SkyGuider Pro or StarAdventurer Pro?
beginner dslr equipment
1 reply to this topic
#1 waikee
waikee
Posted 25 March 2019 - 03:40 AM
Sorry for the dumb question, I am really new to astronomical and still learning
I‘ve had enough with the cg-3 w motor driver ,it is so inaccurate to track the star.
I hv done some searching in these two type of star tracker.
Since I need them to be portable and be able to carry my c90mak with a Canon 600D, Skyguider and StarAdventurer seems to be a solution for me. But what's the mainly difference between them?
#2 Hesiod
Hesiod
Posted 26 March 2019 - 01:39 PM
Absolutely none of them!
To take unguided pictures at 1250mm f.l. you need a bloody good mount, especially because it is a f/15 telescope.
Those devices are designed to take moderately short exposures at very low focals with very fast lenses: your f/15 is 5 stop slower than a f/2.8 lens, meaning that, to get the same amount of signal you would attain in the f/2.8 lens, have to get subs 2^5 longer...
To use the 90/1250 you would need a larger mount (at least eq3/cg4, but bigger is better) and the equipment to guide (manual, or, better, auto), but it is not a really good setup to begin with, and in general term not a good setup overall.
If want to start with AP, I'd suggest to use your camera with standard lenses instead (conventional approach), or stick with you have and try a sort of lucky-imaging with heaps of very short, high ISO, subs
Also tagged with one or more of these keywords: beginner, dslr, equipment
