battery for stored time, location, etc.
4 replies to this topic
#1 fullotto
fullotto
  • Loc: PA.
Posted 20 April 2019 - 04:30 PM
hello,
where is the small disk battery located that stores the time, location, etc. when the scope is turned off?
also, is it a 2032 battery and how do i go about replacing it?
sorry i forgot to add...this is an 10in lx200gps unit.
thank you!
Edited by fullotto, 20 April 2019 - 04:31 PM.
#2 OzAndrewJ
OzAndrewJ
Posted 20 April 2019 - 05:52 PM
Gday fullotto
There is no battery backup for date/time in the LX200s
The last date used is burnt to flash memory, but time is not.
The coin battery on the main board is only there to keep the GPS lump almanac alive.
#3 fullotto
fullotto
  • Loc: PA.
Posted 20 April 2019 - 06:39 PM
ok. but how do you replace it?
and yes i want to. the scope is used and i want to start it off from scratch.
thanks for your help!
Edited by fullotto, 20 April 2019 - 06:39 PM.
#4 OzAndrewJ
OzAndrewJ
Posted 20 April 2019 - 08:08 PM
Gday fullotto
Remove the base plate on the scope and it is on the back of the main PCB
It is a bit tricky to get for removal, but i just use a flat wooden stick to gently push it out
without damaging the spring.
Putting the new one in is very easy after that.
#5 fullotto
fullotto
  • Loc: PA.
Posted 20 April 2019 - 08:52 PM
ok thank you very much. no way to get it from taking out the front panel though?
