Updating SynScan firmware
2 replies to this topic
#1 Scott123
Scott123
  • Loc: Maine
Posted 15 March 2019 - 08:21 PM
I have a SynScan hand controller that came with my Orion Sirius EQ-G. I bought it used, and have't had a chance to set it up yet. I have put the mount on the tripod, attached the hand controller, powered it up, pretended to polar align, balanced my scope, etc.
Do I need to update the firmware? I can't remember the firmware version on the HC, I do know it can be updated.
Will this update the database of objects, too?
Does the mount have firmware that should be updated?
And, lastly, where can I find a firmware update cable? I tried making one, but the firmware update software couldn't see the controller. It could see the USB to RS-232 adapter.
Edited by Scott123, 15 March 2019 - 08:40 PM.
#2 Pauls72
Pauls72
  • Loc: LaPorte, IN USA
Posted 16 March 2019 - 08:53 AM
If it's working OK, you do not need to a firmware update.
The main purpose of a firmware update is to fix problems and add new features. You can find the latest F/W here.
http://skywatcher.co...oller-firmware/
Did you put your hand controller in update mode. Hold the 8 key down and plug the power cable into the bottom of the HC.
If you have a V3 or V4 HC connect the RS232 cable that came with the mount to the HC. If your PC has an RS232 port connect it to that, if not you need a USB to RS232 adapter with a FTDI chip set.
https://www.ebay.com...&frcectupt=true
The latest V5 HC have a USB port on the bottom of the HC and comes with a USB cable.
#3 Scott123
Scott123
  • Loc: Maine
Posted 16 March 2019 - 11:13 PM
Yes, I put the HC in update mode (I forgot to include that in my original post, sorry).
The HC is a V3. I'm probably the third owner, the seller didn't have the cable. As I said, I tried to make one, but it didn't work. I have the USB to RS-232 adapter (see last sentence in OP), my computer recognizes it, but the update software doesn't see the HC.
It sounds like I don't really need to update the firmware; I'll let it stay at the current version.
