Focal reducer for Galaxy Season
accessories astrophotography CMOS refractor
8 replies to this topic
#1 Dovakun
Dovakun
Posted 19 March 2019 - 11:21 AM
It is the beginning of Galaxy Season here in the northern hemisphere. To prepare I'm contemplating a change to the imaging rig. Right now I'm using a x.8 reducer on my ed102. Because galaxies tend to be on the smaller side during spring I'm thinking about removing it to get a bit more focal length. What are your thoughts? Should I leave the reducer in place for imaging galaxies or take it off?
#2 ebeygin
ebeygin
  • Loc: King City Ontario, Canada
Posted 19 March 2019 - 11:30 AM
You can, it all comes to personal preference. You'll get a little bit closer, but if you choose to frame your galaxy with a larger FOV, you will now get field curvature the further from the center you go. Also, your system will be a little slower, but you can counter that with longer exposure.
  • Dovakun likes this
#3 dhaval
dhaval
    Vendor
  • Loc: Round Rock, TX
Posted 19 March 2019 - 11:31 AM
There is never enough reach with respect to galaxies, IMHO. So, the 700mm something FL that you will have with the ed102 is still not going to cut it. As you go higher in FL, you obviously have the need for better mount and so on. I think it really will very quickly boil down to what mount you have, what image scale you're going to be imaging at, etc.
CS!
  • Stephen Kennedy likes this
#4 Eric Seavey
Eric Seavey
  • Loc: Irvine, California
Posted 19 March 2019 - 11:34 AM
What camera are you using?  I've done a fair amount of imaging of small galaxies, and many of them are similar in size.  You can use Stellarium, or telescopius.com to preview framing, and the option for cropping.
Edited by Eric Seavey, 19 March 2019 - 11:46 AM.
#5 Dovakun
Dovakun
Posted 19 March 2019 - 12:49 PM
I'm using an AVX mount and a zwo asi294mc pro. Obviously if I could afford to build a Galaxy Hunter rig id get a beefier mount and a scope with way more focal length like a Edgehd11, but my budget is not unlimited
#6 Eric Seavey
Eric Seavey
Posted 19 March 2019 - 08:05 PM
My friend has the AVX, and I would not use an EdgeHD11 on that mount.  Have you considered the Explore Scientific Comet Hunter?  Your camera is super sensitive and has a decent sensor size, so you may be able to use a 2x barlow to get about 1500mm focal length and f/10, yet have good correction for wider fields without a barlow.
#7 Stelios
Stelios
  • Loc: West Hills, CA
Posted 19 March 2019 - 08:41 PM
Just take off the reducer. If you are imaging a galaxy pair or the Leo Triplet you may want to use a regular flattener (not a reducer) so the edge of the field stars don't require a crop.
If the AVX could handle the 570mm F/L (with reducer) it can handle 714mm. And the increase in object size will be welcome.
I would strongly recommend *against* a barlow, it will be far harder to guide an AVX at 1400mm and you will need to multiply the integration time imaging at F/14.
I have imaged galaxies with the slightly longer 805mm and they are not that bad. Here's the really tiny (look it up) Stephan's quintet (less than 10% crop from a larger image):
and M106:
  • DaveB and tomwall like this
#8 Dovakun
Dovakun
Posted 19 March 2019 - 08:47 PM
I definitely would get at least an Atlas mount for a larger scope. The primary reason for my original question is about optimizing my current setup so I don't have to build a new rig. The question comes down to should I sacrifice the scope sensitivity for FL? I'm leaning towards removing the focal reducer and just increasing my exposure time. Hopefully next year I'll be able to afford an Atlas mount and a Edgehd11 or 14 then this question will become moot.
#9 Eric Seavey
Eric Seavey
Posted 20 March 2019 - 01:44 PM
Understood.  Then take the focal reducer off, and crop the frame if you have star distortion.
People do get decent DSO images with SCT but I would lean towards much faster scopes.  F/5 is the ratio I like; fast enough yet without the headaches of sensor tilt issues you sometimes get with fast scopes.  I use my SCT only for planets and bright planetary nebulae.
Also tagged with one or more of these keywords: accessories, astrophotography, CMOS, refractor
