I have been considering buying the Sky Guider Pro or Star Adventurer and had pretty well decided on the Sky Guider Pro but after reading this thread I am wondering if that's the best decision. It appears that the Star Adventurer has a (much?) better base. If the guiding accuracy and reliability in the 2 units is comparable, then the frustrations with the iOptron base may swing me back to the Star Adventurer. It's currently advertised at a lesser cost anyway.
The SGP base/wedge isn’t tooooo terrible. It’s just not up to the standard of the SGP itself. It’s usable (obviously), but not a pleasure to use. There seems to be some variability in quality, mainly, as far as I can see, in assembly. It relies on plastic washers to “pack” the upper and lower section joint. They are not easy to fit into place quickly without misalignment/distortion of the washers.
You can improve on this, if you feel the need, as described earlier in this thread. Basically, greasing the washer/joint and gearing.
As long as whatever wedge you end up with can be aligned without too much effort and is stable once aligned, it sort of doesn’t matter. I could have carried on using the original wedge, but know that there is better out there, if you are prepared to pay the price.
