PHD2 unable to calibrate (not enough movement)
2 replies to this topic
#1 raguramm
raguramm
Posted 19 March 2019 - 06:43 PM
Hey all, I've had a couple of nights now where my PHD2 guiding fails to calibrate because the star isn't moving enough on the RA axis. I've got my step size at 1200, which I thought would be enough, and I believe I've configured my settings correctly for my guidecam (QHY5L-ii mono) and guidescope (60mm Orion guidescope, 240mm f/4) with darks library. I don't think I'm calibrating on a hot pixel, since the star is moving a little as PHD2 pulses the mount, just (apparently) not enough.
I was calibrating on a star that's not very close to the celestial equator - could this be my issue? (Target is Bode's galaxy). If this is the case, do I have to swing my scope around and first calibrate on a random star close to the equator before returning to my target for guiding? Seems unwieldy.
I've attached my guide log in case anyone wants to take a look and help me out.
Attached File  PHD2_GuideLog_2019-03-16_220002.txt   9.15KB   8 downloads
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 19 March 2019 - 06:51 PM
You should post this here where the developers hand out.  Be sure to post all log files.
https://openphdguidi...g/getting-help/
https://groups.googl...pen-phd-guiding
Make sure you use the current Dev release.
https://openphdguidi...ment-snapshots/
#3 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 19 March 2019 - 07:17 PM
But yes, you have to calibrate on a star near the celestial equator, not too far to the horizon. Then slew to Bode's and pick a star to guide on.
