Here is the latest version of the Nebula filters buyer's guide.
Many filters disappeared since the last version, but many more were added.
Posted 26 March 2019 - 07:17 PM
Thanks for doing this Don!
A filter I've been using the last couple years as a nebula filter is the Astronomik Blue deep sky imaging filter. It has a roughly 90nm bandwidth.
I typically use the filter on emission nebula at smaller exit pupils where broadband and narrowband filters are dimming the image too much, but I do see contrast enhancement with the filter at larger exit pupils as well.
Anyone with an imaging filter set can try the blue filter and see for themselves. Before I bought the Astronomik filters I had used an Orion imaging filter for the same purpose.
Posted 28 March 2019 - 01:01 AM
Nice guide Don. We are in the middle of a golden age for filters at the moment.
Posted 28 March 2019 - 01:47 AM
I'm with Jon. Thanks Don for this and all of your contributions to this community.
Posted 28 March 2019 - 05:41 AM
Great work! Thanks
bandwidth - main quality parameter - must be in separate column making possible to order by lines of the table
in "Type" O-III (one line) and O-III (both lines) could be separated from one another
Edited by Ernest_SPB, 28 March 2019 - 05:45 AM.
Posted 28 March 2019 - 07:00 AM
Posted 28 March 2019 - 08:53 AM
Great work! Thanks
Bandwidth, if the manufacturer even bothered to list it or show a chart, is in a separate column.
And, there are several different O-III filter types: 1 line (extremely narrow), 2 lines (narrow), 2 lines (wide), and 2 lines (wide) with red transmission.
I think the 1-line O-III filters are photographic filters, but Baader, Celestron, Thousand Oaks, and others sell them as visual filters.
No standardization.
Edited by Starman1, 28 March 2019 - 08:54 AM.
Posted 28 March 2019 - 09:07 AM
Thanks Don.
Posted 28 March 2019 - 09:26 AM
Thanks, Don!
Posted 28 March 2019 - 01:05 PM
Posted 06 April 2019 - 06:56 PM
Very nice THANKS for posting it.
Posted 13 April 2019 - 12:42 PM
This question is not specific to the visual nebula filters in Don's spreadsheet, but this is a question that arose in my mind when perusing listings of all types of narrowband filters.
What is the intended, or accepted, meaning of "bandwidth"? I note that the Baader 3.5nm Ultra Narrowband H-Alpha Filter listed here:
https://agenaastro.c...-1-2459451.html
is described as "Hbw (halfbandwidth): 3.5 Nm".
Is this the total width between the half-intensity transmission points? Half the total bandwidth by some other standard? When a filter is described as a "XXnm filter" does the meaning of the XX number have a nominally consistent meaning (whether or not it is actually followed)?
Posted 13 April 2019 - 01:51 PM
Yes, the bandwidth is often referred to as the FWHM bandwidth.
FWHM means "full width, half maximum", so it is the bandwidth at the point halfway between zero and maximum.
Now, that is the most relevant factor on a filter with a pure "square wave" response.
But if the curve of the filter has a Gaussian shape, the bandwidth could continue to widen as the response diminishes,
putting more energy in the OOB (out of band) wavelengths (just call it "noise" if you will).
Technically, however, a reduction of 100% transmission to 40% transmission (less than HBW) is only a dimming of 1 magnitude.
You can see response that is 1 magnitude down.
Filter coatings are applied in multi-layers, called "cavities". The more cavities added, the narrower the bandwidth, but if the bandwidth gets too narrow,
the maximum transmission goes down as well. I've see some great 3nm H-α filters that peaked at about 75% transmission. The narrow bandwidth was great for H-α contrast
but the low transmission meant a longer exposure.
For visual use, we want high transmission (over 90% means a loss of <0.1 magnitude), but we also want a square wave response and a narrow bandwidth.
That can be accomplished in filters, but not cheaply. More cavities = higher cost due to more materials used and lower production volume.
Tight bandwidth control also means a lot more rejects, lower volume, and higher costs.
If it costs $400k to make 4000 filters, and half of them get trashed, then the unit cost just doubled.
The processes are automated now, and the rejection rate is very low, but add the testing of each and every filter to the mix and suddenly the cost jumps again.
About the best achieved at the low consumer prices we see (not the $10k/each price you'd expect in aerospace) is a bandwidth with about a +/-2nm control
and a spread of about the same on the starting and ending wavelengths of the FWHM bandwidth. That's one of the many reasons a single line filter for visual use
might have a 10-12nm bandwidth. Add to that the shift that occurs as rays enter the filter more obliquely on short f/ratio scopes, and you're very lucky if the peak transmission falls around the spectral line the filter is designed to enhance.
