Unusual Vintage Finderscope Bracket...Who Made This?
15 replies to this topic
#1 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 21 May 2019 - 12:35 PM
Got this in a recent astro buy, an unusual vintage refractor finderscope bracket with a small unbranded 30mm finderscope in it, possibly not orginal.
What's interesting is the extension cast into it that looks to be a camera platform. Also the diameter of the tube the base bolts to was quite small, around 2". Seems like a pretty fancy bracket for such a small tube and thus objective, perhaps a 40mm?
Another interesting aspect of the bracket is the 1/2" hole with thumbscrew that is likely to clamp an arm or some such, possibly a sun projection plate arrangement?
Anyone know anything about this bracket?
Thanks in advance for your input.
Tom Duncan
  • Bomber Bob, Garyth64, jcruse64 and 1 other like this
#2 macdonjh
macdonjh
Posted 21 May 2019 - 12:57 PM
I made it.  It's the only one in existence, so be careful with it.
  • Astroman007 and Thaeland like this
#3 Thaeland
Thaeland
  • Loc: Cibolo, Texas
Posted 21 May 2019 - 01:15 PM
My bet is this mounts on a refractor focuser assembly and not the main OTA. That would explain the small diameter of where it mounts.
Sent from my Moto Z (2) using Tapatalk
Edited by Thaeland, 21 May 2019 - 01:28 PM.
  • dave brock, Bomber Bob, Kasmos and 1 other like this
#4 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 21 May 2019 - 01:21 PM
Hmm, good suggestion Jon, seems plausible.
#5 Kasmos
Kasmos
  • Loc: So Cal
Yes, it probably mounted to the focuser and as you said, the small hole was likely for a solar screen rod.
It's very cool. It looks like something Goto or Carton would do.
  • TOM KIEHL likes this
#6 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 21 May 2019 - 01:46 PM
IF that's the original paint...  Mizar.  It's a 100% match to my AR-1 EQ.
(And, Mizar put a 35mm camera mount on the counterweight shaft of the M / P - 100 Newtonians, so puttng one on a focuser is a rather Mizarish thing to do.)
Edited by Bomber Bob, 21 May 2019 - 01:48 PM.
  • Thaeland likes this
#7 rolo
rolo
  • Loc: GA
Posted 21 May 2019 - 03:52 PM
Is that a 1/4 20 camera adapter on the side?
#8 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 21 May 2019 - 08:24 PM
The paint looks original JW. Might you have an Mizar catalogs that may show it?
And yes, standard camera 1/4-20 thread. I don't think the circular pad around the post is original though, looks too new and is a bit too thick.
#9 Mike W.
Mike W.
  • Loc: Washington State
Posted 21 May 2019 - 10:05 PM
just what I was thinking too
#10 Bomber Bob
Bomber Bob
Posted 21 May 2019 - 10:29 PM
Tom, I have only 1 small Mizar catalog, and it has only 1 page of accessories.
But in going through some of the others, I found that nice Newtonian focuser that I put on my RV-6:  Royal Astro sold it as an accessory, and it looks like the LN-6E came equipped with it, too.
#11 Tom Duncan
Tom Duncan
  • Loc: Chico, CA
Posted 22 May 2019 - 10:42 AM
Thanks all.
#12 Bomber Bob
Bomber Bob
Posted 22 May 2019 - 11:46 AM
Some Goto scopes had tall slender finder brackets, so I'm going through those catalogs, too.
#13 rolo
rolo
  • Loc: GA
Posted 22 May 2019 - 01:05 PM
Doesn't look like any of the Mizars in this catalog.
https://wiki.telesco...pes_Catalog.pdf
GOTO 1974 Catalog nothing in this one. Maybe its an older model?
https://wiki.telesco...974_Catalog.pdf
Edited by rolo, 22 May 2019 - 01:15 PM.
#14 Bomber Bob
Bomber Bob
Posted 22 May 2019 - 03:03 PM
To make it even more confusing, some of the older Carton scopes had similar tall slender posts for a few finder brackets.  And, a very few HINO-branded scopes as well (in addition to the more numerous HINO/Mizar-branded)...
And, I just found a Japanese ad for a 1970s Nikon 80mm EQ kit with the finder on a similar tall stalk.
Edited by Bomber Bob, 22 May 2019 - 03:16 PM.
  • rolo likes this
#15 rolo
rolo
  • Loc: GA
Posted 22 May 2019 - 03:09 PM
This one is real mystery. It has hints of Tak & Vixen.
#16 Stew44
Stew44
Posted 23 May 2019 - 12:03 PM
I don't think it's Goto.  The set screws and lock nuts look original and not anything Goto-esque.  The mid-70's 60mm Goto School Telescope had a plastic finder bracket that incorporated a hole for the solar projection rod, but a compact squatish attachment to focuser body, not elegant like this stalk.
