I looked through my historical sessions with AZ-GTi in standalone mode (no computer, just SynScan. Using a DSLR with lenses ranging from 50 to 180 mm.)
About 20 sessions total.
Most of them showed noticeable star trailing.
Some of them produced nice results nonetheless.
Only one of them was perfectly aligned with no trailing and perfect centering on the object.
Yesterday I drove to a dark site and gave it another try.
-- 2 star alignment
-- polar alignment
-- clear alignments
-- 2 star alignment again
after this I shot for about one hour.
-> the target was about 2.5 degrees off with noticeable trailing.
Did another
-- 2 star alignment
-- polar alignment
-- clear alignments
shot for another hour.
-> the target was about 4 degrees off with horrible trailing.
Came back home.
Found and read SynScan manual - it actually recommends to do star alignment (2 stars, not 3!) - polar alignment - reset star alignment routine 3-4 times to be good.
Will give it a try.
Hi Yuri,
I complained about the same recently - https://www.cloudyni...unt/?p=11387330.
Not really complained - I was just a bit frustrated at the moment after fighting with the mount for a couple of hours.
I have quite a lot of experience with this mount but it often gives me problems when run without a computer but with SynScan.
I can see that you figured out the key points already:
-- mount/tripod need to be levelled
-- camera/lens need to be properly aligned with the mount axis. <-- this item is the main source of my problems.
If the above two items are good then the star alignment and polar alignment become easy and not bad.
On a good night I can shoot 60 sec exposures with a 180 mm lens without stars moving much. And the target pretty much in the center.
I usually align the mount with SynScan and then switch over to Sky Safari to find and aim to the target and start tracking.
Edited by maxsid, 10 October 2021 - 05:35 AM.
