Astronomik 6nm vs Baader 4.5nm
16 replies to this topic
#1 amajed172
amajed172
Posted 21 May 2019 - 09:28 AM
Hi, I'm thinking of getting ether:
Astronomik L-RGB Typ 2c Color filter + NB Ha OIII SII 6nm
OR
Baader LRGB CCD Filter set + Ultra Narrowband Ha 3.5nm OIII SII 4.5nm
what do you think I should get?
both sets almost the same price.
#2 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 21 May 2019 - 10:34 AM
What equipment will you be using them with?
Edited by happylimpet, 21 May 2019 - 10:34 AM.
#3 amajed172
amajed172
Posted 21 May 2019 - 10:36 AM
ASI1600MM-C Pro + 7 Pos EFW
EdgeHD 8"
Esprit 100ED
#4 happylimpet
happylimpet
Posted 21 May 2019 - 10:46 AM
And how bad is your light pollution?!
#5 amajed172
amajed172
Posted 21 May 2019 - 10:51 AM
Sorry for that.
Class 4 Bortle.
#6 happylimpet
happylimpet
Posted 21 May 2019 - 11:04 AM
Well after all those questions, I dont have any profound wisdom.
However I would be tempted to get the 6nm myself  (or another wider one) for the Ha at least as
1) your LP isnt too bad so you dont need ultra narrow and
2) wider transmission allows you to image HII regions (the pink splodges) in galaxies to higher redshifts. People often forget about this with narrow bandpass filters.
#7 amajed172
amajed172
Posted 21 May 2019 - 11:20 AM
Well, I see a lot of people trying to get Astrodon 5nm and 3nm I don't think they all live in a red zone right? so I figured maybe a 4.5nm is good too.
#8 RogeZ
RogeZ
  • Loc: Palm Beach Gardens, FL
Posted 21 May 2019 - 05:27 PM
I have the Astronomiks and they are fantastic.
The Baaders are new and I have no idea how good the AR coatings are. I have used the 7nm and 3.5nm as well and they are good but tend to create reflections.
  • amajed172 likes this
#9 amajed172
amajed172
Posted 21 May 2019 - 05:35 PM
Nice, do you see any halos when using the Astronomiks? especially when using refractor?
#10 RogeZ
RogeZ
Posted 21 May 2019 - 06:54 PM
Nope. The astronomiks are halo free on every scope i have use them.
#11 Stelios
Stelios
  • Loc: West Hills, CA
Posted 21 May 2019 - 07:16 PM
I have halos on bright stars with my Astronomik Sii filter. The other two just display the micro-lensing effect of the ASI1600.
I think there's some variability--I may well have got a lemon in the Sii.
#12 entilza
entilza
  • Loc: Oakville, ON, Canada
Posted 21 May 2019 - 08:33 PM
I get that too on my Sii on bright stars but I get more of the microlensing qlmost like a plus sign on the Sii. Its the 1600 camera on bright stars.. A slight desaturation tool helps touch that up.
#13 amajed172
amajed172
Posted 22 May 2019 - 03:23 AM
Maybe Halo in Sii only is not big of a deal, are they all parfocal as advertised? can I really focus using L and image with NB without issues?
#14 Stelios
Stelios
Posted 22 May 2019 - 11:48 AM
They (Astronomik) are much closer to parfocal than ZWO filters (at least the 1st generation) are.
With my Rigel driving a Feathertouch, I had Oiii focus at Ha -10 and Sii at Ha + 10. However Ha was Lum -24. You could try these offsets, measure your own (not all copies will focus exactly the same) or you can refocus.
IMO, a 10 tick change (36000 ticks total range) is close enough to not merit refocusing. A 24 tick change is marginal, and yes, you could get away with it.
However, this assumes that temperature is constant. As this is likely untrue, you should probably be frequently refocusing anyway, unless you have temp compensation dialed in.
#15 amajed172
amajed172
Posted 22 May 2019 - 03:38 PM
I do have an auto focuser and a temp sensor too, I do plan on focusing every 1 degree change in temp, but I do not want to refocus using a NB filter, it will be faster to refocus using Lum filter, that's why I want parfocal filters.
#16 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 23 May 2019 - 06:39 AM
Another benefit of narrow bandwidths are reduced star sizes, which allows greater emphasis on the nebula, as well as resistance to moonlight (a very important point).
However, you cannot use fast telescopes with very narrow bandwidths, as you'd be wasting useful aperture. Even with a special bandpass preshift, my 3nm filters only work down to f/4 at best (despite claims by the manufacturer that it will work till f/3, the math says otherwise). Without the bandpass preshift, which is the default, any system working faster than around f/5 for a 3.5nm filter will be wasting useful aperture.
I live in a bortle 8 zone, so 3nm filters (especially for OIII) are almost a necessity. However, this means I wouldn't be able to use some of the very nice f/2.8 astrographs (or fast telephoto lenses) out there.
Edited by HydrogenAlpha, 23 May 2019 - 06:41 AM.
#17 amajed172
amajed172
Posted 23 May 2019 - 06:45 AM
Nice, so I guess the 4.5 OIII and SII are good for f5.5 and f10 (my two telescopes)
I do want smaller stars. does make the picture look nicer.
  • HydrogenAlpha likes this
