CEM120 No Internet, secured Wifi
EAA mount astrophotography
23 replies to this topic
#1 Michaeljhogan
Michaeljhogan
Posted 20 May 2019 - 08:50 PM
No matter what i try i keep getting the same thing showing their is signal but wont connect
to the mount my Wifi connects easy to my ASI294mc Pro Camera
Edited by Michaeljhogan, 20 May 2019 - 09:07 PM.
#2 Michaeljhogan
Michaeljhogan
Posted 20 May 2019 - 09:08 PM
yes i done all on that 12345678 and downloaded iOptron Commander
#3 Michaeljhogan
Michaeljhogan
Posted 20 May 2019 - 09:11 PM
My mount is only 25-30 ft from my house
#4 bmhjr
bmhjr
  • Loc: Colorado
Posted 20 May 2019 - 09:12 PM
It shows connected? When you go into iOptron Commander and select wifi, then what happens?
  • bobzeq25 likes this
#5 Xeroid
Xeroid
  • Loc: USA
Posted 20 May 2019 - 09:13 PM
Did you download latest ASCOM Platform and install it from http://www.ascom‐standards.org before installing iOptron Commander?
#6 Michaeljhogan
Michaeljhogan
Posted 20 May 2019 - 09:17 PM
I cant get into Commander as im using two Intel NUC the one in the shed has all the programs in it when i use my normal
house Wifi with Remote desktop its easy i control the camera with sharpcap and NUC
#7 Xeroid
Xeroid
  • Loc: USA
Posted 20 May 2019 - 09:32 PM
Lemme see If I understand:
- Your trying to connect to the CEM120 POINT-To-POINT WiFi network while at the same time your trying to Wifi into your NUC?
Its two different networks.
Me thinks you might need to use a Serial-to-USB cable INTO the NUC then run ASCOM & iOptron Commander  ON THE NUC.
The do a remote WiFI to the NUC using your normal home WiFI.
Wheeeew...
  • psandelle and OldManSky like this
#8 Michaeljhogan
Michaeljhogan
Posted 20 May 2019 - 10:30 PM
Wheeeew...
  • Xeroid and otis4411 like this
#9 Bowman
Bowman
  • Loc: Michigan/Florida
Posted 20 May 2019 - 10:51 PM
As I found out the hard way, using WiFi with an ASI 294 camera is extremely frustrating and well nigh impossible. The 294 is a USB3 camera. USB3 and WiFi operate on the same frequency and, if both are operating, WiFi almost always fails. I have a Mach One mount and a 294 camera. My experience is that the mount, with SkySafari on WiFi, will work for a while, then WiFi shuts off and will not reconnect, even if I change from my iPad to my phone. Save yourself from frustration and hard wire the mount and camera to your computer, iPad, or phone.
Larry Hoffman, M.D.
  • Xeroid likes this
#10 Michaeljhogan
Michaeljhogan
Posted 20 May 2019 - 10:53 PM
Wheeeew...
blush.gif USB to RS232 to NUC in the Shed https://www.ioptron....duct-p/8435.htm
#11 bobzeq25
bobzeq25
Posted 20 May 2019 - 10:54 PM
Just a possible thought, I have no idea if it's relevant.  On my CEM60 when using StarFi to connect to the mount, there are two modes.  One is access point, I believe the other is station mode.  iOptron says use access point, but only station mode works with my setup.
If you're using the RS-232 port to connect to the mount, and an RS232 to USB converter, the converter is a common failure point.  I recommend iOptrons converter.
#12 amoncayo
amoncayo
Posted 21 May 2019 - 12:53 AM
Michael,
There is a post in the CEM120 user group that touches on the topic of connectivity. I asked you to please have a look there.
#13 Xeroid
Xeroid
  • Loc: USA
Posted 21 May 2019 - 09:53 AM
Michaeljhogan
Not sure this will work but its easy & cheaper to try:
If your NUC has an Ethernet connector, use that to your CEM120 and TURN OFF the CEM120 Wifi if possible.
You should be able to use iOptron Commander  ON THE NUC via its Ethernet setting.
#14 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 21 May 2019 - 10:27 AM
The wifi option creates it's own network with just the computer and the mount on it. Note that the wifi link doesn't allow you control anything other than the mount. It's not like it's a gateway to your entire imaging system.
