Well, let's start off with some of the physical stuff and initial inspections.
First thing I did was to ditch that rotten, no good, lower than a snake's belly endcap with the standard collet. In its place I put the endcap with a thin AP back with three locking thumb screws. This endcap configuration has about an extra inch of back focus over the standard collet version and better grip too, both of which are very useful when it comes to bino-viewer use (more on that in a later posting).
Some of the physical stuff:
1. Length with the new endcap and the dew shield fully retracted is 44.25".
2. Weights are as follows:
a. Bare OTA : 24.5 lbs.
b. OTA w/rings & dovetail: 28.5 lbs.
c. OTA as pictured ready to observe
with rings, dovetail, finder assembly,
diagonal and full Denk II viewer system: 34.0 lbs.
I was surprised at just how lite weight the assembly is. For example in configuration c., my 140ED (with handle) is 30 lbs., my CFF F6.5 is 36 lbs., old AP 152 F9 is 34 lbs., old AP 152 F10 ATM build is 40 lbs., and former TMB/APM 152 F8 was 38 lbs.
The G11 seemed quite comfortable with the OTA, which comes as no surprise as this sample of the G11 was superb with the TMB/APM 152 F8.
I also found the OTA surface to have a good feel and grip to it.
I did a bunch of residual back focus measurements (RBF) with several diagonals as that is important to me for bino-viewer use. With my standard AP Maxbrite diagonal with the DPAC grating screen placed directly on the top of the diagonal (no 1.25" adapter), I measured 77mm of RBF using the shorter endcap configuration. With my Lumicon deluxe 2" diagonal there was 83.5mm of RBF while an ancient Novak 2" diagonal from the 80's had 79.5" of RBF. The Baader/Zeiss prism diagonal with 1.25" quick lock top measured in at 116.5mm if I pulled the diagonal out a little to reach focus while the same configured Baader BBHS silver diagonal came in at 104.5mm RBF.
More later.
Jeff
Edit: Forgot to mention that whenever I get a new refractor I check the collimation of the focuser with my Glatter laser by firing it down the focuser and seeing where the exit beam lands relative to the center hole of the aperture mask I make for each scope. To my surprise, it was off center about 3/16" or ~.2 degrees, not much but still an error. The spot stayed put too when rotating the laser. Backing off the FT endcap and tweaking the cap's collimation/locking screws brought the laser through the mask's center hole for the entire focuser travel. It took me all of 5 minutes. In fairness, this was after I had changed out the stock focuser endcap/collet for the one with the AP back but I made sure the three little collimation/locking screws on the face of the FT/AP endcap were recessed before screwing it on the focuser draw tube end. Except for my own ATM projects, I've never had to use those screws to collimate a 3.5" FT focuser. This was the first time the focuser collimation was off with the TEC refractors I've had (have). To be further fair, I do not fiddle with the FT's rotation feature either, as the associated unlocking, rotation, and locking can, by itself, introduce small amounts of error (maybe 1/16"). So I leave it alone. Someone before me may not have. So the error was small at ~.2 degrees and easily correctable, but I wanted to mention it for completeness.
After the cap tweak I checked the lens block with my cheshire eyepiece and it was great, just one round reflection dot.
Jeff
Edited by Jeff B, 10 March 2019 - 07:31 PM.
