SGP and Camera Gain/Offset
8 replies to this topic
#1 Doug N
Doug N
  • Loc: Minnesota
Posted 23 May 2019 - 09:15 PM
Is there a way in SGP to set different gains and offsets for each filter?
Thanks.
#2 jerahian
jerahian
  • Loc: Maine
Posted 23 May 2019 - 09:26 PM
Yes.  In the sequence panel, click on the little gear icon on the left side of each event and select Event Settings.  Depending on your camera, you will be able to set the gain and/or offset there, separately for each event.
SGPro.JPG.3ee028b2b0636eb721e6e215f85aa1
-Ara
  • H-Alfa, Doug N, Jon Rista and 1 other like this
#3 H-Alfa
H-Alfa
  • Loc: Spain
Posted 24 May 2019 - 04:38 AM
Wow! Is this new on the new version of SGP or its specific for ZWO cameras?
Enviado desde mi ANE-LX1 mediante Tapatalk
#4 buckeyestargazer
buckeyestargazer
    Vendor - Buckeyestargazer.net
  • Loc: IN, USA
Posted 24 May 2019 - 06:56 AM
With a ZWO camera you can set both gain and offset.  With a QHY camera you can set gain only.  This has been around for a while now.
#5 H-Alfa
H-Alfa
  • Loc: Spain
Posted 24 May 2019 - 07:47 AM
OK. Thank you. I saw that the QHY was able to set the gain and I expected that the sgp stuff was able to do the same with the offset. Not luck for qhy users yet...
#6 jerahian
jerahian
  • Loc: Maine
Posted 25 May 2019 - 01:10 AM
I have to say, I own the ZWO 1600MM-Cool and SGP does not let me set the offset in the event, only the gain.  The offset can only be set at the camera level for some reason.  I know and I have seen others with a 1600 who can set the offset in the event, so I don't know if this a version thing with the camera.
-Ara
#7 buckeyestargazer
buckeyestargazer
  • Loc: IN, USA
Posted 25 May 2019 - 06:50 AM
-Ara
I believe that means you are using the ASCOM driver and not the ZWO native driver.  SGP added native support for ZWO cameras which has access to both gain and offset.  ASCOM does not yet allow access to offset.
Whatever driver you are using in the camera setup, try using a different ZWO or ASI camera driver in the list and see if that gets you the offset.
  • cfosterstars likes this
#8 buckeyestargazer
buckeyestargazer
  • Loc: IN, USA
Posted 25 May 2019 - 06:51 AM
Offset really isn't all that critical.  I use one offset for both LRGB and narrowband with my QHY cameras.  I set it and forget it.
#9 cfosterstars
cfosterstars
  • Loc: Austin, Texas
Posted 25 May 2019 - 07:57 AM
Exactly,
I have you both the native and the ASCOM. The ASCOM allows you to set the gain only and the Native will allow you to set the gain and offset. I use the same offset for all setting at 40 just to be simple so both work fine. You can also set both with the ASCOM driver when you connect he camera. This is the default and will only be changed if you set up the sequence events to alter them. If you dont set them in the sequence events then you will not be able to add the gain and/or offset setting to the file name since if you try it will return "not set" into the file name.
