Manual stacking in Pixinsight quick guide instructions
9 replies to this topic
#1 Becomart
Becomart
Posted 20 April 2019 - 04:59 PM
I’m one of those guys who continually forgets all the settings and switches in Pixinsight. This has proven particularly frustrating when pre-processing as it’s taken hours getting mono images ready for any kind of processing. I found it useful to write my own summary sheet and hopefully this will be useful to others. A credit to light vortex website on which this notes are based.
Pixinsight Quick Guide
Calibration and Stacking
Flats
Image calibration process - add files - tick master bias box and link to image - uncheck master dark (unless you are using one) - set output file and create a folder called flats_lum (or other relevant) - disable ‘optimize’ unless using a dark and ‘calibrate’ - apply global
Image intergration process - add files from calibration process - in image integration choose ‘average’ for combination - ‘multiplicative’ for normalization - ‘don’t care’ for weights - leave evaluate noise enabled - in rejection algorithm ‘percentile clipping’ - ‘equalize fluxes’ - tick ‘clip low/high pixels’ - apply global
Light Frames
Blink Process - Add files - click on ‘apply an automatic histogram transformation to all images’ and ‘compute autoSTF’ - look through images and lose any with poor focus or extreme light pollution
Image calibration process - add light frames - create output folder called lum_cal (or other relevant) - tick master bias and locate - tick master flat and locate - leave ‘calibrate’ and ‘optimize’ unchecked for all masters - apply global
Cosmetic Correction Process - Add files from calibrated folder created above - create output folder called lum_cal_cc (or other relevant) - leave master dark unchecked - click on ‘use auto detect’ - double click one frame and apply a stretch - create a preview of smaller area using alt and ‘n’ - click real time preview - use sliders (default of 3 usually works fine) - apply global
Subframe Selector - add files - click ‘measure’ - eccentricity should be around 0.60 for good subs, FWHM values=the lower the better - SNRweight=the higher the better - you can sort by ascending to make it easier to see - open best exposure  and check for artefacts or satellite trials as this will be the reference image
Star Alignment Process - Add files from the lum_cal_cc (or other relevant) folder - choose appropriate reference image from subframe selector - set output directory and create folder called ‘lum_staralignment’ (or other) - click ‘generate drizzle data’ - apply global
Local Normalisation Process - Add reference image from subframe selector - Add files from star alignment folder - set output files to same folder as star alignment saved files - leave scale set to ‘128’ - apply global
Image Integration Process -  Add files from the star alignment folder - Add the drizzle files from the same folder - Add the local normalization files from the same folder - select ‘average’ in combination - select ‘local normalization’ in ‘normalization’, select ‘noise evaluation’ in weights - click ‘evaluate noise’ - click ‘generate drizzle data’ - in rejection algorithm choose ‘linear fit clipping’ (or ‘winsorized sigma clipping for 10-20 frames) - select ‘local normalization’ in normalization - enable clip low/high pixels (uncheck ‘range’ options) - apply global - don’t need to save this if proceeding to the next step
Drizzle Integration Process - Add drizzle integration files in star alignment folder- Add the local normalization files from the star alignment process - apply global
  • Ballyhoo and 42itous1 like this
#2 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 20 April 2019 - 06:00 PM
I am still not quite sure about the star align tool.  If one calibrates then integrates, why would one need the star align?  seems like my images were stacked well without.
#3 Becomart
Becomart
Posted 20 April 2019 - 06:12 PM
Without star alignment, your images won’t be aligned to each other. Your subs might be very short and therefore you may not see a noticeable difference.
  • psandelle likes this
#4 fmeschia
fmeschia
  • Loc: Mountain View, CA
Posted 20 April 2019 - 06:18 PM
Also dithering is usually a good idea, which means alignment is a necessity.
Francesco
#5 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 20 April 2019 - 10:56 PM
Now that I think about this, I had some bizzare alignment issues on some instances. Maybe it was that [lack of]star align. THANKS!
#6 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 20 April 2019 - 10:57 PM
Flats
Light Frames
I think this post may be worthy of pinning.
#7 Stelios
Stelios
  • Loc: West Hills, CA
Posted 21 April 2019 - 01:32 AM
In addition to dithering and drift from imperfect PA, star align is also crucial to match images from different sessions. I tend to like to image my targets at high elevation, and image for at least 5-6 hours per target (more for NB). This means that I often have to image over multiple nights. For the Sculptor galaxy which rarely gets above 28 degrees here, I had to do four sessions.
DSS incidentally will automatically star align, which is probably why you think you don't need it.
#8 Stelios
Stelios
Posted 21 April 2019 - 01:41 AM
Incidentally, as always with PI, there's more than one way of doing things. Mine is very different. For example, I don't use Blink--SS will catch anything I would've noticed in Blink, and I take enough images that I don't need to worry about excluding images with satellites and airplanes, the software will take what it needs. I also don't drizzle as my image scale doesn't lend itself to it.
My sequence is:
Original directory => Subframe Selector => "Selected" directory
"Selected" directory + Flats/Bias/Dark masters => Image calibration => "Calibrated" directory
"Calibrated" directory => Cosmetic Correction => "Corrected" directory
"Corrected" directory => Star align => "Aligned" Directory
"Aligned" Directory => Image Integration => Masters by filter
Masters by Filter => Dynamic Crop => Cropped masters
... rest follows (ABE/DBE, Deconvolution, Denoise, Delinearization, etc, etc, etc.)
#9 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 21 April 2019 - 02:36 AM
However I have processed images from PI where I went from, I believe it was the script, batch-preprocessing, then to the process, image integration, and the images all appear stacked. But I tried on other occasions and my final image was outtta whack. I want to get all my processing done within PI and not use DSS, just for uniformity sake. So I better integrate the star align tool.
#10 Stelios
Stelios
Posted 21 April 2019 - 12:55 PM
If you use BPP, I believe it does SA. I don't use BPP.
  • 42itous1 likes this
