How do I pause guiding in the middle of PPEC?
4 replies to this topic
#1 betelgeuse91
betelgeuse91
Posted 18 April 2019 - 11:18 AM
So I found that PPEC will begin again from scratch with a new target.
I want to pause guiding for checking the focusing while using PPEC, and resume when I am done.
Will stop guiding and resuming reset the PPEC? How should I do this properly..?
Thanks a lot!
#2 Stelios
Stelios
  • Loc: West Hills, CA
Posted 18 April 2019 - 11:53 AM
You don't say which mount you have, but in general the mount doesn't know guiding is taking place (think about it--if the guider is paused or the guider is issuing no corrections because tracking is perfect, how can the mount know the difference?).
What I think you are describing is that PPEC restarts after a slew. This does not affect whether you choose to guide or not. PPEC makes guiding generally easier and allows for longer exposures, but doesn't require, assume, or validate guiding.
Bottom line--stop guiding and restart when you want to. No worries.
#3 StephenW
StephenW
  • Loc: San Jose, CA
Posted 18 April 2019 - 12:21 PM
Do you mean the PPEC algorithm in PHD2 or PEC in your mount?
#4 betelgeuse91
betelgeuse91
Posted 18 April 2019 - 01:05 PM
My apologies. I did not make it clear there. I meant the PPEC algorithm for PHD2 for RA correction.
#5 StephenW
StephenW
  • Loc: San Jose, CA
Posted 19 April 2019 - 12:05 PM
As far as I know it is not affected by "pausing" guiding (e.g. when doing a dither), but it does need to be restarted if you "stop" guiding (e.g. when slewing to a new target)
You should probably post on the PHD2 forum to get a complete answer, and maybe request enabling a re-start feature...
I've often considered whether PHD2 could read and save the worm phase position (it's available via the ASCOM interface for many mounts) and could then re-apply it's PPEC across multiple nights.    For me though PPEC generally takes two worm cycles (~8 minutes of guiding) before "kicking in", so it's only a mild annoyance.
