Advice on lightweight mount replacement for Atlas and Sirius
mount Orion
5 replies to this topic
#1 vballrican
vballrican
  • Loc: Sarasota, Fl
Posted 18 March 2019 - 01:32 PM
Hello everyone, i need advice on a replacement mount for my ES 127ED plus ST80, Canon DSLR configuration.  I had them on an Atlas mount which is quite heavy... i also have a Sirius mount that i acquired as part of a purchase. What mount should i be looking at to replace both the Atlas and Sirius that is not as heavy and can hold my equipment weight that doesn't break my bank?  I do plan on going CCD in the future to alleviate the weight a little but it will be a while. Thanks.
#2 mistateo
mistateo
  • Loc: San Diego, CA
Posted 18 March 2019 - 01:38 PM
Well decent performance and lightweight means more expensive than decent performance and heavy.  You also didn't define the criteria for "break the bank."  I would look at the new iOptron CEM40.
  • Gary Z likes this
#3 scadvice
scadvice
  • Loc: Lodi, California
Posted 18 March 2019 - 01:39 PM
I would look at a iOptron CEM60 at 26 lbs. I bought mine from Astronomics.
IMO - The new CEM40 may be just a bit undersized if considering a 50% AP weight criteria and the prices I've see so far are not that much less than the CEM60. However, the new CEM40 is a all new mount so I could be wrong. It will be interesting to see them at NEAF in a few weeks.
Edited by scadvice, 18 March 2019 - 01:48 PM.
  • OldManSky likes this
#4 Gary Z
Gary Z
  • Loc: New Mexico
Posted 18 March 2019 - 02:06 PM
Have you considered a Losmandy GM811?  Here's Uncle Rod's Review of it....but the point is 27 lb mount head....
http://uncle-rods.bl...-gm811-for.html
Gary
#5 Hesiod
Hesiod
Posted 18 March 2019 - 02:32 PM
Ioptron mounts have a very good payload/weight ratio and are not hugely more expensive than Synta's.
Vixen Sphinxes could be another option: SX, SXD2 (I have this one, weighs 9kg and declares 15kg as optimum max load for AP. However it has a big fault: a non replaceable VIxen-type clapm to secure the load), SXP (it has been recently discontinued, so may find a deal somewhere. The head weighs a couple of kgs more than SXD2 but has more payload and can use Losmandy-type clamps).
I use mine with the stock tripod and the whole mount is under 15kg, plus CWs (1.9kg is enough for my most typical setup, around 7kg)
#6 vballrican
vballrican
  • Loc: Sarasota, Fl
Posted 17 April 2019 - 02:25 PM
Thank you for your suggestions.  I'll continue looking at the iOptron mounts... Losmandy are out of my range for now.
Also tagged with one or more of these keywords: mount, Orion
