NOW AVAILABLE- The new LS130 night and day telescope from Lunt Solar Systems
astrophotography imaging refractor solar equipment
1 reply to this topic
#1 LuntSolar
LuntSolar
    Vendor (Lunt Solar Systems)
Posted 14 May 2019 - 01:27 PM
Introducing the LS130THa F7 Triplet Solar Telescope from Lunt Solar Systems -The Perfect Telescope for Day or Night Viewing
The Lunt Solar Systems LS130THa is our first 100% Modular Designed, truly convertible telescope and is sure to impress astronomy beginners and expert viewers and imagers alike.
This newly designed triplet refractor replaces the Lunt Solar Systems LS152THa telescope, and allows the user to experience a complete travelling telescope, certain to fit all your astronomical viewing needs with its easily convertible modular design system - allowing you to experience not only day time viewing, but explore the night skies as well!
LS130THa_5-Day-and-Night-Telescope-1000-
The LS130THa is sure to delight with its increased resolution over smaller aperture telescopes, allowing for the viewer to delve into the fine details and surface phenomena of our ever changing Sun with its tried and true doppler tuning system. With its 130mm aperture allowing for higher magnification due to its increased resolution, the fine intricacies of the Sun will spring to life in your eyepiece or on your screen.
This convertible Module System is unlike any other - allowing for the end user to switch between configurations with ease! With a few twists of a screw, you can go from basking in the Sun’s surface views to viewing distant objects in the night sky. The Lunt Solar Systems LS130THa will give you the ability to take your telescope from Hydrogen Alpha, to Calcium K, to White Light, or standard night time viewing, simply and easily. Choose the accessories to match your requirements (with current options ranging from Calcium K to White Light), and interchange as directed into your OTA, you are ready to view!
Not only will you be able to enjoy the quality solar views you come to expect from any Lunt Solar Systems Telescope, the base Triplet Apochromat allows for fantastic night time use with virtually no chromatic aberration.
Ted-Dobosz_May-9-2015_Solar-Filament-Eru
Whether it’s day or night, the Lunt Solar Systems LS130THa telescope has you covered!
#2 LuntSolar
LuntSolar
Posted 14 May 2019 - 01:46 PM
You can trade in your current scope and upgrade to the LS130 with our Trade-Up Program
Also tagged with one or more of these keywords: astrophotography, imaging, refractor, solar, equipment
