Here are one of each of the files... Organized if any of you wanna take a stab) https://drive.google...?usp=drive_link
this is also in another thread I opened and someone asked, but since others are commenting here on this one too I figured I would add this here as well:
There is a doc in there that states why i put more 10s ones in. 10s was the sky flat I did yesterday, but it was kind of late, so it was hard to get more than 2 seconds without jumping to a longer one, BUT since it was so long at 10s per, as it went on, it's histogram started dropping as the daylight slowly went away. (but fast enough apparently) So I included the first frame and the last and 2 in between, but only one bias. I organized everything to be easy.
I also added a few different flats/bias. each matching of course, also separated by sky and panel, there are at least 3 of each.
If you are able to figure it out, that would be greatly appreciated. Here is also a link to the settings i had in WBPP in pixinsight... (https://imgur.com/a/3xAMZxE) . Ignore the master flats etc, as that was just there when I was done with one today (and it still didn't work) but for each of these runs, I deleted the masters and ran with the full count of the calibration frames. I also had drizzle on but that particular run I forgot to select it, but I did rerun it with it, and still no difference in the pattern. (here is the pattern... https://i.imgur.com/zmeGfiO.jpeg..., and it's almost always the same in all of those pics, with very little difference between all the different variations of flats etc. I also tended to purge the cache before each run as well.
