Does your CEM60 sound like this?
27 replies to this topic
#1 Tom K
Tom K
  • Loc: Escondido, CA
Posted 15 March 2019 - 12:41 AM
I am curious as to whether this is how the drive is supposed to sound while tracking.  I am wrestling with getting my guiding down to the specs that others have acheived and am trying to reduce the variables.
The video is dark, well, because it was dark out!  :-)
https://youtu.be/3BqM2hXClTM
#2 mistateo
mistateo
  • Loc: San Diego, CA
Posted 15 March 2019 - 01:43 AM
Unfortunately no, that is not how they are supposed to sound.  How did you set the tension for the worm gear?
#3 gotak
gotak
  • Loc: Toronto, CA
Posted 15 March 2019 - 02:53 AM
They do make a fair bit of noise but you're sounds pretty loud and rythemic. What does the guide graph looks like? Sounds are hard to pin down. Graph easier.
#4 Skymind
Skymind
Posted 15 March 2019 - 07:03 AM
Check the zero position; if the mount can return to zero correctly, then the motor was running normal, no skip steps, otherwise the noise was from motor skip.
#5 Tom K
Tom K
Posted 15 March 2019 - 07:36 AM
Here is a look at the PHD Log Viewer RA analysis from the session where that sound was recorded.   I have worked on getting the mesh right for a while.  I have used advice from many here and in the OpenPHD Google group - tighten down to where I see stalling and then back off ~1/4 turn so that it fully engaged but does not cause a stall.
Oddly, I ran a PEMPRO session and showed nearly within spec PE although that graph looks nothing like the one that came with the mount.
Of course, I had set SGP to run unattended to start imaging after the moon went down and woke up to find that my PC had an "unexpected shutdown" (Event ID 6008) about a half an hour after I went to bed.....grrr...no subs taken.
The mount kept track of where it was and could go to it's park position just fine - which happens to be the zero position, so I don't think it is skipping.
I will send this over to the techs at Itron for review.  This mount is only about 6 weeks old.  Sadly, we have had about 5 weeks of clouds here so I am still in the learning curve here...
#6 HxPI
HxPI
  • Loc: Virginia Beach, VA
Posted 15 March 2019 - 08:27 AM
No that sound is not normal. Time to call iOptron!
#7 Tom K
Tom K
Posted 15 March 2019 - 08:48 AM
I have already emailed the youtube link - and a link to this thread.   They are super responsive so I hope to hear back soon.
#8 gotak
gotak
  • Loc: Toronto, CA
Posted 15 March 2019 - 12:10 PM
Is that guide graph comes with guiding in? If so either settings or something more is wrong
#9 Tom K
Tom K
Posted 15 March 2019 - 05:10 PM
That image is the RA analysis in PHDViewer that has the guiding corrections turned off.   My RMS for that run was in the 1.3 range.  I have gotten some a bit better than that, but you are right, something in wrong.  At one point last night it got down to about .6 - for about a minute, and then right back up.   My dec axis is pretty solid but there is something rotten in Denmark on the RA side.   Even though this mount is new, based on this sound that other owners say is unusual, I have a sense that this baby may be heading back to MA for a look - or a replacement.
Edited by Tom K, 15 March 2019 - 05:10 PM.
#10 Tom K
Tom K
Posted 15 March 2019 - 05:13 PM
Ioptron was prompt again and I am arranging to have it go back.   He asked what speed this was slewing at and I pointed out that this was not slewing - it was tracking at sidereal rate.
  • bosh60 likes this
#11 Tom K
Tom K
Posted 15 March 2019 - 07:52 PM
I gotta say that even though I am not super happy about having to send this mount in for service, I will say that Ioptron has been very responsive.  They sent me a shipping label today and say they will turn it around in a week.   I should be good to go easily by next new moon.
In my day job I am a GM at a water district and I have built and operated treatment plants with lots of complex equipment.   After a few decades of experience there is one thing I know for sure - all complicated gizmos will have issues at some point.   The measure of the company is not just if they make a great gizmo, but if they stand behind it and deal with issue proactively when (not if) they crop up.
In this case, I paid $2200 for a mount that will rival mounts that cost a lot more.   The risk I take by saving thousands on a mount is that it may need this sort of service.  In order to deliver it at that price they have to decrease tolerances here and there that when perfectly set up work fine, but if something goes awry it may need service.   The reputation for service that Ioptron owners have expressed on these forums was a big factor in my decision to buy the mount.   I am glad that my experience with their support thus far has matched the experience of others.
I am not an Ioptron fanboy, just relating my experience.
  • Skymind and OldManSky like this
#12 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 16 March 2019 - 11:01 AM
Sorry it has to go back, Tom, but if it results in performance that improves, it'll be worth it.
And yes...iOptron does great customer service.
Let me know if you want to drive up the hill and watch me work with the CEM25 while you waitshocked.gif waytogo.gif ...
#13 Tom K
Tom K
Posted 16 March 2019 - 01:03 PM
Now you are rubbing it in!  I may just pull out the AVX for a bit in case I don't have it back by next new moon....
