A Rangefiner is awesome for testing resolution
2 replies to this topic
#1 MartinPond
MartinPond
Posted 15 March 2019 - 01:05 PM
(In the daytime, of course)
I took a chance on a "Yardage Pro"  rangefinder at the consignment shop
   ($14) and quickly replaced the battery that had a 2016 sell-by, so it wouldn't
    "juice out" out the battery compartment.  With new battery...shazam! Works great.
    I'ts a laser time-of-flight widget, so angles are no problem.
So it's easy now to place things like shampoo or Dorito ingredient lists at a
  solid spot and get the distance, then figure the "total acuity", scope+ep+me....
As an example:
From an 80mm x 400m scope, focal-extended to 80x,
a 1.2mm font can just be read at 39 meters   (39000 millimeters).
Optometrists say you need 5 line seperations per-height
to read a sans-serif font, so the resolution is at least 1.2/5 = 0.24 mm.
The angle for this is   arctan(0.24 / 39000)
or 3.526e-4 degrees,   or (times 3600) 1.27 arc-seconds.
    (I assume I could do slightly better, but it was starting to blur)
According to several books, the Airy disk is:
                                          "For an 80-mm refractor, 1.4 arc seconds."
So while the eye can likely see better than the Airy disk
   (likely due to the brain knowing letters, and cortex processing),
    the results are pretty close.
One thing I observed:
   ----there was very little chromatic aberration at 80x  (1mm exit pupil)
        for an 80mm F5
    ---the thing is,  an 80mm scope gets fairly dim at night past 80x anyway,
        and the atmosphere here can having seeing wobble of 2-6 arc-seconds
         fairly often.....
        I would need a bigger aperture AND a better sky to do more power...
      I do a fair amount of day observing as well, so the rangefinder will be
      valuable in looking at the ranges where the sometimes-brutal
     "horizontal seeing" kick in.   Over a mile, the slushing.can get to 30--70 arc-seconds!
Edited by MartinPond, 15 March 2019 - 01:10 PM.
  • Astrojensen, DuncanM and Mike G. like this
#2 gnowellsct
gnowellsct
Posted 16 March 2019 - 08:53 AM
for an 80mm F5
fairly often.....
In astronomical viewing many people assume that due to this or that limitation they won't be using a scope on planets. But when Jupiter is up off they go to have a look, and the wide fields end up taking a back seat.
One can say the seeing is bad, and I don't doubt you, but when the seeing is good, which DOES happen, you'll be the guy who forgot to bring his swim trunks to the beach party.
The range finder stuff is really interesting. But going to great lengths to verify your theoretical resolution contradicts your claim that you won't be using it!
Still, given the number of poor scopes that ship brand new, this is potentially a game changer in terms of helping us purchasers get reasonable quality control. Maybe we should all be running these tests, though ground thermals may compromise results.
GN
#3 MartinPond
MartinPond
Posted 16 March 2019 - 09:28 AM
In other threads, people mention that achromats can be very good or very bad.
As a practical matter, this is a way to see if the OTA I have salvaged from a crummy
starter tripod is worth putting on a nice bogen mount.
And.....using the rangefinder means I don't have to go to "great lengths" at all...it's easy.
Plus....knowledge is control: Am I going to get something I really can't use?
I realize it doesn't matter if you have plenty of money..
Actually.....yes.
 You found the counterpoint to your prior point....stream of consciousness posting?
    That's OK by me!
It would be great to identify the duds and the gems at the low end,
  those scopes worthy of trashing the tripod they come with and remounting
   on a great tripod.    That is were I'm at.   Currently, many achromat scope barrels widely
   surpass the crappy jiggly moiunts they come with....but which?
I know this is "Road Warrior" stuff, but every other hobby ,  like ham radio or wood carving
    or guns or archery or whittling or model trains,  or even running or mountain biking,
    has a division of     "best you can do on a budget".   It's a challenge!
    There are achievements to reach for.
   Being able to evaluate your optics cheaply and reliably is key to that.
Notice how I used tiny print at 40 yards.....that's how worried I am about 'horizontal seeing'.
If someone uses an 80mm ED spotter at high expense across 400 yards, do they have
   any hope of being better than a 70x600 acchro?  So far, up on Holt Hill...the answer is: No.
