Problems with Celestron Starsense Alignment device
3 replies to this topic
#1 PABresler
PABresler
  • Loc: Los Osos, Ca
Posted 15 March 2019 - 01:16 AM
I am having problems with the Celestron Starsense alignment device and my mount, a Celestron Advanced GT which I got used a few months ago. I added a two screw saddle to improve the security for the scope, but do not think that should have changed the alignment process. My scope is a Nexstar 8SE.
I polar align the mount using the polar finderscope, bring the mount to the home position, and do the Starsense autoalignment, which seems to work. I then attempt to calibrate the center using Polaris. Is out of the field by a few degrees. I go through the calibration, and then realign the mount, as instructed. When I again do goto to Polaris, it still is off by about the same amount as before the calibration. I tried this several times with the same result each time. I now am wondering if there is problem with the mount?
Peter
#2 echobeach
echobeach
  • Loc: Brisbane,Australia
Posted 15 March 2019 - 04:46 AM
Hi Peter, have you tried doing an alignment using the A-GT hand controller , then trying a few slews  then going back to Polaris ?. If it all works out well , take note of your backlash settings on your A-GT controller then compare the backlash settings on your Starsense  controller when you put it back on your C8. Also make sure your time and location inputs are as accurate as possible.
Cheers Martin
Edited by echobeach, 15 March 2019 - 04:52 AM.
#3 Noah4x4
Noah4x4
  • Loc: Colchester UK
Posted 15 March 2019 - 05:32 AM
A clue here might be in the statement '...mount........which I got used....".
Both Starsense HC and AVX mounts have had crucial firmware updates that have an impact on polar alignment. So, try updating your firmware before adjusting backlash or similar physical adjustments. We eventually proved (in TeamCelestron testing) that the Polar Alignment Error being reported by the Starsense HC differed from that of the Nexstar + HC. Hence that required a firmware fix around December 2017, which is, of course, just over a year ago. My guess is your scope might have missed this update.
This is also true for Alt-Az with wedge owners as there was a distinct StarSense All Star Polar Alignment (ASPA) 'bug' generally affecting control by the Starsense HC. A Starsense auto-alignment will work remarkably well even on a wonky mount. But what you really seek is an 'ASPA' where once polar aligned the mount will track in RA Only. I also don't believe that an ASPA has yet been implimented in any of the (WiFi) Tablet APPs, but there is one in the new CPWI software for Windows, which I am hoping to test as soon as the weather gets better.
If that doesn't work, retrace all of your steps as regards settings. Most Starsense problems are caused by an incorrect data setting, notably <Location> that after initial set up can only be adjusted via Menu. Check via HC Menu that this isn't at the default California setting. ...and remember that DST changes this month.
Edited by Noah4x4, 15 March 2019 - 05:40 AM.
#4 PABresler
PABresler
  • Loc: Los Osos, Ca
Posted 15 March 2019 - 11:05 AM
I will try both of the above. Thanks for the advice!
Peter
