Where does your scope balance out?
3 replies to this topic
#1 Startex
Startex
  • Loc: Texas
Posted 21 March 2019 - 03:59 AM
Mine (Nexstar 8SE)mounts so that there's only about a half inch of dove tail past the back side of the arm. Seems like it's mounted way far forward but the spot the scope balances on is a little over 5 inches from the back of the scope. I mount that spot at the middle of the arm right at the index marks. This would be correct right?
#2 Fomalhaut
Fomalhaut
  • Loc: Switzerland
Posted 21 March 2019 - 04:31 AM
On a GEM, scope should be balanced very slightly "east-heavy" to fight possible looseness within worm-gear.
#3 Dynan
Dynan
  • Loc: NOLA
Posted 21 March 2019 - 06:10 AM
If you're talking about an original 8SE Alt/Az mount, you are correct.
#4 deansjc
deansjc
Posted 21 March 2019 - 10:25 AM
In case you didn't see this topic previously, you can search for "Back Heavy" vis a vis GoTo Approach in the Nexstar forum.
Since that discussion, I implemented a wedge design.  That means a second review of just "what balances where"....which remains to be done while I get proficient with the new alignment procedure :-)
'All the best!
