Choosing between a Quark based refractor and a dedicated solar scope
32 replies to this topic
#26 gnowellsct
gnowellsct
Posted 15 March 2019 - 03:20 PM
 I wonder why Lunt went with EDs for their 80 and 100 scopes? David
Do they also serve as night scopes?  If so that's perhaps the answer.
#27 gnowellsct
gnowellsct
Posted 15 March 2019 - 03:21 PM
Just got in from some of the best h-alpha views I've ever had and that includes the demos at NEAF.  But I'm putting my impressions in the CFF hath arrived thread in REFRACTORS
#28 dscarpa
dscarpa
  • Loc: San Diego Ca.
Posted 15 March 2019 - 09:39 PM
 I'd love to see a side by side with you're CFF 90-Quark and a  Coronado 90  3. David
Edited by dscarpa, 15 March 2019 - 09:41 PM.
#29 ValeryD
ValeryD
    Vendor (Aries)
  • Loc: Kherson, Ukraine.
Posted 15 March 2019 - 09:52 PM
I've read it.  Congrats with a small beauty.
BTW  let me tell you something more.
 First is that the F/30 ratio is not really a design speciafication for Quark or any another (regardless of manufacturer)  H-a etalon.  This F/30 is the maximum of the system "speed"  where H-a etalon (in your case - Quark) works OK.  If you will lower the F/D to about F/45-50 you will get significantly narrower bandwidth of your system (vs what you have at F/30) and so, a higher contrast and better details visibility.
 Secondly, you also will notice another important impovement - if at F/30 you see some FOV non-uniformity (due to imperfection of an H-a crystall) then at F/45-50 it become less noticeable!
 To keep etalon at the highest contrast, you will need to set the tuning knob one or two clicks counterclockwise vs best position at F/30.  To keep the image brightness the same you will need
to use about 1,5x longer f.l. eyepieces.
 So, putting a 1.5x Barlow in front of Quark and reaching slower F/D at F/45-50 in return you will get two major improvements of your H-a system performance.
Hope this helps.
Valery
  • gnowellsct likes this
#30 BYoesle
BYoesle
  • Loc: Washington USA
Posted 16 March 2019 - 10:35 AM
I would assume (yes, I know) these lenses are more readily available or less costly from their OEM objective supplier.
#31 gnowellsct
gnowellsct
Posted Yesterday, 02:26 PM
Hope this helps.
Valery
Well at some point we I can give this a try.  I am unclear about the order of assembly.  Currently it is
telescope-ERF-diagonal-powermate-quark-eyepiece
Where should I put the barlow relative to the power mate?  If you think I should use a different order of assembly let me know.
I don't currently have a 1.5x Barlow.  1.5*4x powermate would get to f/41.  A 2x power mate * 4x powermate gets to f/55 which is not far off the f/50 you are talking about.  I can tell you that this is very high magnification because I did it once by accident and the were not terrific, but it was a cloudy day and there were trees.    The experiment would bear repeating 55*92 mm fl is only 5,000 or so focal length and about 127x with a 40mm eyepiece so I guess it's not excessive.  But I did notice that the solar disk was VERY BIG and it was a little difficult maneuvering.  But I suppose I should put the hand controller at a slower speed.
I'd also like to know what the F/D stands for.  I hate to confess such ignorance in public but there it is.
Thanks for your advice,
Greg N
#32 gnowellsct
gnowellsct
Posted Yesterday, 03:51 PM
I did find this Starizona 1.5x Barlow which looks like it would threat into a Quark etalon.
So with this the optical train would be:
telescope-ERF-diagonal-powermate 4x-1.5x barlow-quark-eyepiece
and would be about f/42
I keep writing ERF.  What I actually have is the UVIR.
thanks
Greg N
#33 George9
George9
Posted Yesterday, 04:03 PM
I think he just means F=Focal length, D=lens Diameter, F/D = focal ratio = f-number.
George
