Celestron #52306 Regal M2 100ED Spotting Scope caveats
refractor Celestron equipment eyepieces
6 replies to this topic
#1 Castor
Castor
Posted 19 April 2019 - 12:56 AM
I live in a suburban environment close to a natural reserve that hosts a good diversity of flora and fauna.  I have been into backyard Astronomy for many years but it is only until recently that I started doing terrestrial observing.  For that purpose a few months ago I purchased a Pentax PF-80ED-A spotting scope and I have been very pleased with its performance.  However, because of my daily routine I generally observe at dusk and at night when the small aperture of the 80mm scope becomes a severe limitation.  Fortunately I was able to adapt my smaller SCTs (6” and 8”) for doing terrestrial observing in low-light conditions with excellent results.  Alas, most of the year it is humid here and I can’t use my SCTs for terrestrial observing in bad weather!  For that reason a few days ago I purchased brand new a Celestron #52306 Regal M2 100ED spotting scope hoping that the additional 20mm of aperture (over my Pentax 80ED spotting scope) would allow me to continue to observe in rainy, low-light conditions as long as I can keep realistic expectations of what can be seen with this small aperture in those circumstances.
Here is a link to the product that I purchased:
https://www.amazon.c...g/dp/B00BQ52QS2
First caveat:
After using the new scope (Celestron Regal M2 100ED) for the first time while looking at various stationary terrestrial objects at night (in good weather), it became quite apparent to me that the scope is probably not using the full aperture to produce the images.  To confirm my perception, the next time I setup the Celestron Regal M2 100ED scope next to my Pentax PF-80ED and did a side-by-side comparison (at night, in good weather with the same stationary objects that have different levels of illumination) using their respective zoom eyepieces at the same magnifications and in most cases the images in both scopes were more alike than different, showing similar image brightness and resolution, with a slightly brighter image provided by the Celestron, but not what I would expect from a 20mm aperture gain –I can easily see the increase in image brightness when I compare my TV-85 next to my ED100SF and that’s only a 15mm difference!
So, if you are considering the Celestron Regal M2 100ED spotting scope for observing in low-light conditions, my first caveat would be that the scope may probably not be taking advantage of the full 100mm of aperture to produce the images.
See another user’s comments on the subject here:
https://www.cloudyni...work/?p=8089569
Second caveat:
Although the Celestron Regal M2 spotting scope line is supplied with a decent quality zoom eyepiece, one of its pros over other spotting scopes of similar cost is the ability to use 1.25” eyepieces designed for astronomical telescopes.  As an owner of two Pentax spotting scopes that have this feature I was looking forward to use my astro-eyepieces with the new scope to try to extract the best possible images.  Alas, the implementation of the eyepiece holding collar is quite different in both brands.  While with the Pentax scopes you only need to drop an eyepiece into the eyepiece holder and then gently turn a knurled ring to lock it, the Celestron Regal requires you to press with some force on the eyepiece to fully seat it into the holder (else it springs back up because of an o-ring placed inside the holder) while at the same time you need to do quite a few turns of the locking collar to secure the eyepiece –if you do not seat the eyepiece properly, it won’t come to focus.  On my Celestron Regal 100ED I need to press on the capped eyepiece top with my chin while I hold the scope body with one hand and turn the locking collar with the other.  After all the trouble doing a few eyepiece exchanges I decided to abandon my initial plan of using my favorite astro-eyepieces with the Celestron Regal M2 100ED and simply use the included zoom eyepiece.
So, if you are considering the Celestron Regal M2 100ED spotting scope for its ability to use 1.25” eyepieces for astronomical telescopes, my second caveat would be that the way that the eyepiece holder of this scope is designed makes it difficult for frequent eyepiece swapping.
Other options and conclusions:
Before I purchased my Celestron Regal M2 100ED I was aware of these caveats from two owner’s comments but somehow I was hoping that Celestron would have dealt with the issues by now.  Now I realize that I was probably too optimistic!  If money was no object, I would have purchased a Pentax PF-100ED spotting scope that most owners/users agree it is a very good scope and be done with it, but unfortunately it is beyond my reach for using it just as a recreational terrestrial scope and also it does not come in an angled version.  Even after these caveats, I see no other waterproof spotting scope options with ED glass for use in low-light conditions within my budget that would have been an improvement in light gathering capacity over the Celestron Regal M2 100ED, so I will probably stick with the scope and hope for the best!
I do not want to start a discussion about the merits of one type of telescope over the other (e.g. astronomical vs. spotting, catadioptric vs. refracting, etc.).  I just want to let prospective buyers know about the limitations of the scope model that I purchased so they can make a more informed buying decision, that’s all.
