Can Celeatron CPC 1100 tripod be modified to support CGX-L
Celestron equipment mount tripod
5 replies to this topic
#1 Shaz_st
Shaz_st
Posted 15 April 2019 - 03:06 PM
I am planning to buy Celestron CGX-L mount.
I live in UAE and shipping cost is very hight!
I do have a CPC 1100 and was wondering if I can modify the tripod to support new mount. Has anyone tried this already? Will it support the weight of CGX-L?
If I buy just the mount then I can save around 1000 USD.
Any help on this is highly appreciated.
Thank you.
#2 barbarosa
barbarosa
  • Loc: 139 miles W of the Awahnee Hotel
Posted 15 April 2019 - 04:00 PM
https://s3.amazonaws...ter-to-pier.pdf
https://www.cloudyni...ipod/?p=5789150
  • Shaz_st likes this
#3 Shaz_st
Shaz_st
Posted 15 April 2019 - 06:03 PM
Thank you these links are really helpful, now I hope cpc 1100 tripod is strong enough to support all the weight?
#4 barbarosa
barbarosa
Posted 16 April 2019 - 01:27 PM
I asked our laboratory staff for an opionion. Here are the pertinent notes.
  1. The standard CPC1100 OTA+mount weights 65 pounds/ 30Kg.
  2. Tripod tested with legs extended 9" and locked to one standard me torque.
  3. Static load of 1 standard me +20lbs on an extended one standard me arm.
  4. Tripod appeared stable with no obvious bending, shaking, or unsteadiness.
#5 Shaz_st
Shaz_st
Posted 16 April 2019 - 05:05 PM
Thank you :)
I think one could use a cap style disk brake, trim it to the right size and drill the holes. It might work?
#6 barbarosa
barbarosa
Posted 17 April 2019 - 03:03 PM
I don't see why not.
The only thing that would give me pause is the difference between the two tripods in terms of leg diameter and total weight.
69.85mm - 21 kg vs 50.8mm - 8.6 kg)
My CEM 60 is on a pier so i can't say whether this would be a significant concern or only a possible issue if the tripod legs are extended.
Good luck and if it works come back a post a photo.
Also tagged with one or more of these keywords: Celestron, equipment, mount, tripod
