Skywatcher AZ-GTi - Useful Links and Accessories
24 replies to this topic
#1 davidparks
davidparks
  • Loc: Battle Creek, MI - USA
Posted 16 May 2019 - 11:06 AM
Skywatcher AZ-GTi – Useful Links and Accessories
Please feel free to add any additional useful links.
Skywatcher AZ-GTi – It is useful to check local and online dealers/vendors, I’ve seen them for $300
Skywatcher Motor Controller Firmware  – Loader program for Windows OS is available in a WiFi version.  AZGTi Firmware is available for AZ Mode Only Left Side Mounting, and AZ/EQ Dual Mode Right Side Mounting
Skywatcher AZ-GTi Mount Manual (PDF)
Skywatcher SynScan Hand Control and SynScan App Manual
Skywatcher Star Adventurer Latitude Base – This came with the top vixen dovetail bar which connects directly to the 3/8” hole on bottom of AZ-GTi
iOptron Alt-azimuth Adjustable Base – Does NOT come with a top vixen dovetail bar
Hercules Micro stage-Fine Adjustment Unit from AliExpress – Looks the same as iOptron, but comes with top vixen dovetail bar
Hercules Counterweight Shaft for AZ-GTi
Hercules 2KG 20MM Counterweight
Hercules 0.5KG 20MM Counterweight
Skywatcher  Star Adventurer Counter Weight Kit – needs Reducer Bushing to work with the M12 bolt size of the AZ-GTi
Edited by davidparks, 16 May 2019 - 11:07 AM.
  • Astrodave, rustynpp, beammeup and 14 others like this
#2 junomike
junomike
  • Loc: Ontario
Posted 16 May 2019 - 05:34 PM
ADM Replacement Saddles
  • jgreif, davidparks, mxcoppell and 1 other like this
#3 jgreif
jgreif
Posted 21 April 2020 - 10:51 AM
Great resources, guys.  Any idea what cable I would want to connect a guide camera to the AZ-GTI (which I've converted to equatorial with a Williams Optics wedge and a firmware update).  I suspect that it is one of these:  http://www.store.sho...products_eq.htm
Edited by jgreif, 21 April 2020 - 10:52 AM.
#4 RVee
RVee
Posted 03 September 2020 - 12:45 PM
For using the Az-Gti in Eq mode with the Sky Watcher latitude base, please confirm the correct bolt size (source) to replace the locking knob that comes with the base.  Thank you.
  • dahills1 likes this
#5 jgreif
jgreif
Posted 03 September 2020 - 01:04 PM
Hi.  Sorry, but not going to be able to help. I used the William Optic High Latitude Vixen style base mount with my AZ-GTI (https://williamoptic...tyle-base-mount), and don't remember having to make any additional adjustments/purchases.  I've since purchased a Rainbow Astro RST-135 as my grab and go mount, but I really liked the AZ-GTI and it served me well.
#6 RVee
RVee
Posted 03 September 2020 - 01:53 PM
Had to look that one up...quite the upgrade!
#7 jgreif
jgreif
Posted 03 September 2020 - 02:14 PM
I started out with the base from my Ioptron SkyGuider Pro, but it was just too "rickety" for the AZ-GTI, scope, cameras, computer, etc, and tracking.  The WO base is really well machined and solid and, I think, made a huge difference.  Really important (more so than with mounts that track in AZ and DEC planes) is that you are well polar aligned, and then my AZ-GTI with OAG (using this Lynx Astro cable: https://www.firstlig...gti-mounts.html) tracked very nicely, and produced subs between 2-5 minutes, depending mainly on sky conditions (and polar alignment).  I could only find that cable in the UK, but FLO had it in stock and shipping costs were reasonable.  Good luck.
#8 beammeup
beammeup
  • Loc: Straight of Gibraltar
Posted 03 September 2020 - 02:43 PM
I have found a cable from Aliexpress that might work, it's cheaper of course..😊
https://www.google.c...0610764393.html
#9 jgreif
jgreif
Posted 03 September 2020 - 02:58 PM
...and with the coupon, it's practically free!  Probably worth a try.  I can vouch for the Lynx cable -- well made and worked!  Only issue was that there was too much of it -- I coiled it up and hid it in a cable management sleeve.  One person on this thread took it apart and cut it down and put it back together -- way too much work for me!
