For larger cities with numerous suburbs, especially with independent municipalities, color temps for installed LED systems are currently widely mixed.
The earliest color temps installed circa 2010 were either 6500° or 6000°K. These were implemented with mesopic-factoring. Many of these installations were so dim and the LED heads so poorly made that most of these have gone through further upgrades to warmer toned systems. The American Medical Association (AMA) report also came out in June of 2016, warning of the potential harm to people with the high blue light content in LED night-time lighting. In some regions converted to disproportionately blue 6500°K induction or LED systems, some residents complained that the lighting was either too harsh or discomforting. Due to such complaints and the AMA report, retrofit programs under contract started specifying a lower color temperature for LED.
The lighting industry, being virtually unregulated, has moved from dim, ~6000°K LED, to bright neutral toned 4200°K (or 4000°K) LED, to slightly inefficient 2700°K LED, which are actually pretty good for a phosphor-based systems, all in less than a decade.
In areas where conversions occurred by 2015, LED systems closer to a 4100°K color temperature were chosen. By 2018, 3000°K and even 2700°K were preferred, one reason being a greater awareness of the importance for foveal (central) vision compared to peripheral vision.
Currently established by experts is the notion that yellow light benefits foveal vision, while blue light benefits peripheral vision. Since forward vision seems more crucial in driving tasks, the latest consideration for street-lighting favors warm toned LEDs to be installed for adequate foveal vision.
By 2018, installed LED systems were unlikely to be near 6000°K, less likely to be at 4000°K, but a great deal likely to be closer to a 3000°K color temperature. In comparison, HPS lighting is near the 2100°K color scale and LPS/SOX are in the 1800°K range.
Because of these trends, many cities have ended up with a mix of CCTs. Example: color LED temperatures for both Brooklyn and Queens were at 4000°K which were completed by the end of 2016. Because of complaints about the new LED color in these boroughs and the general awareness of that 2016 AMA report, the contractor for The Bronx, Staten Island and Manhattan (all of which had the same contractor) was required to install luminaires in 3000°K starting in January of 2017.
Unfortunately, this is not necessarily true for commercial or industrial properties where highest profits can still be obtained by lighting companies when installing neutral and cool-toned LED systems. Photographed three years apart using exactly the same camera settings and equipment (as per EXIF data), the newly installed LED wall-packs appear a bit brighter than the soiled and under-serviced HPS wall-packs at the top. The change in color is quite contrasting, rising from about 2100°K to 5000°K. This is what's happening for the majority of private commercial and industrial property retrofits..(The wattages are known from the discarded LED packages which contained broken up parts of the old HPS lamps and fixtures)..
