What can this ronchigram tell about this mirror?
9 replies to this topic
#1 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 20 May 2019 - 01:56 AM
This ronchigram pic is on file for a mirror that I'm interested in know more about.  It is for a 23 inch f/4.74.  I've never been very knowledgeable about how to interpret such images.  I much prefer a foucault image or certainly a null image.  There appears to maybe be some microripple but can anything be determined about the figure itself from this pic or is more info needed?  Thanks.
#2 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 20 May 2019 - 02:28 AM
Inside focus?  Outside?  Lines per mm?
  • Augustus likes this
#3 Pinbout
Pinbout
Posted 20 May 2019 - 06:15 AM
The very center has a hole
outside of that some shallow zones
but ke is the only way to test the edge.
Edited by Pinbout, 20 May 2019 - 06:29 AM.
#4 ccaissie
ccaissie
  • Loc: Whitefield, Maine
Posted 20 May 2019 - 07:27 AM
The slight inward kink at the edge tells me it's turned.  An outside focus picture would probably more clearly show the reverse hooks typical of TDE.  The #2 band looks suspiciously uneven.... too sharp a curve near center, too straight as it passes through 70%.
Yeah, microripple.
So why are you testing this mirror?  bad images?
Someone with the Ronchi skills could do better analysis if you provided the info re: lpm of the grating.  They could do the Bartels technique of generating the ideal Ronchi and overlaying it.
#5 Arjan
Arjan
  • Loc: Netherlands
Posted 20 May 2019 - 08:05 AM
#6 Pinbout
Pinbout
Posted 20 May 2019 - 08:46 AM
this is what I get in terms of an undercorrection… if and only if....4lines/mm [100lpi] grating was used.
I believe the outer 30% is more undercorrect than inside the 70%
but still I'm at 2~'s under with this rendering.
#7 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 20 May 2019 - 10:38 AM
It is a 50 line ronchigram .
#8 dogbiscuit
dogbiscuit
Some astigmatism.
It looks like the mirror might be sitting on a single point at center line bottom edge rather than support points each side of center.
#9 Pinbout
Pinbout
Posted 20 May 2019 - 01:58 PM
at 50lpi its much much better
but the difference between right on and 1/4~ is so small its indistinguishable with a coarse grating.
but a 133lpi the difference of a qtr~ is much more obvious.
Edited by Pinbout, 20 May 2019 - 01:59 PM.
#10 scopemankit
scopemankit
  • Loc: south africa
Posted 29 May 2019 - 05:48 AM
I don't think the centre hole is a train smash as it would be shaded by the diagonal ot secondary (if Cass).