#10 beammeup
beammeup
Posted 03 September 2020 - 03:08 PM
FLO now supply the cable in 3 different lengths (1m, 2m or 5m),  also on AliExpress 2 lengths available, 180cm or 500cm.
Edited by beammeup, 03 September 2020 - 03:09 PM.
#11 stelaras1
stelaras1
Posted 03 September 2020 - 03:35 PM
this worked for me :)
https://www.aliexpre...2978177186.html
#12 RVee
RVee
Posted 03 September 2020 - 03:51 PM
Interesting, I had not considered a direct PC connection to my yet-to-arrive az gti mount.  I think I'll give it a try.  Apparently the bolt I need for attaching the az-gti to the SW star adventure latitude wedge (to replace the knob that interferes with full RA movement) is an M8.
#13 beammeup
beammeup
Posted 03 September 2020 - 04:23 PM
Apparently some people have had problems getting phd2 guiding to work over WiFI.
Connecting by cable seems to work better.
I need the cable because I got stuck in the dreaded 3 blinking led mode whilst updating the firmware... Connecting by cable is the only way to reset the mount...
Edited by beammeup, 03 September 2020 - 04:26 PM.
#14 FredSoDak
FredSoDak
  • Loc: South Dakota
Posted 04 October 2020 - 08:45 AM
I have been using my AZ-GTi with a power source of DeWalt batteries through a 12v adapter.  The adapter itself puts out 14v at 2 amps.  It seems to be within the recommended range and operates well.  I do have another 120v AC to 15v 3 amp DC transformer that actually puts out 18v and the safety feature of the AZ-GTi cuts off the operation.  Does anyone know what the upper cutoff voltage is for the AZ-GTi?
Here is the adapter for the DeWalt batteries.  I am only using the low capacity batteries (that come included with many bundled sale purchases), that are used on my floodlights & not the high capacity batteries that are used on my power tools -- in case the "power drain" problem of some Amazon reviewers are actually true and not posted by DeWalt sales people.
https://www.amazon.c...0?ie=UTF8&psc=1
I will soon have this attached to the mount with a small counterweight with this 10" bolt.  Is this the correct thread size & pitch to order?
https://www.amazon.c...lv_ov_lig_dp_it
I am using the AZ-GTi with an ST120 that weighs 9.2 lbs with rings, etc. & without eyepieces.  I do not have the hand controller, using WiFi only; and after doing the 2 star alignment, the next 2 objects are close to centered -- but after centering them and telling the app the new center -- all other objects using GoTo are almost perfectly centered.  Love this little mount.
Edited by FredSoDak, 04 October 2020 - 08:47 AM.
#15 mchriste
mchriste
  • Loc: Switzerland
Posted 16 November 2020 - 09:02 AM
I have also been using a small 5V to 12V USB step-up adapter with my AZ-GTI. Doing so lets you power the mount with a standard USB power bank. Mine is a conveniently shaped 8000mAH that I velcroed into the mount's battery compartment. Powering the AZ-GTI barely makes a dent in it, it lasts for weeks and I don't have to worry about batteries dying on me.
I specifically use this converter (currently out of stock), but there are of course others out there. For example this one from Aliexpress looks like it would work too (triple-check first, I did NOT test this one!)
Edited by mchriste, 16 November 2020 - 09:02 AM.
  • gfstallin and FredSoDak like this
#16 ItsMeTony
ItsMeTony
  • Loc: Florida
Posted 08 December 2020 - 11:10 AM
Is there an adapter of sorts that will allow the AZ-GTI to attach to a vixen tripod?
Tony
#17 Cometeer
Cometeer
  • Loc: SF Bay Area, California
Posted 08 December 2020 - 06:36 PM
Tony
What sort of Vixen tripod? If it's one with a flat head (or if the polar alignment pin won't get in the way of the az-gti pier), you can take out the M12 bolt and put in a 3/8" bolt. I did that with the Vixen Porta tripod that I have.
  • ItsMeTony likes this
#18 toothdoc
toothdoc
Posted 04 February 2021 - 09:37 PM
The Hercules counterweight bar for the AZ-GTI in EQ mode has three weights at the end of the shaft.  I need the bar that is made in Japan and has the standard safety bolt at the end of the shaft.  It doesn't look like the Hercules shaft has the safety bolt.  Also I want a bar made of stainless steel not aluminum, heavy enough to balance a load without adding weights. A company in Japan called Eyeball has one on their website but the site is in Japanese.