You just need to use a USB cable to connect a computer to the CEM120. I've had mine connected that way for over a year and everything works just fine. There is no need for a USB serial converter but you can use one if you prefer to. Plug it into the RS232 port located at the base of the mount. You can also get the mount on your home network if you have a router or a switch in the observatory using the LAN connection. Then everyone is on the same network and you can access the computer that controls the mount and that computer can access the mount using commander.
I'd be curious to learn what the point is of using the wifi link if you have a computer at the mount anyway. I get that for visual use at a star party it would be nice to use a planetarium program rather than the hand controller. Other than that, what's the point of that connection?
Rgrds-Ross
  • psandelle and bobzeq25 like this
#15 amoncayo
amoncayo
Posted 21 May 2019 - 02:45 PM
Michael,
I cleaned up a set of diagrams I had put together some months back. Please see attached. This is how I connect to my three mounts using the same basic infrastructure.
The reason I use the laptop and iPad is that the laptop is usually in a warm place (my home or camper) and when I go to the mount(s), I use the iPad instead. With Windows RDC, I can switch from one to the other readily.
In fact, I've gotten a bit more advanced recently and have figured out how to configure a VPN router slaved to my main router, so that I can access and operate my observatory securely from anywhere.
Al
Attached File  190522_CEM120_CEM40EC_EQ-G_Comm.pdf   145.92KB   25 downloads
#16 Michaeljhogan
Michaeljhogan
Posted 21 May 2019 - 04:34 PM
Rgrds-Ross
The whole point is to not freeze the nuts off myself in the winter i tested the usb lead today from the NUC at the pier to the mount usb port
with a little short usb lead it just wont pick up my mount so it looks like now its two very long Ethernet leads going into the i5 NUc and the CEM120 mount
Edited by Michaeljhogan, 21 May 2019 - 05:00 PM.
#17 Xeroid
Xeroid
  • Loc: USA
Posted 21 May 2019 - 11:09 PM
amoncayo:
Excellent!
ONE Ethernet cable to a network switch at the OBS, Wifi for the home device only, mini PC and CEM120 each have specific IP Addresses.
Al
attachicon.gif 190522_CEM120_CEM40EC_EQ-G_Comm.pdf
#18 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 21 May 2019 - 11:11 PM
Before giving up USB, try this. Download and install all of the latest firmware and the 6.2 Commander. Open up device manager and check the comm ports. Connect the mount. A new comm port should appear. After that you should be able to connect. If you don't see the comm port then there's something wrong with your installation process or the mainboard is defective. Make sure that you use ALL of the new stuff - firmware and driver and that you have the latest ASCOM Platform installed. Should work fine unless there is something very strange with the NUC.
I access my mount from home over the internet with this very same connection using Teamviewer or ChromeDesktop and it works perfectly. Connecting the PC to the mount using USB is the simplest possible topology but it's always fun to figure out other ways of doing things.
Rgrds-Ross
  • psandelle likes this
#19 Michaeljhogan
Michaeljhogan
Posted 22 May 2019 - 06:28 PM
Rgrds-Ross
I was using the old Commander with CEM-60 logo
Edited by Michaeljhogan, 22 May 2019 - 06:29 PM.
  • OldManSky likes this
#20 Michaeljhogan
Michaeljhogan
Posted 22 May 2019 - 06:41 PM
major problem out of the way now sent back the iPolar Camera gave me the wrong one again after giving me the wrong backet
#21 Michaeljhogan
Michaeljhogan
Posted 22 May 2019 - 06:46 PM
Im using my own very powerful Wifi dont need to use mount Wifi Hi-Link
#22 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 23 May 2019 - 08:09 AM
You can really skip the iPolar scope and use PHD to polar align the mount for free. I've been experimenting with it the last week or so and it works as well as anything else on the market and it's free and easy to use. Give it a try.
Rgrds-Ross
#23 Michaeljhogan
Michaeljhogan
Posted 23 May 2019 - 11:00 AM
Rgrds-Ross
I cant wait to try it correct me if im wrong it seems like a really smart auto drift alignment and if you want manual
too if you want as well ?
#24 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 23 May 2019 - 02:37 PM
Yes, PHD 2.6 has a drift alignment tool that's easy to use. Of course, PHD needs to know the focal length so that it can determine the image scale. What it's doing is measuring the deflection of the selected star from zero while not guiding. That deflection can be used to calculate the distance from the pole in azimuth and altitude. Just keep adjusting the mount until you get to zero. You don't need to see Polaris either.
Rgrds-Ross
Also tagged with one or more of these keywords: EAA, mount, astrophotography
