LX90 Drive Training OTA Angle
7 replies to this topic
#1 imk
imk
  • Loc: UK North West
Posted 22 March 2019 - 11:43 PM
Hello,
I am having a RA tracking issue and wondering is it is due to me training the drives with the OTA horizontal?.
I have a new audiostar hbx with firmware A4S1 and have been thru the setup/training/motor calibration three time now and still the same problem.
So i was reading the book again and it says "Use a terrestrial object such as telephone pole/lamp post" .which are generally upwards.
Well I used a tall factory chimney about a mile away that is in the valley hence my OTA was horizontal.
Should i have the OTA point upwards during Drive Training say at 45 deg?
Many thanks imk
#2 OzAndrewJ
OzAndrewJ
Posted 23 March 2019 - 12:08 AM
gday imk
For DEC training,you can use any OTA angle.
For RA training, the DEC tube should be as close to DEC/Alt = zero as you can ( ie 90deg to RA axle ).
Meade completely changed the way tracking gets done in the later firmwares
which is one of the reasons i suggest staying with A1F7 for the LX90s.
#3 imk
imk
Posted 23 March 2019 - 12:24 AM
Andrew,
Many thanks for the posts, it is couple of days before next clear sky here so will be then before i have new test results.
BTW is down or has moved? http://www.stargps.ca/downloads.htm
Thanks again for your help
#4 OzAndrewJ
OzAndrewJ
Posted 23 March 2019 - 01:36 AM
Gday imk
No idea re his site
I have emailed him to let him know, so will wait and see.
#5 Piet Le Roux
Piet Le Roux
  • Loc: Bloemfontein, South Africa
Posted 23 March 2019 - 02:02 AM
Hello,
Many thanks imk
Hi imk I take it that you have decided to upgrade to a wedge?
#6 imk
imk
Posted 23 March 2019 - 04:18 AM
Piet,
Yes I am considering a wedge, but have a strange RA tracking problem at this time, detail of which you can find in another thread.
As you will see i had/have an older flaky AutoStar hbx and from memory i think it RA tracked was better than this new AudioStar.
But last time i had a clear sky, i did not have presence of mind to re-test with the AutoStar and when i thought of it the skies clouded up.
Hence, plan is to get up at 0300 sunday morning to re-test with the old autostar and if tracking is better then it must be issue with way i have setup this new audiostar.
I have read much in several astro forum in past week and it seems like these meade hdx's have a few undocumented features that may have caused my audiostar not to RA track at all.
So when i have the basics all working as expected i'll go wedge shopping.
We await some stars, wish me luck imk :-)
#7 OzAndrewJ
OzAndrewJ
Posted 23 March 2019 - 04:45 AM
Gday imk
Just for info, there are 2 ways to track in polar and 2 ways in AltAz
ie In Polar, you can track using a std sidereal rate, or you can work out the now vs Now + 30second positions
and work out a tracking rate from that. ( ie a pseudo king rate calc )
For AltAz its the same, you can create differential equations to convert polar tracking
to equivalent Alt/Az rates, or use the now vs 30 seconds from now to come up with rates.
A1F7 in polar just uses a std tracking rate
The later firmwares use the delta Alt/Az rates, so can give different results, esp if they use the wrong motor commands to apply the speeds ( as the LX600s do )
All good fun
#8 Piet Le Roux
Piet Le Roux
Posted 23 March 2019 - 06:15 AM
To prevent confusion : When using Azimuth mode your two drives are the Azimuth and Altitude drives (Az/Alt) and in Polar mode with a wedge, your two drives are the Right ascension and Declination drives (Ra/Dec).
  • M57Guy likes this