#19 jgreif
jgreif
Posted 05 February 2021 - 10:50 AM
I use this configuration, described here (https://www.cloudyni...s/#entry9368587) by David Parks, with links to the sites for purchase: Skywatcher  Star Adventurer Counter Weight Kit – needs Reducer Bushing to work with the M12 bolt size of the AZ-GTI.
#20 opienc
opienc
Posted 14 February 2021 - 11:26 AM
adding to the list.
if using the skyadventurer latitude base, the declination knob will block the az-Gti and needs to be replaced.
i replaced it with a m8 bolt with handle.
https://www.amazon.c...13318508&sr=8-9
for the counter weight bar, i used a M12 threaded rod + 2 M12 nuts. 250mm is just a tad shorter than the sky adventurer counter weight kit.
https://www.amazon.c...2xpY2s9dHJ1ZQ==
M12 nuts
https://www.amazon.c...3319753&sr=8-10
Edited by opienc, 14 February 2021 - 11:54 AM.
  • eros312 and Juzwuz like this
#21 Gazpacho
Gazpacho
  • Loc: It's Vegas, Baby!
Posted 14 February 2021 - 07:00 PM
I posted this in other places, but I found this thread an thought it might be good to post here also.  Apologies to the Mods if this seems like spamming.
New AZ GTi Mount 3s
This is a 3D printed project I designed to reduce the weight suspended on the mount and to bring the OTA closer to the mount to reduce leverage "added" weight.  It replaces the dovetail saddle, the dovetail and the scope rings.  Total weight of all parts is 8.7 ounces.  A single GSO 90mm ring weighs 6.5 ounces so I would not be surprised if this modification saves up to a pound of weight.  I am a visual only user, so I cannot comment on its effectiveness for AP, but it appears to be solid.
This modification is for 90mm optical tubes.  If you need a different diameter, I can design one for you fairly quick, but I cannot test it for you.  I would welcome any recommendations for improving this adaptation.
  • Alex01 likes this
#22 TheChemican
TheChemican
Posted 27 April 2022 - 01:08 PM
So I know you posted this a while ago but did the ST120 work out on that mount? It looks like maybe you have a Celestron 102mm now. Is that because the ST120 was too heavy? Going to get the mount with either the 102mm or 127mm Mak and am thinking about what refractor I could pair with it for my wild field views.
#23 FredSoDak
FredSoDak
  • Loc: South Dakota
Posted 27 April 2022 - 07:37 PM
The ST120 was at the "edge" for weight, once I put on a 2lb counterweight.  The motor did strain when finalizing its target.  The motor was fine using manually & when moving in normal speed; it only groaned when it was close to centering the object.  My ST120 does have a different focuser, that is heavier than the original.
I am using the Celestron on that mount now; mainly because the lens are much better at getting clear images.  The weight of the 102mm is much lighter; and getting the image centered is more accurate.  I feel that the 102mm Celestron is a much better fit for this mount.
#24 Halfstar
Halfstar
  • Loc: Pipe Creek Texas
Posted 19 January 2023 - 03:41 PM
Has anyone replaced the Azimith screws on the GTI   they are so small they are a royal pain to rotate when its cold out.  If so where did you find them
Edited by Halfstar, 19 January 2023 - 05:21 PM.
#25 Mikhail Pavlichenko
Mikhail Pavlichenko
Posted 03 December 2024 - 03:04 AM
Hey all,
I just received a Star Adventurer Gti that I bought used from a friend in a different city. Unfortunately, I've received it with a broken Declination dovetail saddle and a bent left-side azimuth knob (this is shipping damage). For now, there doesn't seem to be any further damage to it than this.
I found a replacement saddle made by ADM which I was planning on replacing anyway, but I was wondering if I could replace the azimuth adjustment knob as well - does anybody know where I could buy a replacement knob? Also, does anybody happen to know what thickness and thread size it is so that I could just get any knob with the same threads and thickness so I can simply plug and play (I may not get a green colored knob, but the color is trivial to me).
It is currently raining at my location, and I am awaiting the rains to stop so I could try out guiding and tracking to ensure both axes are performing fine.
