NexRemote Virtual Port Issue CGEM
2 replies to this topic
#1 chopper2585
chopper2585
  • Loc: Brooklyn
Posted 18 March 2019 - 09:39 AM
Hi all, I'm one step away from being able to control my mount completely remotely, but I'm getting held up with the NexRemote Virtual COM port. The NexRemote works as long as I do not select a virtual port, but if I do select one, it just crashes.  It happens in all compatibility modes, every time I try it.
My long-term hope is to remote into my home PC (done), trigger my scope's power outlet via wifi (done), then set the alignment on the PC without having to touch the controller (here's where I'm stuck). Then from there, control via SharpCap and Stellarium (done). The alignment step is missing because without the virtual COM port, Stellarium doesn't know the scope is aligned and thinks it's in some wacky position unless I set the alignment on the hand controller directly.
Has anyone else encountered this issue? Is there another work around to this virtual port method, ie newer model hand controller, etc? Or is there a fix for this?
Any help is greatly appreciated. Thanks!
#2 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 18 March 2019 - 11:06 AM
a) have you re installed NexRemote? It's not uncommon to have problems with the com port driver that get resolved by changing the order of the installation (just re installing NexRemote using the Win7 compatibility mode).
b) You can also consider the in progress software called CPWI from Celestron (among many features it has the initial alignment code as well as a virtual port capability). While there is a released version the appropriate version for your use is still in beta and only available from teamcelestron.com
  • chopper2585 likes this
#3 chopper2585
chopper2585
  • Loc: Brooklyn
Posted 18 March 2019 - 11:49 AM
This is great, thank you. I signed up at teamcelestron and will try the beta once I'm approved. I'll also try reinstalling and see if that has any effect. Thanks!
