What planetarium software?
EAA planetarium software mount
20 replies to this topic
#1 makeitso
makeitso
  • Loc: SoCal
Posted 06 March 2019 - 11:55 AM
Hi again,
So now, I am at a new juncture. I have plate solving working with All Sky plate solver. Never could get astrotortilla to work.
Now, I would like to get a solution going so I don’t have to go out to the mount and use the hand controller to choose the next target. I guess I need some planetarium software.
I do have starry night se. have no idea if it would work or not. It costs more than I want to spend to upgrade, if I even wanted to. I could not get it to work, I’ve only tried once though.
Im not sure really which direction to go in. I’ve checked out Cartes du Ciel. I think CdC would do what I want.
My current flow is using the asi224 is just starting SharpCap and connect it to the mount using POTH, polar align and then plate solve from inside SharpCap. I then go inside and connect to that laptop with another laptop using RDP. Using this method, I have to use the hand controller outside to do Goto’s. I want to be able to do that from inside. Should I be able to connect starry night and SharpCap to the POTH driver?
I would also like to include guiding too. I think I would need another camera for guiding though. Is that correct?
Anyway, I hope I’m not asking too much of all you knowledgeable people out there. I have asked many questions and i have been given great advice from all of you so far.
Thanks, Jack
#2 cmooney91
cmooney91
  • Loc: Massachusetts
Posted 06 March 2019 - 01:39 PM
I like CdCs ability to display multiple charts at once. I use it to show the telescope's FOV, the E-finder's FOV, and an alt-az Eyeball wide FOV all at once.  No more zooming in and out, and depending on which window you drag you get coarse, medium, and fine adjustment.
Works with ASCOM so it should be a shoo-in with POTH.
  • S1mas and makeitso like this
#3 makeitso
makeitso
  • Loc: SoCal
Posted 06 March 2019 - 03:09 PM
Corey,
So, CdC works with more than one camera at a time?
I will download and try it.
I see thatCdC plays nice with PHD2.
How does it work with plate solving? I haven’t been able to find out about that yet?
Shoud I try out APT? It looks complicated.
Thanks, Jack
#4 Biggen
Biggen
Posted 06 March 2019 - 04:46 PM
What mount?   I use a combination of Stellarium on the PC and Sky Safari on the iPad to control my AZ GTi.  My mount has wifi built in, so its pretty easy to control it with a variety of ways.
  • MMBARS and makeitso like this
#5 roelb
roelb
  • Loc: Belgium, Antwerp
Posted 06 March 2019 - 05:33 PM
I do have different planetarium programs tried and found Stellarium the most easy to use.
Also has a bunch of objects to choose.
It is possible to connect your mount with Stellarium and SharpCap via Ascom-POTH.
See here for my wireless setup as an example: https://www.cloudyni...ifi-connection/
To connect the mount with Stellarium it is best to use "StellariumScope".
See here for more details: https://www.cloudyni...ense/?p=8148926
I don't use guiding but I think a separate guiding camera is needed.
Although doing EAA with small exposure/integration times guiding isn't required.
  • makeitso likes this
#6 makeitso
makeitso
  • Loc: SoCal
Posted 06 March 2019 - 06:24 PM
Biggen,
The mount I’m currently trying to get working is an AVX. I don’t want to involve an iPad in the mix. What my goal is eventually, is to have a computer at the mount controlled by another computer in the house. I have that basically now with the exception of gotos, I have to be at the hand controller. If I don’t need WiFi, I’d rather do without it, the exception of course, is the connection between the two computers.
Roel,
I have not considered stellarium yet, I will look into that software. The main thing I’m looking for is integration with the rest of what I’m using. I’m not afraid of scrapping what I’ve got so far and starting over. It does seem that most will work together to some degree. I’m not doing guiding so much now but may in the future. I want to be able to polar align and plate solve, since I’ve gotten that working I’m now spoiled. Why haven’t I already been doing this? I guess because I just started eaa. I’m considering getting another camera, but that’s another thread and even more questions.
Thank you all for the information and advice, Jack
  • roelb likes this
#7 nic35
nic35
Posted 06 March 2019 - 06:46 PM
I use CdC in conjunction with SC Pro. I use the celestron ascom driver, not POTH. All work well together - I issue goto's  in CdC,and plate solve if necessary.  If I plate solve I sync CdC after SC moves the mount.
I tried stellarium, but do not care for the interface.  The one in CdC is decidedly old school, but can be made to show black on white, which I prefer.
Plus, I seem to recall that stellarium is a resource hog.
john
#8 makeitso
makeitso
  • Loc: SoCal
Posted 06 March 2019 - 07:02 PM
John,
 I tried connecting to the Celestron ascom driver. SharpCap did not not show the solve and sync controls for the mount this way, it was only after I connected via POTH it showed these controls. This is all an experiment, I will try it again. Right now, clears sky’s are scarce. Maybe there is an updated ascom driver for Celestron mounts I need to get. It’s been a few years since I installed all that stuff. I haven’t been using it until the last few months. It seems that you’re doing pretty much what I’m shooting for.
I will try both stellarium and CdC. I will most likely try CdC first since it’s been recommended by more people. I think all will be happy together on the same computer.
Does APT have role to play in this or is it just too complex? Looking at the documentation is a little overwhelming.
Its takes awhile to learn all this stuff when you only have a few days a month to be at it. Soon here it will be the hot time of year.
