Quick capture
15 replies to this topic
#1 MAURITS
MAURITS
  • Loc: Belgium
Posted 24 March 2019 - 05:28 AM
Today I had small possibility to make a recording.
Before I had always used "SharpCap" as my recording software but today I used for the first time "FireCapture".
I like this software a lot but with these new layout I forgot to make a "flat frame"  blush.gif  and in the meantime it was back cloudy.
This is the quick capture from today 2019-03-24.
ASI 174MM - Quark Chromosphere - 0,5x reducer - 150mm refractor with D ERF.
Edited by MAURITS, 24 March 2019 - 06:54 AM.
  • gnowellsct, hopskipson, borish and 5 others like this
#2 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 24 March 2019 - 06:01 AM
  • MAURITS likes this
#3 rigel123
rigel123
  • Loc: SW Ohio
Posted 24 March 2019 - 06:12 AM
Love the processing!  You've managed to capture great detail while retaining that wonderful soft look of the churning plasma!
#4 MAURITS
MAURITS
  • Loc: Belgium
Posted 24 March 2019 - 06:52 AM
Thanks James and Warren for the nice comments.
#5 Spikey131
Spikey131
Posted 24 March 2019 - 07:02 AM
Thanks for posting.  I’m really enjoying your images.
#6 MalVeauX
MalVeauX
  • Loc: Florida
Posted 24 March 2019 - 07:18 AM
Lovely capture Maurits!
Very best,
#7 MAURITS
MAURITS
  • Loc: Belgium
Posted 24 March 2019 - 11:23 AM
Thanks Spikey131 and Marty.
  • MalVeauX likes this
#8 MAURITS
MAURITS
  • Loc: Belgium
Posted 26 March 2019 - 10:11 AM
I now have in the meantime also the Quark Prominence filter.
I couldn't resist this.
For the Quark Chromosphere I need the "minimum bandwith" for the best surface details.
I don't know if this is the same conclusion for the "Quark Prominence" to see the prominences on the edge of the sun ...?
Edited by MAURITS, 26 March 2019 - 10:12 AM.
#9 mikerepp
mikerepp
  • Loc: Harwood Heights, Illinois, dark site Manistique, Michigan in UP
Posted 26 March 2019 - 10:18 AM
That is outstanding, nicely done!
#10 MalVeauX
MalVeauX
  • Loc: Florida
Posted 26 March 2019 - 12:10 PM
If you run your Chromosphere model at a faster focal ratio, like F15~F20, you'll get the same effect (wider bandpass) as the Prominence Quark model.
Very best,
  • hopskipson likes this
#11 gnowellsct
gnowellsct
Posted 26 March 2019 - 12:13 PM
Very best,
Really?  All I have to do is swap out the 4x for the 2x?  I gotta check that one out.
#12 MalVeauX
MalVeauX
  • Loc: Florida
Posted 26 March 2019 - 03:26 PM
Yes,
The Quark's etalon's bandpass is sensitive to the focal-ratio of the telecentric beam going into it. Bandpass narrows as the focal-ratio gets longer, so F30 is a good starting point, but F40 is better, if you want narrow bandpass and high contrast. If you shorten the focal-ratio, so that less than a F30 beam is going through that etalon, bandpass widens significantly, the image is brighter, but you lose contrast on the surface significantly, but the wider bandpass that is brighter allows prominences to be brighter. Prominence Quarks are not special, they're really the "worse" quality etalon out of the batch that couldn't be sold as Chromosphere etalon models or better. You can simply drop down to F15~F20 and basically have a Prominence Quark. The bandpass will be a lot closer to 1A rather than 0.6~0.4A in a good copy of a Chromosphere model with an F30~F40+ beam.
Very best,
#13 sushi1128
sushi1128
Posted 26 March 2019 - 08:19 PM
awesome resolution ! Maurits
#14 MAURITS
MAURITS
  • Loc: Belgium
Posted 28 March 2019 - 04:33 PM
Thanks  Francisco.
#15 joshman
joshman
  • Loc: Brisbane, Australia
Posted 31 March 2019 - 05:12 AM
This is insane, such an ethereal image. Absolutely love it.
#16 MAURITS
MAURITS
  • Loc: Belgium
Posted 31 March 2019 - 02:57 PM
Thanks Josh man.
