IC405 without colors
2 replies to this topic
#1 tommymark
tommymark
Posted 10 March 2019 - 10:28 AM
Hi everyone,
I hope I can collect a bit of RGB too... but the weather... so just simple plain H-alpha.
I still like the ASI183, I just need more clear skies for the small pixels grin.gif
I have a feeling I could collect more photons to get better details in the outer parts. But did I mention the weather?
IC 405 (Flaming-Star-Nebula) by TommyMarkus, on Flickr
CS
Thomas
  • rustynpp, CCD-Freak, psandelle and 6 others like this
#2 BenKolt
BenKolt
Posted 10 March 2019 - 03:08 PM
That's beautifully done.  I do hope you get the chance to add color soon.  But your monochrome rendering certainly brings out the unique ripples of this nebula.
Ben
#3 tommymark
tommymark
Posted 15 March 2019 - 03:53 PM
Thank you Ben.
I tried, but unfortunately a "small" problem came up. I managed to take new blue subs but after integration the stars were just a little bit smaller. Actually this was the first time I took RGB subs with my little scope and the reducer: this was mainly my "large emmision nebula setup". Looks to me that I ran into the classic blue bloat problem: I use Baader filters and the blue cuts off somwhere at ~380nm. That's probably to much (or less...) for my scope.
I'm not sure if I end this litte RGB experiment or try an other blue fliter. The Astronomik deep sky blue filter seems to fit better (cut of at ~420nm), but the filter is 1mm thick. This would change my backfocus because the Baaders are 2mm thick. Hmmm.
CS
Thomas
