An Awesome Opportunity To Help Lowell Observatory!
5 replies to this topic
#1 Astronomics
Astronomics
    Vendor: Astronomics
  • Loc: Right Here
Posted 16 April 2019 - 09:00 AM
Lowell Observatory in Flagstaff Arizona, a non-profit astronomical and educational institute is building a new $4M public outreach observatory that will house six permanently mounted telescopes, a classroom and a telescope storage and workshop area.
Construction is well underway and we have a planned grand opening date of September 14, 2019.
Here is an architectural rendering of the roll-off building observatory in its “open” position:
There will be multiple educational displays around the exterior of the observatory. We want to use six descriptive plaques that will be approx. 16” x 16” that will provide the basic information for each of the telescopes and a typical view through 4 of them as two will be EAA scopes.
Here is a very quick mockup of what we are doing (please ignore the fact that the object viewed does not match the telescope described, but you get the idea):
We are soliciting sketches to be used on the four panels for the visual telescopes from Cloudy Nights members. We are hoping to have artists donate their images, but we can also discuss compensation if you do this work professionally. We are under a bit of a time crunch, so we’d like to have these in our hands within about a month. If you have something in the same object class as what we’ve requested below, we are open to substitutions of object, but not telescope size used for the observation.
This is what we are looking for:
• For the 32-inch f/3 StarStructure - Globular cluster (M13) at core resolving power from a 28-32” class telescope.
• For the 8-inch f/12 Moonraker - Jupiter and Galilean moons at 200-300x from an 8” class telescope using an eyepiece with an AFOV of 76-92°.
• For the 16-inch f/10 Meade ACF SCT - Ring nebula at 200-300x from a 15-18” telescope using an eyepiece with an AFOV of 76-92°.
• 5.5-inch f/7 TEC - Pleiades – We already have acquired the sketch for this one.
Please PM Jim Cole (CN tag: rockethead26) thru CN messaging if you have something that you think might fit our needs.
Thanks and the CN community has been a great help to me over the last couple of years in the selection of the telescopes, mounts and eyepieces being used. A special thanks to Mike at Astronomics and the CN admin team.
  • nicknacknock, petert913, Susan H and 1 other like this
#2 rockethead26
rockethead26
  • Loc: Northern Arizona, USA
Posted 17 April 2019 - 02:36 PM
UPDATE:
We have received an outstanding sketch of the Ring Nebula thru a 16" telescope, so we are no longer seeking that one.
We found a technical error on the Pleiades sketch that we wanted to use, so that one is being re-opened.
Here's the current list of sketches that we need:
• For the 8-inch f/12 Moonraker - Jupiter and Galilean moons at 200-300x from an 8” class (6-10") telescope using an eyepiece with an AFOV of 76-92°.
• For the 5.5-inch f/7 TEC - Pleiades – a view that fits brightest recognizable stars of the cluster into about a 3° field of view. This could be thru a 4-6" telescope using an eyepiece with an AFOV of 80-120°. Should be a refractor view without diffraction spikes on the bright stars.
Thanks, everyone.
By the way, all sketches will be credited to the artist on the plaque.
#3 rockethead26
rockethead26
Posted 18 April 2019 - 08:18 AM
Come on folks, don't be shy!
For the 8" Moonraker a Moon skectch will be acceptable as well at 200-300x from an 8” class (6-10") telescope using an eyepiece with an AFOV of 76-92°.
Thanks all!!!!
Edited by rockethead26, 18 April 2019 - 04:20 PM.
#4 rockethead26
rockethead26
Posted 24 April 2019 - 03:32 PM
Along with our Ring Nebula sketch for the Meade 16" we now have a beautiful Lunar sketch that will be used for the 8" Moonraker. Thanks to the artists.
We are now still looking for:
For the 32-inch f/3 StarStructure - Globular cluster (M13) at core resolving power from a 28-32” class telescope. Any other resolvable globular cluster or any impressive galaxies like M51 will work just fine, too. If you have a subject that's completely different that you think will work, let me know.
For the 5.5-inch f/7 TEC - Pleiades – a view that fits brightest recognizable stars of the cluster into about a 3° field of view. This could be thru a 4-6" telescope using an eyepiece with an AFOV of 80-120°. Should be a refractor view without diffraction spikes on the bright stars. Another bright cluster would work as well.
Thank for helping us out!
#5 rockethead26
rockethead26
Posted 24 April 2019 - 06:39 PM
UPDATE: I now have a sketch for the 32". The same artist did M5 and M51 thru a 28" so we will decide between the two.
I still need the Pleiades thru a 4-6" class scope. Calling all sketchers....
#6 rockethead26
rockethead26
Posted 25 April 2019 - 06:00 PM
We now have all the sketches we need. Thanks everyone for your support.
The dedication of the observatory for donors and VIPs is on Sept 14th.
The grand opening for the general public will be on October 5th.