Thanks, Jack
#9 roelb
roelb
Posted 06 March 2019 - 08:20 PM
Latest Celestron ASCOM driver: Celestron Unified (6.1.6944, January 2019) Telescope & Focuser
http://Celestron Uni...scope & Focuser
Since it is already a few years that you installed "all the stuff" it is also recommended to install the latest ASCOM Platform 64SP1:
https://github.com/A...atform/releases
#10 makeitso
makeitso
  • Loc: SoCal
Posted 06 March 2019 - 08:51 PM
Roel,
Thanks for the post and information. The link takes me to the top of this page. I did search and find the ascom update. I have been using 6.2.
 I didn’t know the Celestron driver was separate though. I found it too. It’s all installed and waiting for the next clear night.
CdC is installed. It took me a minute or two before I figured out how to enter my location. Not too complicated, even for me.
You all have been a great help so far, thank you!
Jack
#11 Ptarmigan
Ptarmigan
    Lagopus lagopus
  • Loc: Arctic
Posted 06 March 2019 - 09:07 PM
I use Cartes du Ciel because it is less resource on the computer as I use Sharpcap. cool.gif
#12 makeitso
makeitso
  • Loc: SoCal
Posted 06 March 2019 - 09:35 PM
Ptarmigan,
Is it better than stellarium in that regard? Have you used them both?
Thanks, Jack
#13 Ptarmigan
Ptarmigan
    Lagopus lagopus
  • Loc: Arctic
Posted 06 March 2019 - 11:28 PM
Ptarmigan,
Thanks, Jack
I have used Stellarium, but I think it is more resource intensive as it uses 3D graphics.
Cartes du Ciel had simpler graphics, so it is less resource intensive.
I am not going to say which is better. More of a preference.
#14 makeitso
makeitso
  • Loc: SoCal
Posted 07 March 2019 - 12:05 AM
Ptarmigan,
That makes sense, thanks. I’m going to try both and make a decision. I’m using older laptops, both are i7 CPU’s. They’re both 5 years old though. One has 24Gb of ram and an SSD, the other has 8Gb of ram and a spinner hard drive. It might make a difference, maybe not. Stellarium looks more complicated from the online documentation.
Thanks, Jack
#15 Rickster
Rickster
  • Loc: NC Kansas Bortle 3 SQM 21.8+
Posted 07 March 2019 - 12:06 PM
Regardless of which software that you use, please be aware that they do not all use the same star catalog and epoch (time reference).  This can create a significant discrepancy between your plate solver coordinates and your planetarium program coordinates.  This discrepancy can drive you crazy.  https://www.cloudyni...ing-my-objects/
If using CDC and All Sky Plate Solver (as I do), you need to change the CDC chart epoch setting to Astrometry J2000.  https://www.ap-i.net...art_coordinates  This will get you close enough for most purposes, but it still wont be perfect because the two programs default to different star catalogs.
#16 Rickster
Rickster
Posted 07 March 2019 - 01:40 PM
One nice thing about CDC is that there are many additional (specialty) catalogs available.
http://www.schoenbal.../cdc/cdc_en.htm
https://www.ap-i.net...d=uk/catalogues
http://www.stargazin...n/external.html
#17 makeitso
makeitso
  • Loc: SoCal
Posted 07 March 2019 - 01:42 PM
Rick,
More things to think about, it’s never simple. As long as it’s doable I’m going to figure it out. Thanks for the link and heads up. At least now I know what to look out for.
Thanks, Jack
  • Rickster likes this
#18 Rickster
Rickster
Posted 25 March 2019 - 12:10 AM
I need to amend my earlier post regarding plate solving epochs.  After experimenting some more, I have come to realize that the problem is considerably more complicated and it typically can not be solved analytically because there two many unknowns.  That is, there are 4 components involved (mount, alignment software, planetarium, and plate solver), each with an input and an output.  And typically, the user does not know (conveniently) what epoch each of the inputs and outputs is charted in.  For example, I had to resort to trial and error with my Onstep controlled mount.  And the solution was that I had to set (mismatch) ASPS to Jnow and CDC to J2000.  Or maybe it was the other way around.  Hmmm.  I don't recall without driving to my "observatory" to double check.  But I do recall l that I was very relieved when it finally started working right.  Anyway, the moral of the story is that you may have to do some trial and error to see what works.
#19 makeitso
makeitso
  • Loc: SoCal
Posted 25 March 2019 - 10:12 AM
I had a strange event the other night. I slewed to an object with CdC, then, I plate solved. After the plate solve successfully went through it’s routine, when it went to realign the mount, the mount went crazy, I had to push the direction button on the hand controller to make it stop. After that, I had to realign. This is not making me comfortable for staying inside while my mount is outside where I can’t see it.
Jack
#20 Rickster
Rickster
Posted 25 March 2019 - 01:02 PM
The only time I have experienced something was when the object near the meridian, and the mount needed to move over the meridian.  Depending on how you have things set up, the mount will either freeze or it will take off for home before heading to the object (on the opposite side of the meridian.  Was the object near the meridian?
#21 makeitso
makeitso
  • Loc: SoCal
Posted 25 March 2019 - 06:11 PM
It would have been either m82 or m51 at about 9:00p so it could have been fairly close.
Jack
Also tagged with one or more of these keywords: EAA, planetarium software, mount
