recommended polarizing filter for visual use.
13 replies to this topic
#1 gnowellsct
gnowellsct
Posted 25 March 2019 - 02:40 PM
For some time now I've been using a polarizing filter on my quark.  This variable polarizing filter was purchased back around '02 from Orion for lunar and when rotate rightly enhances solar h-alpha surface detail (weakening prominences.)
The problem with this filter is that it doesn't screw into my eyepiece barrels very well.  I was wondering if anyone has any recommendations for polarizing filters for visual use.  I note that virtually all my other two inch eyepieces have accommodate my variety of two inch filters OK.  I think the issue here is the 2002 Orion threads.
I see there is a fancier Alpine-Astro Baader version of the variable polarizing filter.  But I was thinking maybe there is a one filter polarizing option that is not to bright and not to faint.  It seems to me that I use the one I have in one position, implying that a non-variable polarizing filter might do the trick, if I knew which one to get.
thanks
Greg N
Edited by gnowellsct, 25 March 2019 - 02:41 PM.
#2 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 25 March 2019 - 03:49 PM
A single polarizing filter, if made correctly, should be about the same brightness no matter who makes it, except circular polarizers which are designed primarily for cameras with CMOS/CCD sensors due to the problems using standard polarizing filters with their type of light meter sensors.
Anyway a variable polarizer is made up of 2 identical filters that you can rotate to change the amount of light that gets to your eye in this case. Other than the quality of the glass you can use any 2 of those filters from anyone and make a variable polarizer. They don't even have to be the same size so you could put one on the end of your diagonal if its threaded and one on your eyepiece or your 1.25" > 2" adapter if its threaded. Only thing that matters is what part you need to rotate in the rear to get the effect you want. Some people mistakenly think the filters need to stacked on top of each other. they are used that way in cameras because there is only one place to mount them on the end of the lens so those types are actually stacked in a single unit where only the outer one rotates.
In a telescope you have options on where to mount them depending on what parts have the correct threads in them. And many things that appear to have threads really don't as sometimes they are just mini baffles to combat stray light and sometimes they are the actual threads in the barrel that the lens retaining rings screw into. Not truly correct filter threads. Just depends on when they were made. Many things were initially made without filter threads at all and were added later as production of the item picked up.
  • gnowellsct likes this
#3 Stardust Dave
Stardust Dave
  • Loc: 39*N 122*.40' W
Posted 25 March 2019 - 04:16 PM
"I think the issue here is the 2002 Orion threads."
I'd had a similar issue with Orion filters 1 1/4" and 2" on my TV EP's
The Toya variable polarizing filter works very well both at the threads of a 2" EP and the threads of the diagonal.
These are made in Japan.
I use the Toya VP filter when observing Sun with the SCT in WL , helps tone down the brightness of the baader visual film and makes it easier to observe granulation of the photosphere.
Also like the Toya filter to observe the Moon before the sky gets fully dark, you can give a little twist the bottom of filter and the sky turns black and shows more contrast of Lunar features.
#4 gnowellsct
gnowellsct
Posted 25 March 2019 - 05:11 PM
This is all good to know.  I'm not getting any hits on Toya variable polarizing filter so it looks like Baader unless someone has a better idea?  Or a link?  Has anyone compared the Toya to the Baader?
I guess I'm also wondering whether Orion cheaped out on this filter or whether they're sort of impossible to get wrong.
Thanks photorcer and Dave.
Greg N
p.s. as a side note back in the early 00s Meade filters did not fit everyone else's oculars. I don't know if that is still true.
Edited by gnowellsct, 25 March 2019 - 05:11 PM.
#5 Stardust Dave
Stardust Dave
Posted 25 March 2019 - 07:43 PM
Sorry there , correction HOYA , not Toya!... My bad.
 I found a few in 52mm and a link for a 48mm but out of stock there.
