimensions are 8 1/4” wide by 17 1/2” long by 7 1/4” deep.  I’m not sure if I want to go with pluck foam or try something different.
  • epee, rowdy388, BFaucett and 3 others like this
#36 russell23
russell23
  • Loc: Upstate NY
Posted 28 February 2019 - 12:47 PM
Inside the box:
  • epee, BFaucett, Allanbarth1 and 1 other like this
#37 jaraxx
jaraxx
Posted 28 February 2019 - 02:43 PM
A plastic brief case I found at the Goodwill. $5 out the door, picked up a little foam and good to go. The case goes inside a plastic tub for 4x4 travel.
Kinda like the idea of old camera bags, tho...
  • rodney j johnson jr likes this
#38 JCasey
JCasey
  • Loc: Goldsboro N.C.
Posted 28 February 2019 - 03:03 PM
Apache from Harbor Freight here.  Works great so far.  When it wears out I won' t be out much
  • droid, CeleNoptic and eblanken like this
#39 buddy ny
buddy ny
  • Loc: USA N.Carolina8
Posted 28 February 2019 - 03:43 PM
The H.F. Apache case for 40$
95% as good as a Pelican. I have both.
Ditch the pluck & pull foam. Buy some Kazian foam, I got a 2 ×4 55mm sheet for 29$ locally,, thats about 70$ + enough foam left over for at least 2 other case's
Absolutely worth it
BTW look at the kazien foam videos
 Just to see how u can work this foam. I made the tool that kazien sells my self..
Eazy
Edited by buddy ny, 28 February 2019 - 03:50 PM.
  • CeleNoptic, havasman and eblanken like this
#40 droid
droid
    rocketman
  • Loc: Conneaut, Ohio
Posted 28 February 2019 - 04:17 PM
which filters do you use Jon?
#41 rowdy388
rowdy388
  • Loc: Saratoga County, NY
Posted 28 February 2019 - 04:41 PM
I use a large pelican case but I have an old wooden telescope case with dovetail joints that
I'm considering switching to. I'd probably need to upgrade the handle and latches.
#42 yeldahtron
yeldahtron
  • Loc: Rideau Ferry, ON
I keep each eyepiece in its own bolt case (e.g., https://agenaastro.c...er-42x60mm.html) and transport the EPs I wish to use in the tool tray of the large, wheeled Stanley tool box that supports my Lightbridge. (Box holds cooling fans, charts, extra clothes, radio, power connectors, laser pointer, sometimes some wine, etc.)  I use the same strategy for my ST80, except that its support tool box is much smaller.
The nice thing about using bolt cases is that they protect each individual EP, so the bolt cases can be dumped into whatever container is on hand. No need for a purpose-built box.  Furthermore,  it's easy to take an EP out of its case and to return it to  its protective cocoon -- even in the dark.  As such, I keep the encased EPs I'm using at the scope in a front-mounted fanny pack while I'm observing, knowing that they're protected from dew, dirt, and cold when they are not inserted in the focuser.
Having each EP in its own case means that I can create a purpose-built EP "case" on the fly to suit the needs of the observing mission, the font mounted fanny pack and the two tool boxes mentioned above being examples.  Sometimes I even take my EPs on observing trips while leaving my own scopes at home -- when I want to use my EPs in someone else's scope.
  • sonnyrsg likes this
#43 buddy ny
buddy ny
Posted 28 February 2019 - 06:57 PM
Kazein foam tools
Can be made from a hacksaw blade & a belt sander
A 1/2" copper pipe with cap & rough
Wood handle & go buy an Olfa knife
Cost 12$
  • CeleNoptic and patta like this
#44 BRCoz
BRCoz
  • Loc: San Tan Valley, Az
Posted 28 February 2019 - 09:10 PM
The first case I had was from a device used before projectors were used with computers.  If you remember overhead projectors with transparencies.  The case has hard sides and I used foam from all of the computer equipment used at work.  This was about 20 years ago and I still use it.
The next is an aluminium case. Used with the same foam that I cut custom for eyepieces and diagonal.
I have two others that are smaller used for eyepiece sets that had equipment used in a Hospital.
  • eblanken likes this
#45 Arthur NY
Arthur NY
  • Loc: Metro NY
Posted 28 February 2019 - 09:22 PM
I'm big on the apache cases. Eyepieces, cameras....
I think they have a new big one that I might get for some pro audio gear I have.
#46 pierce
pierce
  • Loc: Santa Cruz, CA
Posted 28 February 2019 - 09:28 PM
i'm on my 2nd pelican.  my first one turned out to be too small, so now I have a 1500.   I figure I have a few $1000 in eyepieces and accessories, its worth keeping them in a secure sturdy case.    its bright yellow so I don't misplace it in the dark.
the real pelican pluck foam works just fine for me.
  • Paul G, RAKing and Lenard like this
#47 Jaimo!
Jaimo!
    CloudyNights is for the people.
  • Loc: 3rd Stone from the Sun
Posted 28 February 2019 - 10:08 PM
I'm somewhat handy... This is an older picture, but I am still using this case in a similar fashion, although some of the eyepieces have changed over the years.  It's a winge top with the constellation of Orion inlaid with appropriate color woods to match their stellar classification.
Enjoy,
Jaimo!
  • Scott Beith, Chopin, BRCoz and 33 others like this
#48 pierce
pierce
Posted 28 February 2019 - 11:15 PM
my pelican 1500 (from before I added the 11, so there's now one more in the lower row)
  • Paul G, Neptune, Sarkikos and 7 others like this
#49 Greyhaven
Greyhaven
Posted 01 March 2019 - 09:10 AM
Draw
  • george tatsis, russell23, denis0007dl and 3 others like this
#50 SandyHouTex
SandyHouTex
  • Loc: Houston, Texas, USA
Posted 01 March 2019 - 09:22 AM
Hello,
What is everyone using to store there eyepieces in?
I have looked at some of the cases made for eyepieces but find them a bit on the expensive side.
What would make a good case or box that others are using that could be modified or used as is?
I like the Televue grey soft case, but like you said, that’s expensive.  You can get a very similar Zhummel case for a lot cheaper.
