New "Weightless Mount" RST-135
164 replies to this topic
#1 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 20 March 2019 - 11:18 PM
We are proud to introduce our new product.
You can meet our new products at NEAF2019.
This mount uses a strain wave gear instead of a worm gear.
Both Equatorial and Alt-Az are possible.
It can carry 30lbs without using counterweight. But its weight is only 7.3 lbs!!
You can buy from local dealers from May.
The price will be around 3,895USD.
Thank you.
  • moshen, psandelle, OleCuss and 4 others like this
#2 jag32
jag32
Posted 20 March 2019 - 11:25 PM
Is this goto?
#3 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 20 March 2019 - 11:29 PM
Is this goto?
Yes it's "goto" mount.
Hand controller is included.
We also provide the ASCOM driver.
Edited by xuranus, 20 March 2019 - 11:34 PM.
#4 jag32
jag32
Posted 21 March 2019 - 12:08 AM
Can you post a photo of the hand controller? Thanks
#5 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 21 March 2019 - 12:11 AM
Here is photo. :)
#6 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 21 March 2019 - 12:22 AM
What tripod would you recommend for the head? Is there any adapter for any particular tripod?
Rgrds-Ross
#7 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 21 March 2019 - 12:30 AM
Rgrds-Ross
We recommend a carbon tripod, the LN-404C or RT90C.
Of course, gitzo 3-series and 5-series are also good.
The RST-135 includes an adapter for the camera tripod as standard.
We also sell "half pier" separately.
Thank you.
#8 deepanshu29
deepanshu29
Posted 21 March 2019 - 09:31 AM
What's the main difference between this and RST-150H?
#9 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 21 March 2019 - 07:23 PM
1.The main difference with the RST-150H is that the manufacturer of the strain wave gear has changed.
RST-150H uses Harmonic Drive System gear of Japan. HDS's strain wave gear is original and very expensive.
Several companies other than HDS have recently made a strain wave gear.
We purchased and tested many strain wave gears and finally found a good performance, reasonably priced gear.
The RST-135 uses strain wave gears from other companies in Japan rather than HDS.
2. The load capacity was slightly reduced from 33lbs to 30lbs.
3. RST-135 will have WiFi.
We decided to produce more mounts than before.
To lower the price, buy a large quantity of motors and gears at once.
Thank you.
Edited by xuranus, 21 March 2019 - 07:23 PM.
#10 happycamperjohn
happycamperjohn
Posted 21 March 2019 - 09:33 PM
Will SkySafari on my iphone connect directly to this mount via the mount's WiFi?
John
#11 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 21 March 2019 - 10:00 PM
John
I am talking with the SkySafari team now.
I will provide our mount protocol to the SkySafari team.
We expect to be able to control the RST-135 in SkySafari soon.
I am also talking with the ZWO team for ASIAIR.
ByoungJun
  • BinoGuy and danielguo like this
#12 happycamperjohn
happycamperjohn
Posted 21 March 2019 - 11:17 PM
ByoungJun
Thanks ByoungJun,
If you could post here when you can confirm that skysafari is compatible, that would be great.
John
#13 Tamiji Homma
Tamiji Homma
  • Loc: California, USA
Posted 22 March 2019 - 08:36 AM
ByoungJun
I hope adding Wifi bridge to USB serial by Safari Wifi adapter or Nexus-II,  it  works for RST-150H as well.
Tammy
#14 happycamperjohn
happycamperjohn
Posted 22 March 2019 - 05:28 PM
Tammy, are you saying it works for RST-150H, or that you hope it works for RST-150H? (I think you mean "hope" - but just checking).
EDIT: Because It would solve my needs also for the serial port on the RST range to have the correct protocol to interface with a NEXUS-iI or Safari WiFi adaptor as well.
cheers
John
Edited by happycamperjohn, 23 March 2019 - 06:06 AM.
#15 tkottary
tkottary
  • Loc: San Jose,CA
Posted 22 March 2019 - 06:35 PM
Will this work  with INDI or Indigo ?
#16 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 25 March 2019 - 04:22 AM
We do not have an INDI driver yet.
But I will develop soon. I will let you know when the development is complete.
  • tkottary likes this
#17 tolgagumus
tolgagumus
    Vendor
  • Loc: NJ
Posted 25 March 2019 - 04:01 PM
The RST-135 will start shipping in May. It can be order through here.
https://www.tolgaast...ro-rst-135.html
  • xuranus and Gleason like this
#18 Gleason
Gleason
  • Loc: SF Bay Area
Posted 05 April 2019 - 12:25 PM
Will the RST-135 accept the QHY Polemaster like the RST-150?
#19 tolgagumus
tolgagumus
    Vendor
  • Loc: NJ
Posted 05 April 2019 - 01:05 PM
Yes it has a built in polemaster adapter
#20 RobertM
RobertM
Posted 06 April 2019 - 01:59 PM
I do like the idea of these harmonic drive mounts and have been following them for a number of years.  I like the size, weight and smooth drive but from a portability point of view how would the large centre of gravity shift, as the mount tracks around in RA, be countered ?  A big drawback of equatorial mounts is is that they are generally very large but are in balance so there aren’t any shifts in the centre of gravity.
Robert
#21 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 08 April 2019 - 05:31 AM
RST-135 at NEAF 2019
https://youtu.be/sAqgX2183T4
https://www.flickr.c...157690801709883
#22 Gleason
Gleason
  • Loc: SF Bay Area
Posted 08 April 2019 - 12:33 PM
It has a provision for adding a small counterweight bar and weight.  Does this change the load capacity?
#23 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 09 April 2019 - 11:32 PM
Using a counterweight of 3 kg will increase the load capacity to 18 kg.
#24 Traveler
Traveler
  • Loc: The Netherlands
Posted 11 April 2019 - 11:07 AM
Besides a reseller in Italy, do you have any plans to expand your reseller network in Western Europe (Germany, The Netherlands)?
#25 xuranus
xuranus
    RainbowAstro
  • Loc: South Korea
Posted 11 April 2019 - 06:09 PM
I am now discussing dealerships with shops in the Netherlands and Germany.
You will soon be able to meet our products in Western Europe.
Thanks.