Here is a picture of my newly acquired Celestron Regal M2 100ED spotting scope.
  • m9x18, OleCuss and BFaucett like this
#2 Castor
Castor
Posted 19 April 2019 - 12:59 AM
(Continued)
Here is a close-up picture of the eyepiece locking collar of the Celestron Regal M2 100ED spotting scope and one comparing it to the knurled locking ring of the Pentax PF-80ED-A spotting scope, each using their respective brand of 8-24mm zoom eyepiece.
  • paulsky, m9x18 and Sirius Blue like this
#3 Castor
Castor
Posted 19 April 2019 - 01:02 AM
(Continued – last pictures)
Here are a couple of pictures of my new Celestron Regal M2 100ED next to my Pentax PF-80ED-A spotting scope for a size comparison.
Thanks for reading, I hope that it helps!
#4 Jon Isaacs
Posted 20 April 2019 - 05:06 AM
It is possible to test a scope to see if it is operating at full aperture.  Glenn LeDrew's flashlight test is simple and effective:
https://www.cloudyni...re-illustrated/
It is not uncommon for refractors to not operate at full aperture but with the different focal lengths of the two scopes and the relative insensitivity of the eye to changes in brightness, a test would be helpful.
There's a lot of optics in a spotting scope so the coatings are important in maximizing the throughput, they could be the issue.
  • m9x18 and Castor like this
#5 25585
25585
Posted 20 April 2019 - 07:23 AM
With some spotting scopes, focusing is by moving the internal prism. At certain distances, this can result in a vignetting or stopping-down effect, one or both happening.
#6 Castor
Castor
Posted 20 April 2019 - 12:36 PM
Hi Jon,
I’m not good at setting up and running tests, but I appreciate your reply and I thank you for the link to Glenn LeDrew’s excellent resource of the flashlight test!  The advertised focal lengths of the spotting scopes that I compared are very close indeed:  518mm for the Pentax PF-80ED-A and 540mm for Celestron Regal M2 100ED.
To quote the remarks linked on my initial post (and below) from the CN member (Eric.TB) who did the flashlight test on his Regal M2 100ED:  It should be noted that the Celestron Regal 100ED is not a true 100mm in aperture. My flashlight tests show the true aperture to be 90mm to 91mm with focus set to infinity. Futhermore, the type of prism system this scope uses, the closer in you rake the focus, the smaller the aperture shrinks. By the time you focus to a sharp star point, you're down to around 87mm in aperture”.
https://www.cloudynights.com/topic/590379-spotting-scopes-due-they-work/?p=8089569
According to the product’s advertising, Celestron employs XLT coatings with the Regal M2 100ED so I doubt it’s a transmission problem.  It’s more likely an issue with the internal prism system stopping down the aperture like CN member 25585 points out so well -Thank you for your comments!.  Per other user’s comments in the forums, vignetting is also present on this scope.
At any rate, as I commented on my first post, I found no other 100mm waterproof ED spotting scope alternatives available within my budget (topped out at about $900) that could have been an improvement over the light gathering capability of the Regal M2 100ED scope even with the stopped down aperture issue –if that turns out to be the case.  So I’m keeping the scope.  Besides, I prefer exposing the Celestron Regal M2 100ED to the elements and the tear and wear of daily use than my favored Pentax PF-80ED-A spotter with Japanese optics and finer mechanics that is a joy to use with its own SMC XL 8-24mm zoom or with XW eyepieces.
Best,
Edited by Castor, 20 April 2019 - 12:54 PM.
  • paulsky likes this
#7 btr209
btr209
Posted 23 March 2020 - 12:33 PM
Hello everyone,
I've owned this scope for a couple of months and can confirm what is written above.
I have run the flash test and the maximum diameter is indeed 90mm when the focus is set to infinity, and quicky diminishes when the wheel is turned the other way. This is annoying for a 100mm scope indeed.
The other caveat (eyepiece changing) is also true, there are very hard to insert if possible at all. For instance my Delos eyepieces won't fully go in due to their long barrels and even without trying to go all the way there is too much resistance right from the start. The Celestron X-cel LX fixed eyepieces on the over hand are a perfect match for this scope...Celestron have ensured that "standard" 1.25" is actually not fully standard...
That being said, the optical quality of this scope exceeds my expectations, it's first rate full stop. I hate zoom eyepieces but this one is as sharp as my X-Cel LX fixed eyepieces, only better eyerelief and wider AFOV give those the edge over the supplied zoom. The 12 and 9mm for instance are killers.
I did not except this level of optical quality, it's just a pity the aperture is stopped down to 90mm...
Edited by btr209, 23 March 2020 - 12:36 PM.
Also tagged with one or more of these keywords: refractor, Celestron, equipment, eyepieces