Edited by Starman1, 13 April 2019 - 01:52 PM.
Posted 14 April 2019 - 10:16 AM
The meaning of the term "Hbw (halfbandwidth): 3.5 Nm" for the cited Baader filter is still confusing with that explanation, since it seems to explicitly say that it is NOT "full bandwidth". But I suppose it really means "half maximum bandwidth" since otherwise it would be a run-of-the-mill 7nm filter and not worth the extra cost for the product.
Posted 14 April 2019 - 11:01 AM
Yes, I think you're right. The error is in translation, I'm sure, and what they really meant was FWHM.
Don
Posted 20 December 2019 - 02:54 PM
This is a great list. I am buying my first Nebula filter for myself for Christmas. I am going to buy a 2 inch UHC for visual use only. I have an XT8 (8 inch Dob). I live in the suburbs of a bright city (Portland OR) so I do have semi significant light pollution at my house (Yellow / Orange range)....but will take the 30-60 min trips near by for the dark skies (green) areas throughout the year.
There are numerous threads (I have read through most of them), but seems difficult to narrow down the best choice of an UHC filter....especially given that filters can but updated with different light wavelength specs after maybe several of the posts. I think I pulled out of those threads that nearly unanimously it is the consensus that Lumicon Ultra High Contrast UHC Filter is the best one...but that is $200 for a 2 inch filter.
With that, I am looking at a budget of around $100 for a UHC 2 inch. The ones I seem to be finding most are listed below (with links).....
Ones I think I was able to rule out based on comments in the forums
So....is there a consensus of that the best UHC filter is with around a $100 budget?
Edited by Hobbes_Is_Real, 20 December 2019 - 03:05 PM.
Posted 20 December 2019 - 03:29 PM
Of the ones you mention, the Celestron UHC/LPR filter is a broadband, identical to the Baader UHC-S.
The DGM NPB is not in your price range.
Examining actual lab results here:
https://searchlight....d-153d7e7c0eb8#
and superimposing filter test results on top of one another, it looks like
the Orion Ultrablock is the only true narrowband among your choices.
The others are more like broadbands than they are like narrowbands.
If you can get the Orion for $100, I'd say go for it.
Posted 20 December 2019 - 04:34 PM
Thank you so much for the fast reply!!!!
One last question. When comparing the Orion for $99 vs just waiting a few months and getting the Lumicon Ultra High Contrast UHC Filter for $200..... is the difference really worth the extra $100? Especially since my next purchase I was planning budget wise is an O-III.
Edited by Hobbes_Is_Real, 20 December 2019 - 04:35 PM.
Posted 20 December 2019 - 11:12 PM
Then it's a matter of consistency. Orion is know for producing nebula filters that vary a bit in quality, mostly in terms of bandwidth, but also in terms of transmission percentages.
That being said, the narrower bandwidth will have a more effective enhancement for the nebulae.
If you go for a TeleVue or Astronomik or Lumicon filter you are guaranteed to getting a state of the art filter.You aren't guaranteed that with Orion, but you could get it.
Posted 22 December 2019 - 03:22 PM
Where is the line drawn between UHC & OIII filters?
Posted 22 December 2019 - 05:56 PM
A UHC narrowband filter transmits these lines in the spectrum:
H ß at 486.1nm
O-III at 495.9nm
O-III at 500.7nm
Typical bandwidths from 22-28nm
An O-III visual filter transmits:
no H ß
O-III at 495.9nm
O-III at 500.7nm
Typical bandwidths from 12-16nm
An O-III photographic filter transmits:
No H ß
No O-III at 495.9nm
O-III at 500.7nm
Typical bandwidths from 3-10nm
Edited by Starman1, 22 December 2019 - 05:58 PM.
Posted 04 January 2020 - 11:52 PM
Posted 18 March 2020 - 04:44 AM
Is there likely going to be a 2020 version of this Don? Have any new filters entered the market?
Owen
Posted 18 March 2020 - 11:47 AM
There will be a 2020 version.
I'm confined to my house, so writing and researching is something I have some time for.
I'm completing the 2020 Eyepiece Buyer's Guide first, however--hopefully done some time in the next month.
The Nebula filters guide will follow.
365 Astronomy in the UK now has their own filters. There may be more.
I haven't done the research yet.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
