ASi 071 pro darks
9 replies to this topic
#1 Christian-UAE
Christian-UAE
  • Loc: Abu Dhabi
Posted 11 March 2019 - 11:22 AM
Hello,
I have recieved a new ASI071 today and I am in the process to create my darl libarray.
Can you please let me know if this masterdark (40 x 60 sec, Gain 0, -5 degree Celsius, integrated in pixinsight) looks normal for this camera ? I do see patterns and banding and a lot of glow.  The darks I do with my ASI1600 are much more cleaner....
I would appreciate if a ASI071 owner could post a masterdark from his library to compare.
Thank you very much
Christian
#2 descott12
descott12
  • Loc: Charlotte, NC
Posted 11 March 2019 - 05:50 PM
I am pretty new to this stuff so this may be way off but that looks like a flat frame, not a dark...
#3 Christian-UAE
Christian-UAE
  • Loc: Abu Dhabi
Posted 11 March 2019 - 09:32 PM
Hi.
It's a heavy stretched Masterdark.
Regards
Christian
#4 John Miele
John Miele
  • Loc: North Alabama
Posted 12 March 2019 - 05:35 PM
Here is one from my ASI071 pro. This is a master dark consisting of 25x60 seconds. Taken at -5 deg.C at unity gain. Sorry I do not have any at zero gain.
The first image is the full field. The second image is a center crop. You can see my dark pixels in the center crop. I don't seem to have as much of the vertical banding but there is some there for sure. These are both very heavily stretched...John
#5 John Miele
John Miele
Posted 12 March 2019 - 05:36 PM
Now here is a center full scale crop...
And I'll add when you stretch this hard, I'm not sure it tells you much as so much weird junk seems to appear. The real test is do the darks work...do they help your images? My darks always help so I think they are doing their job.
Edited by John Miele, 12 March 2019 - 05:40 PM.
#6 Christian-UAE
Christian-UAE
  • Loc: Abu Dhabi
Posted 13 March 2019 - 09:22 PM
John.
Thank you very much for your reply. I will try my darks during processing and I will see how they will work.
Regards
Christian
#7 jgraham
jgraham
Posted 14 March 2019 - 10:59 AM
Pretty much standard fare for all of my cameras including my ASI071MC Pro. Darks do a great job cleaning things up. Any residual is usually from scrum flowing across the field.
#8 AhBok
AhBok
  • Loc: Lakeland, TN
Posted 14 March 2019 - 03:34 PM
Are you taking your darks during the day with just a plastic cover over the scope end? I find I must use the cover plus a thick black felt piece of material draped over that to prevent light leakage when taking darks in a lit room. I even cover the bottom of my newt and turn the lights off to get the best flats with my ASI071MC Pro. I mostly use unity gain and 120-300 sec exposures.
#9 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 14 March 2019 - 06:19 PM
You are seeing FPN, fixed pattern noise. DFPN, dark fixed patter noise in this case, to be exact. DFPN is THE reason we create master darks and calibrate with them in the first place. Without DFPN, there really is no need for a master dark...no DFPN means the dark is a perfectly flat offset, and if that were the case, removing the offset would simply require a subtraction.
Every camera has DFPN, to one degree or another. It's totally normal. In fact, if your master dark was not modeling this FPN accurately, then subtracting it from each light would be an ineffective means of correcting this pattern in the lights. So, what you are seeing is not only normal, but expected and desired.
#10 Christian-UAE
Christian-UAE
  • Loc: Abu Dhabi
Posted 15 March 2019 - 01:48 PM
Thank you all for your replies.
As soon as the much desired and needed rain and cloudy weather stops I will do some test images.
Regards
Christian
