T-Adapter for Nikon D5600
2 replies to this topic
#1 Shane1200
Shane1200
Posted 23 April 2019 - 10:56 PM
I'm trying to find a t-adapter that will accept ES 82 1.25 eyepieces. Any suggestions for brands or models numbers?   I've looked at a few that give the diameter  of the eyepieces on different vendors websites and my ES eyepieces are to large.
#2 KLWalsh
KLWalsh
  • Loc: North Georgia, USA
Posted 27 April 2019 - 08:10 AM
Is there a threaded area under the rubber eyecap?
The Baader Hyperion eyepieces have threaded areas under the rubber caps that allow direct attachment (or attachment using a readily available threaded adapter) to most T2 and M48 camera adapters. Extension tubes can be added to increase the projection distance for EP Projection photography.
#3 Eddie_42
Eddie_42
  • Loc: Colorado Springs
Posted 28 April 2019 - 10:03 PM
Im confused. What configuration are you trying to tie an eyepiece with a T-adapter? Typical setup with the t ring is using the scope as a prime lens. Are you trying something afocal?
