Buying a refractor
astrophotography beginner dslr equipment imaging optics dso accessories
7 replies to this topic
#1 astronomykiwi
astronomykiwi
Posted 19 May 2019 - 06:24 AM
SkyWatcher Evostar 72ED
#2 astronomykiwi
astronomykiwi
Posted 19 May 2019 - 06:26 AM
I am planning to buy a SkyWatcher Evostar 72ED in the near future, however, I have been told by many videos it has the focusing issue and needs a spacer, simple question, would it work just to use macro extension tubes to move the camera into focus or do I HAVE to invest in a pricey Focal reducer?
#3 dhaval
dhaval
    Vendor
  • Loc: Round Rock, TX
Posted 19 May 2019 - 06:41 AM
Almost all refractors will require extension tubes to come to focus using a camera. You don't "need" a focal reducer unless you truly want to image using a faster F/ratio. And even then, you may still need extension tubes.
Depending on the size of the camera sensor, you may want to invest in a flat fielder. This will ensure round stars edge to edge. You can also crop the image if you don't use a flat field device.
CS!
  • 2ghouls likes this
#4 astronomykiwi
astronomykiwi
Posted 19 May 2019 - 06:47 AM
CS!
Thanks! I use a apsc sized sensor in my canon 600D. people have had issues with round stars around the edges, I already own some macro extension tubes, 13mm 21mm and 31mm so I have many options, how much is usually a reasonably priced flattener? Sometimes stuff here in new zealand is highly overpriced! 😂
#5 dhaval
dhaval
    Vendor
Posted 19 May 2019 - 06:59 AM
The thing with flatteners is that unless they are specific to the scope, it makes it very difficult to find out which one will actually work.
I haven't used the scope that you are looking to buy, so I can't answer the question of which FF will work for you. Sorry.
CS!
#6 PirateMike
PirateMike
  • Loc: A Green Dot On A Blue Sea
Posted 19 May 2019 - 08:27 AM
You can contact SW to see what they suggest. I have heard that they are a friendly bunch and very willing to help their customers.
Miguel   8-)
#7 terry59
terry59
  • Loc: Colorado, USA
Posted 19 May 2019 - 09:03 AM
If a flat field with round stars is your objective then yes a flattener or reducer/flattener is needed. Since this scope has no matched flattener getting a perfectly flat field may not be possible. This review uses a William Optics flattener
https://astrophotons...GC_2024_Nebulae
#8 Stelios
Stelios
  • Loc: West Hills, CA
Posted 19 May 2019 - 11:28 AM
I can easily recommend the Hotech field flattener. And yes, you *will* need one, especially with a DSLR which has an APS-C sensor (or larger) (likely also with 4/3rds cameras such as the ASI294 and ASI1600).
Also tagged with one or more of these keywords: astrophotography, beginner, dslr, equipment, imaging, optics, dso, accessories