#14 dsullivan
dsullivan
  • Loc: Brooklyn NY
Posted 25 March 2019 - 03:20 PM
Tom, I know I've caught up with you in other threads but just wanted to chime in here that my CEM60 makes the same noise, along with a separate strange noise when beginning/ending slewing at a variety of speeds.
I'm speaking with iOptron about sending it in for repair.
#15 Tom K
Tom K
Posted 25 March 2019 - 04:24 PM
It seems that our mounts suffer from the same affliction - mine made sounds similar to that as well.
#16 Tom K
Tom K
Posted 25 March 2019 - 07:24 PM
So Ioptron checked out the mount and they have indicated that the noise is normal.
Anyway, they had three people listen to the mount and compared it to a new one and an old one and they say that all sounded the same.  Well alright then - they must all sound like that.  He apparently did not turn up the volume when he listened to my video of the sound on youtube.
They measured by PE as being at 13 arc seconds with the gear alone being 6".   They said that it was obviously gear meshing or bearing that added the majority.   I have asked for clarification as to what that means.   they added that it could have been caused by temperature cycling or ship bumping whatever ship bumping means.   I presume that means damage in shipping but I have asked for clarification.
He added that they were able to make adjustments to get the full PE down to 8 without difficulty.  I have asked whether this was just them getting the gear meshing right or if they made other adjustments.   I am sure they all went home so I hope to get that cleared up tomorrow.
He indicated that the technician would take one more look at it tomorrow and then ship it back to me.   Of course, I will get it set up and run through PEMPRO as soon as I get it!
All in all, they were speedy in their work, so I can't complain too much.   If it will run at 8" peak to peak I will be a happy camper.
#17 mistateo
mistateo
Posted 25 March 2019 - 07:37 PM
Still find it odd that they claim this noise is normal.  I took an imaging class at mesa college and they had 5 of these CEM60s and NONE of them sounded like this.
#18 Tom K
Tom K
Posted 25 March 2019 - 07:47 PM
Hmmm - another user has a post about his CEM60 USB hub not working and posted a video with a sound that is pretty much identical to mine.   I can't quite figure out what would make a stepper sound like that with a cyclic noise of about half a second intervals.
I may have to report back to them your experiences.   If they can get this mount performing to specs I really don't care if it sounds like a garbage truck falling off the Empire State Building - although my neighbors might.
#19 gotak
gotak
  • Loc: Toronto, CA
Posted 25 March 2019 - 07:48 PM
Good news if it all shows up ok at your end. The experience of other people shows that sometimes the adjustments have a pretty big impact. At least on the ioptron stuff usually adjustments are easy to make.
#20 mistateo
mistateo
Posted 25 March 2019 - 07:50 PM
I agree the performance is more important than the noise.
#21 OldManSky
OldManSky
Posted 25 March 2019 - 07:52 PM
Good news on the 8" PE, if that holds when you get it back.
Not entirely sure about the "that sound is normal" diagnosis.
I guess we'll see when it gets back.
Fingers crossed, Tom!
#22 Tom K
Tom K
Posted 25 March 2019 - 09:02 PM
So John at Ioptron got back to me just now - at nearly 10PM his time which is appreciated.
To paraphrase his email, he said that the original versions of the CEM60 had a Pokemon type music that used to be played with the mount tracking - I never heard that one before.   He indicated that some customers have asked for it back!   Anyway, he indicated that the noise is not an issue.
They did make some adjustments to the mechanism related to get to the sweet spot of "bearing fitness to the worm".   He indicated that he does not give too detailed a description of the internal workings of the mount and how they make the adjustments to protect trade secrets.   Not sure what those are, but as I mentioned in Post 11 there must be something different that they are doing to deliver at this price/performance ratio.
He did indicate that the manner in which I adjusted the mesh was not the issue, which is a relief to me!
Now I just get to wait for it to return home in time for New Moon!
#23 gotak
gotak
  • Loc: Toronto, CA
Posted 25 March 2019 - 09:20 PM
He set his clock 1 week fast or something?
#24 Tom K
Tom K
Posted 02 April 2019 - 12:24 PM
So I just got the mount back today and will be giving it a go - clouds willing - over the next night or two.  They definitely did something to the mount as the curve is distinctly different than it was previously.   Whether it will perform better or not is anyone's guess at this point.   I am also not sure how much these curves vary across multiple measurements.
  • OldManSky likes this
#25 Tom K
Tom K
Posted 13 April 2019 - 01:44 AM
In case any of you want an update, after getting the mount back and suffering through another round of cloudy skies (I blame Paul - a local CN friend - for getting a new cooled camera), I finally got to test the mount tonight.   I went through several runs of PEMPRO and never got a curve with a peak to peak over 8.2 arc seconds.  Five runs averaged about 7.3 peak to peak.   I will take that as considerable improvement!   I also think it was worth the $85 in shipping costs.
Also - the mount sounds exactly the same.   Same sound, but markedly better performance.  My hat is off to Ioptron support.
