What was I seeing last night/this morning?
observing
10 replies to this topic
#1 kyle528
kyle528
Posted Yesterday, 08:45 AM
So last night I set up all my AP gear and got it going and it was a very clear calm night so I got my little reflector out and was tinkering around with it, I’ve not been observing very long, and it’s an old hand me down scope so long story short I got frustrated and took a break for a while and just sat in a chair. It wasn’t long at all before I was noticing meteor after meteor zipping across the sky. Here’s where the question comes in. A few times, I noticed something moving, fairly dim, and slower than most meteors, and much faster than any plane I’ve watched. It would stay dim and then in the space of about 2 or 3 seconds, gradually become brighter, flash very bright for a split second (brighter than Venus) then gradually dim until I could no longer follow it. At first I though maybe a large satellite? Then I thought are satellites naked eye objects, and why the flash? It should be noted that I am not an experienced observer, so this may be painfully obvious.
Sent from my iPhone using Tapatalk
#2 Starman47
Starman47
  • Loc: Tennessee
Posted Yesterday, 08:53 AM
#3 earlyriser
earlyriser
  • Loc: Cincinnati
Posted Yesterday, 08:59 AM
Sounds like an Iridium satellite. They "flare" when their solar panels are at the right angle to reflect sunlight at the observer.
  • Spikey131 likes this
#4 Cfreerksen
Cfreerksen
  • Loc: Tooele, Ut
Posted Yesterday, 09:01 AM
Sound exactly like experiences I have had several times. It's a satellite.
Chris
#5 The Planetman
The Planetman
  • Loc: Western KY
Posted Yesterday, 09:05 AM
As earlyriser said, it sounds like an Iridium satellite.  You can use Heavens Above, a satellite identification/prediction site to confirm any suspected satellite.
On a separate note, I was just reading last night that the Iridium flares will be coming to an end as the group of satellites are now beginning to reenter the atmosphere; one by one......
  • bob kelly likes this
#6 jaraxx
jaraxx
I have had the experience and been told it's a satellite. Personally, and based on some old info from the USAF,  I think it's swamp gas...
  • Dynan likes this
#7 sg6
sg6
  • Loc: Norfolk, UK.
Posted Yesterday, 09:18 AM
Satellite, they are generally non-flashing but some do. A couple of sites list them but often they only list the bright ones. Probably impossible to catalogue everything that might flash, especially as the flash is often dependant on where the observer is at the time.
There is at this time also the geostationary satellites, normally they are not really apparent but at this time of year they can be visible. This is becasue of the earths tilt which at the equinox puts Sun-Earth-Geostationaries in a line. So at this time you can see reflections off of some of those, they would appear to move a bit strange as they would move against the sky but not with reference to a building or tree.
Problem is there are lot of satellites of one variety or another up there.
http://www.stuffin.space/
We are in the middle of the central ball, zoom out to get a better idea of everything.
#8 CharlesC
CharlesC
  • Loc: Atlanta, GA
Posted Yesterday, 10:14 AM
Its an iridium satellite also known as an "iridium flare" which are predicted for your location on heavens-above.com.
https://www.heavens-...ed&alt=0&tz=UCT
#9 *skyguy*
*skyguy*
  • Loc: Western New York
Posted Yesterday, 10:16 AM
Most likely it was a satellite. An Iridium satellite is usually cited as the "culprit", but many other satellites can also brighten and/or produce a "flash". Iridium satellites are in polar orbits ... north - south, south - north directions. If your object traveled in this this direction, then the likelihood of it being an Iridium is greatly increased. Any other direction would mean it's most likely some other satellite.
A more detailed description of this sighting .... location, time, path direction, nearby bright stars or constellation transits ... would help to pin-down its identity.
#10 MikeHC8
MikeHC8
Posted Yesterday, 10:24 AM
At about 430 approximately I was looking above at my zenith and also seen object moving slowly across the sky going from south to north.  It stayed at a steady brightness then just got dimmer and then gone.  I would estimate about from the time I spotted it, the travel was 40 degrees and it was gone.  Seeing was clear no clouds, city lights.  Location San Diego
Edited by MikeHC8, Yesterday, 10:25 AM.
#11 earlyriser
earlyriser
  • Loc: Cincinnati
Posted Yesterday, 10:33 AM
I think SkySafari can be set up to generate Iridium flare alerts as well.
Also tagged with one or more of these keywords: observing
