TeleVue Starbeam Working Intermittently
3 replies to this topic
#1 Muppo1
Muppo1
  • Loc: Wellington, New Zealand
Posted 22 May 2019 - 09:07 PM
Hello
My TeleVue Starbeam no longer works reliably, in that the LED does not illuminate when the ON/OFF switch is turned on.
I have changed batteries with no effect.
However, when I tap the bottom of the ON/OFF switch, the LED light does come on (usually).
Clearly there is a loose connection somewhere.
Any ideas about how to fix this?
Thank you.
#2 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 22 May 2019 - 09:18 PM
The switch is dirty.  You want an aerosol to spray into an opening in the switch. Rremove battery first & allow to dry after, rotate the switch while it's wet.  One is : Tuner Control Cleaner and Lubricant -- Radio Shack Cat No. 64-4315. An  equivalent should be available but I can't offer one, someone else will come along who can.
#3 M11Mike
M11Mike
  • Loc: Ballston Lake, NY
Posted 22 May 2019 - 10:54 PM
Deoxit works well resolving bad connections - that's what it's made for.
M11Mike
#4 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 23 May 2019 - 10:59 PM
