Whirlpool Galaxy (M51) & neighbours in Hα/lrgb
11 replies to this topic
#1 carballada
carballada
Posted 16 May 2019 - 09:53 AM
One of the most common targets.
I use it every year to check my improvements on hardware and test my processing skills also.
It's only a process of 60% of the taken frames, only the best are used with close to 24 hours of final integration.
All data is from the current year, it not was an integration with frames with other equipment.
UPDATE May 17th, new balance colour process:
Whirlpool-Galaxy-M51-20190509-HaLRGB-v2-
here the original post image:
whirlpool-galaxy-m51-neighbours-in-h%CE%
All technical info of the capture at astrobin:
http://www.astrobin.com/404991
Edited by carballada, 17 May 2019 - 04:34 AM.
  • elmiko, WarmWeatherGuy, BenKolt and 9 others like this
#2 stargazer60
stargazer60
  • Loc: South Texas
Posted 16 May 2019 - 10:24 AM
Beautiful image, thank you for sharing it with us.
#3 tomlindquist
tomlindquist
Posted 16 May 2019 - 11:44 AM
Simply Awesome!
#4 carballada
carballada
Posted 16 May 2019 - 03:04 PM
A pleasure, thank you to comment!
#5 flt158
flt158
  • Loc: Dublin, Republic of Ireland
Posted 16 May 2019 - 03:21 PM
Sensational image from Spain!
Do you know how far from your northern horizon was M51 at the time?
Not to worry if you cannot find out.
I am only wondering.
Thank you, Carballada.
Aubrey.
#6 jhayes_tucson
jhayes_tucson
  • Loc: Bend, OR
Posted 16 May 2019 - 06:45 PM
Jose,
That's a beautiful image but the color balance doesn't look quite right.  On my screen, the core region has a greenish cast and the overall balance is too blue.
John
  • ezwheels likes this
#7 carballada
carballada
Posted 17 May 2019 - 04:20 AM
Jose,
John
Thank you John for your advice, you are completely right, to much blue!!
I reviewed my monitor colour calibration and I reprocessed all the colour balance in the image, resulting to this new version.
I hope you like it!
Edited by carballada, 17 May 2019 - 04:40 AM.
#8 carballada
carballada
Posted 17 May 2019 - 07:55 AM
Aubrey.
Not a problem at all.
Here you see the Astroplanner graphics (CET time), we are lucky at 42º :D
  • flt158 likes this
#9 jhayes_tucson
jhayes_tucson
  • Loc: Bend, OR
Posted 17 May 2019 - 10:06 AM
I hope you like it!
Jose,
That is definitely closer (and I do like it;) however, allow me to provide some thoughts on color balance.  Whenever I process an image, I stare at the screen for hours as I work through all the steps.  A lot of times I get through the color calibration process and it's common to arrive at a result that I really like.  At that point, I try to put the image aside and look at it again the next day.  I look at it during the daytime and at night.  Then I look at it on my iPad and (sometimes) my phone, but most important, I compare it to images that others have taken.  It's usually during that period that I realize that my eyeballs have been fooled and my colors are really "off."  I can't even begin to tell you how many times I actually start over again to see what went wrong and to try to figure out if there is anything I can do to produce a more "natural" appearance to the colors.  If you look at my images, you'll see that I tend to favor slightly more saturated colors but that doesn't matter--what matters is getting the color balance "right."  And...if you do the color calibration steps properly, your resulting image will often be pretty close--requiring only minor tweaks to get thing where you want them.
Take a look at the colors in this image:  https://www.astrobin...6599/F/?nc=user.  First you'll see that most of the stars in the field don't have a blue/violet hue.  You should also see that the yellows are more pure with tinges of orange in a few regions.  This is an example of what I look for after I've processed an image to make sure that my eyes didn't become a bit color blind while I worked through the processing.
At this point, I hope that you can see that your color balance still needs work.  I don't know how you are doing your color calibration but it should involve setting both the black balance and the white balance.  When you get it right, the correct colors should pop out fairly easily.   You've got some nice looking data and I think that if you keep working on it, it's a good data set for learning to better color calibrate your results.  Frankly, this is one of the harder things to get dialed in as you learn to process images...and I struggle with it all the time myself.
Good luck with it!
John
  • pfile likes this
#10 carballada
carballada
Posted 17 May 2019 - 10:54 AM
Jose,
Good luck with it!
John
Thank you a lot for all your detailed explanation. I appreciate that.
I will follow all your advises and I will process entirely all the data from the beginning of the process again.
I did mistakes on the rgb stretch, for this last version presented on the post only I changed the final balance for a fast evaluation.
Part of the problem it was a not really good monitor calibration used on the rgb stretch (and not check the balance results in other monitors), also I suffer (like many times) problems with the colour profiles on the final file and how are working on the different screens (like you I try to check on different platforms the final image) but it wasn't all the problem.
I think that my original rgb data is not totally good and of course I need to do a really good balance there (at the origin) and repeat all the other steps....
Really I like my lum data.. but I need to rework more all the process.
thank you again John
#11 Jim Thommes
Jim Thommes
  • Loc: San DiegoCA USA
Posted 20 May 2019 - 10:27 PM
Jose,
The Luminance detail and depth is outstanding. I like the outer halo that you brought out. I would say this color is close when comparing to the color data of DSS. As you and John are discussing, there is some tweaking in the core area you can work on, but in general,  I like the image very much.
#12 carballada
carballada
Posted 21 May 2019 - 01:08 PM
Jose,
Thank you Jim, thank you so much
Now I am reworking all the process. I will post the results soon.
