Stellarvue 50mm RACI Shoe
8 replies to this topic
#1 mfoose
mfoose
  • Loc: Lancaster, PA
Posted 22 May 2019 - 07:42 AM
I am building a Dob and would like to upgrade my 50mm RACI from a 8x50 GSO to a 9x50 Stellarvue. However, I don't want to do this right now, but in a year or so. I'd rather spend my money upgrading EPs at this point. I am wondering, would I be able to use the same mounting shoe used on the 8x50 GSO or would I need to buy a specific one for the Stellarvue 50-60mm rings. I am concerned about drilling new mounting holes in order to switch mounting shoes down the road.
Clear skies
#2 Jon Isaacs
Posted 22 May 2019 - 08:01 AM
I think this is the ring set you want:
 https://www.stellarv...l-shoes-r050da/
  • mfoose likes this
#3 spencerj
spencerj
  • Loc: Londonderry, NH
Posted 22 May 2019 - 08:37 AM
That should fit the standard Synta mounting shoe.  The SV50 is a great finder.  I tried the 60mm version a while back, but wasn't happy with it.  The field curvature of the 60mm version was too much for me, but the SV50 is great.  Nice bright sharp image.  I use mine with an 11mm ES eyepiece making it about an 18x finder with a 4.5* FOV.  A perfect compliment to my red dot finder.
  • mfoose and Allanbarth1 like this
#4 mfoose
mfoose
Posted 22 May 2019 - 12:18 PM
Thanks Jon and Jason!
My decision now is whether or not to buy the Stellarvue 50-60mm rings that have a lower profile and mount my 8x50 GSO RACI in the rings until I upgrade to Stellarvue 50mm RACI or just buy the Stellarvue 50-60mm rings that fit the Synta shoe. I do like the lower profile. Less weight and bulk to deal with.
Edited by mfoose, 22 May 2019 - 12:18 PM.
#5 spencerj
spencerj
Posted 22 May 2019 - 12:29 PM
I use the low profile rings on my scope. They both use the same style shoe. Just a matter of having the clearance everywhere to use the low profile design.
  • mfoose likes this
#6 mfoose
mfoose
Posted 22 May 2019 - 02:02 PM
How high is the finders lens cell from the surface of your dob?
#7 Will_S
Will_S
Posted 22 May 2019 - 06:07 PM
Even lower profile:  https://agenaastro.c...base-dfb50.html
Double-check that the ring diameter will suffice for the SV50, but you shouldn't need rings as large as the 60mm finder requires.
#8 spencerj
spencerj
Posted 22 May 2019 - 07:14 PM
The finder scope is about 1.5” above the surface, but that includes the height added by the shoe.
  • mfoose likes this
#9 mfoose
mfoose
Posted 23 May 2019 - 01:42 PM
Thanks! That helps a lot
