Illuminated reticle ep upgrade
6 replies to this topic
#1 John Fitzgerald
John Fitzgerald
    In Focus
  • Loc: ROR Obs. near Pettigrew, AR
Posted 21 March 2019 - 01:10 PM
I have an old University Optics Or 12.5mm illuminated reticle with corded battery holder and rheostat on the battery holder.  Has anyone on here ever upgraded one of these to cordless?  I wonder if the Agena cordless illuminator would work?  The cord is long and stiff, and an annoyance to use.
#2 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 21 March 2019 - 02:19 PM
My UO 12.5mm Ortho takes a ~14mm illuminator, whereas nearly all the current battery illuminators are around ~8mm diameter.  You'll need some sort of adapter to make up the difference in size.  Maybe you could find some rubber O-rings at the plumbing dept or similar to put over the Agena cordless?  A couple rings 1/8" thick and 5/16" ID would just about do it.
#3 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 21 March 2019 - 03:09 PM
for 30 bucks you can find several 12.5 mm illuminated reticle EP's on the bay.  this is basically what you would pay for a reticle by itself.  sure the EPs are not 7 element 100 degree but you are just using it for a finder. take it out after you have done your alignment. if you try using an adapter, the LED may end up being too far away to properly illuminate the reticle.
#4 msl615
msl615
  • Loc: Fairbanks, Alaska
Posted 21 March 2019 - 03:13 PM
There is a small company that makes metal adapters for different sized illiuminators for these eyepieces...I have one at home and will add that info to this post later tonight when I get home.
mike
#5 Kunama
Kunama
    Aussie at large
  • Loc: Garran, Australia
Posted 21 March 2019 - 04:11 PM
Just be aware that in many of those the reticle crosshairs are not in the centre of the view.  Even a more expensive TS one ended up in my rubbish bin when I noticed that the reticle was not centred.....
I now use a Baader Polaris1 reticle which is very good.
#6 John Fitzgerald
John Fitzgerald
    In Focus
Posted 21 March 2019 - 04:16 PM
Whether the crosshairs are centered does not matter for drift alignment, which is what i'm using it for, but mine is centered.  One of them I saw for sale has centering screws, btw.
Edit: For at least a stopgap measure, I shortened the 3.5 foot power cable to about 4 inches and spliced it inside the 2-AA battery box.  That way, I can either let the battery box hang, or velcro strap it to the focuser.  EP and box together are not as heavy as most 2 inch eyepieces.  The reason the power cable is so stiff is that the wires inside are solid, not stranded, copper.
Edited by John Fitzgerald, 21 March 2019 - 06:02 PM.
#7 macdonjh
macdonjh
Posted 22 March 2019 - 08:36 AM
To that point, can you disassemble the illuminator itself so you can change the whole power cable to a "fresh" stranded wire?  That kind of rewiring project is pretty simple, if you can get access to the connection points.
If you can do that, I'd suggest a hundred feet of 12ga wire, then you can leave your battery box in the closet and never have to move it again. smile.gif