This may NOT be the right one...https://www.ebay.com...TQAAOSwAThcGNdK
The listing says 48mm but product description indicates is 49mm. That would be a no- go. I'll keep looking .
another at https://www.ebay.com...CsAAOSwJt5bylIf
I picked up mine at the GSSP swap meet,  says PL on the side not CIR PL
Could be this one? ,https://www.ebay.com...hYAAOSwOupcdc3T
I do not know the difference between the CIR PL and the PL , hope any of that is some helpIMG_1222.JPG
Edited by Stardust Dave, 25 March 2019 - 08:03 PM.
#6 gnowellsct
gnowellsct
Posted 25 March 2019 - 08:06 PM
This guy says polarizing filters bite big time!
I guess I'll try to see what comes up at NEAF.  The issue of variable threads and what-is-that-on-ebay makes me lean to Baader as a proven entity, unless I can find an established vendor.
Greg N
  • rolo likes this
#7 rolo
rolo
  • Loc: GA
Posted 26 March 2019 - 11:35 PM
Maybe this one could work for you
https://www.ebay.com...JgAAOSw-V1cmk-T
#8 gnowellsct
gnowellsct
Posted 27 March 2019 - 12:16 AM
The price is....interesting, to the point of making one cautious.  It's like those svbony oculars.  There is such a thing as TOO inexpensive?
Greg N
#9 rolo
rolo
  • Loc: GA
Posted 27 March 2019 - 06:57 AM
See if get lucky with a want ad for one these...Also, some of the best filters are Heliopan & B&W
https://www.bhphotov...8mm_Filter.html
Edited by rolo, 27 March 2019 - 07:00 AM.
#10 gnowellsct
gnowellsct
Posted 27 March 2019 - 03:12 PM
thank you for the link.
I'm wondering about just getting a single polarizing filter.  Astro-physics sells them in 1" and 2" formats.  They say they must be used with a diagonal.
Couldn't one just screw it in to the quark etalon's threads and just rotate the etalon for optimal view?  There would be a diagonal in front.  They're not expensive as far as these things go.  I actually would prefer NOT to have a variable filter unless there is a compelling reason to do so.  What I have found is that there is one optimal position (for me) and I just wish I had a filter which went to that position.  The two inch could also be threaded on to a 1.25" to 2" adapter.
BPPOL125 1.25" Single Polarizing Filter. This filter is a single stage polarizing filter and must be used with a diagonal mirror, such as our MaxBright Diagonal
(PMDMAX), or the Hershel Prism (BPHERP) to achieve the polarizing affect.
$58
BPPOL2 2" Single Polarizing Filter This filter is a single stage polarizing filter and must be used with a diagonal mirror, such as our MaxBright Diagonal (PMDMAX),
$87
#11 BGazing
BGazing
  • Loc: Belgrade, Serbia
Posted 23 April 2019 - 01:58 AM
So, have you tried single polarizing filter? Astrojensen reported good results with it...
#12 gnowellsct
gnowellsct
Posted 01 May 2019 - 05:59 PM
I scored the filter shortly after NEAF.  It's a single 2" filter not a variable.  I have not had a chance to use it and am beginning to think I never will.
I didn't realize that I controlled the weather.  I suppose if I take all my astro stuff out in back and make a big bonfire and turn it into molten slag, we will have clear skies day and night.
Greg N
#13 Stardust Dave
Stardust Dave
Posted 01 May 2019 - 07:52 PM
Thanks OP for the idea , I got around to using my polarizing filter with my Daystar ATM .6
I'd had the mentality that stopped down to a 70mm ERF I would be short on light.
Never occurred to use on H -alpha solar -exception of WL.
Found a setting right away with the polarizer about 3/4 up its range that showed me H-alpha like I'd not seen before so easily on the disk.
Much easier to roam the recent bland chromosphere with the polarizer on. Of course , edge proms disappear almost entirely.  I pull out the polarizer if I am able to go 120X and upward.
30 years of Solar and I am just learning this?!
Sure we're mad at you about the weather , just don't burn you gear please.
Edited by Stardust Dave, 01 May 2019 - 07:53 PM.
#14 gnowellsct
gnowellsct
Posted 01 May 2019 - 10:57 PM
Yes it's a shame that you can't have disk detail and prominences at the same time.  Is your polarizing filter a "variable" model or is it a one lens system?
